    MMM-MyCommute
    286 Posts 80 Posters 741.2k Views 77 Watching
      canadrian @Smotx
        j.e.f.f Project Sponsor Module Developer @Smotx
        @smotx The module is designed to be as frugal as possible when making requests. Outside of your start and end times, no requests are being made to Google. Between those times, requests are made every ten minutes, one for each destination configured.
        • citizendevpiC
          citizendevpi @Bob
          @bob so how often do you refresh the data to stay under the limit of the “free” tier?
          • A
            Aries1984 Module Developer
              rmonteroc
              Hi, yesterday this module stopped working for me, I reinstalled it using the default config and still not working, I don’t even get the “loading” message
              Anybody else?
              • joela85J
                joela85
                Hi, mine was working fine for me this morning.
                • Y
                  yupwho
                  @j-e-f-f - Thanks for creating this module.
                  I have a question - is it possible to use the Origin property inside the destination objects? The use case is that i’ll like to display the commute to work in the morning and in the evening display the traffic back from work. I believe this will be possible if origin can be defined at each destination level.
                  J 1 Reply Last reply
                    j.e.f.f Project Sponsor Module Developer @yupwho
                    @yupwho no, the module doesn’t work that way. However you can define a second instance if the module and use your work as the origin and route your way home. However it wouldn’t be an accurate representation of commute time because the module reflects current traffic patterns. So it might say your trip home right now is 20 minutes but it might actually be an hour at the time you actually commute home.
                      Skeeter
                      Does this module still work? I’ve just installed it and get nothing other than “Loading…” no matter what I try. I’ve used the example config (with my own API key) and tried a number from scratch and nothing works.
                      The MMM-Traffic module this is based on is installed and works so I know my API is working. Anything dumb I should check for to make sure I’ve not screwed up?
                      Edit: Solved it. When running in Docker I needed to restart the Container for the API key to get picked up and work.
                      • F
                        fotis.str @Looking
                        @looking Hi looking, I’m having the same an error display how did you solved it ? thanks in advance, FS
                          robiv8
                          Is this modul working also in germany?
                          • A
                            @robiv8 yeah it does work for me perfectly. Can send you my latest config if you want?
                            lolobyteL 1 Reply Last reply
                              robiv8
                              Au das wäre sehr nett :kissing_face:
                              • lolobyteL
                                lolobyte @Aries1984
                                @aries1984
                                Bitte mir dann auch wenn moglich.
                                • K
                                  keyun21
                                  Newbie here I guess i have to pay for Google API service right? without that this module not going to work correct?
                                  BKeyportB 1 Reply Last reply
                                  • BKeyportB
                                    BKeyport Module Developer @keyun21
                                    @keyun21 You have to set up a pay account, including a credit card, but they give you a specific number of free accesses, and if you keep the module to a timeframe that you’d normally look at it, you’d have a hard time exceeding those uses.
                                    K 1 Reply Last reply
                                    • K
                                      keyun21 @BKeyport
                                      @bkeyport said in MMM-MyCommute:
                                      Thanks a lot I will look into to see how many I can get free and how to set up module to run specific times?
                                      • A
                                        Hi everybody,
                                        sorry for the late reply. Haven’t been here much in the last couple of weeks. Here’s my config:
                                                module: 'MMM-MyCommute',
                                                position: 'bottom_right',
                                                header: 'Traffic',
                                                classes: 'default everyone',
                                                    apikey: 'your API Key',
                                                    origin: 'Marienplatz 1, 80331 München',
                                                    startTime: '05:00',
                                                    endTime: '10:00',
                                                    hideDays: [0, 6],
                                                    destinations: [
                                                            destination: 'Belgradstraße 13, 80796 München',
                                                            label: 'Good Food',
                                                            mode: 'driving',
                                                            color: '#82E5AA'
                                          seanluse41
                                          Can this module support Japanese addresses?
                                          The default config and values work for me, but putting in Japanese addresses returns loading… forever.
                                          • T
                                            thoeng
                                            This is great and very practical module! Everything is working on me but i would like to remain below USD200 (40K calls)/mo API call request. This means staying below 1.3K calls/day
                                            However, after installed I can see 570+ request call in 2 hours on Google API dashboard. This is despite setting pollFrequency: 1200000 (20mins interval) on MM config.
                                            Any help please?
                                            I 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
