    MMM-MyCommute
    286 Posts 80 Posters 741.2k Views 77 Watching
    • K
      keithsizer
      Hi all, I hope you can help me? I can’t get this to work, no matter what I try. I’ve read everything I’ve found about this module, and tried everything, but nothing works. At the moment, I have copied and pasted the example entry, only adding the api key. Everything loads up with errors next to them. What am I doing wrong? On the google console, which api do I need to enable (currently, I’ve enabled everything for google maps)
        soundarchitect @keithsizer
        @keithsizer Hi, you should just activate the “Directions API” on Google console. Best, L.
        • A
          Akutik
          Is it right that you have to pay for Google Directions API for now? So if I dont pay for that I only have one request for each day? Because my log says my daily request have exceeded:/
            Smotx
            a question about,
            sorry if i’m not clear, my english is bad.
            now that the APIs are no longer free, when the functions ‘start time / end time’ are activated and the module is not displayed on MagicMirror, does it make requests to google?
            Ex. : If i set endTime: '09:00', , module continues requests after ?
            C J 2 Replies Last reply
              canadrian @Smotx
                j.e.f.f Project Sponsor Module Developer @Smotx
                @smotx The module is designed to be as frugal as possible when making requests. Outside of your start and end times, no requests are being made to Google. Between those times, requests are made every ten minutes, one for each destination configured.
                • citizendevpiC
                  citizendevpi @Bob
                  @bob so how often do you refresh the data to stay under the limit of the “free” tier?
                  • A
                    Aries1984 Module Developer
                      rmonteroc
                      Hi, yesterday this module stopped working for me, I reinstalled it using the default config and still not working, I don’t even get the “loading” message
                      Anybody else?
                      • joela85J
                        joela85
                        Hi, mine was working fine for me this morning.
                        • Y
                          yupwho
                          @j-e-f-f - Thanks for creating this module.
                          I have a question - is it possible to use the Origin property inside the destination objects? The use case is that i’ll like to display the commute to work in the morning and in the evening display the traffic back from work. I believe this will be possible if origin can be defined at each destination level.
                          J 1 Reply Last reply
                            j.e.f.f Project Sponsor Module Developer @yupwho
                            @yupwho no, the module doesn’t work that way. However you can define a second instance if the module and use your work as the origin and route your way home. However it wouldn’t be an accurate representation of commute time because the module reflects current traffic patterns. So it might say your trip home right now is 20 minutes but it might actually be an hour at the time you actually commute home.
                              Skeeter
                              Does this module still work? I’ve just installed it and get nothing other than “Loading…” no matter what I try. I’ve used the example config (with my own API key) and tried a number from scratch and nothing works.
                              The MMM-Traffic module this is based on is installed and works so I know my API is working. Anything dumb I should check for to make sure I’ve not screwed up?
                              Edit: Solved it. When running in Docker I needed to restart the Container for the API key to get picked up and work.
                              • F
                                fotis.str @Looking
                                @looking Hi looking, I’m having the same an error display how did you solved it ? thanks in advance, FS
                                  robiv8
                                  Is this modul working also in germany?
                                  • A
                                    @robiv8 yeah it does work for me perfectly. Can send you my latest config if you want?
                                    lolobyteL 1 Reply Last reply
                                      robiv8
                                      Au das wäre sehr nett :kissing_face:
                                      • lolobyteL
                                        lolobyte @Aries1984
                                        @aries1984
                                        Bitte mir dann auch wenn moglich.
                                        • K
                                          keyun21
                                          Newbie here I guess i have to pay for Google API service right? without that this module not going to work correct?
                                          BKeyportB 1 Reply Last reply
                                          • BKeyportB
                                            BKeyport Module Developer @keyun21
                                            @keyun21 You have to set up a pay account, including a credit card, but they give you a specific number of free accesses, and if you keep the module to a timeframe that you’d normally look at it, you’d have a hard time exceeding those uses.
                                            K 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
