    Using MM as a SmartDisplay for my Living room
    14 Posts 8 Posters 16.6k Views 10 Watching
      Mykle1 Project Sponsor Module Developer @sgopala
      @sgopala
      Nice. :-)
        j.e.f.f Project Sponsor Module Developer @sgopala
        @sgopala Heh! I just did the same thing for my Kitchen:
        F E 2 Replies Last reply Reply Quote 1
        • F Offline
          fabbr @j.e.f.f
          @j.e.f.f Loved the design! How did you manage to have the clock the the weather(9º) at the same level?
            j.e.f.f Project Sponsor Module Developer @fabbr
            @fabbr Ahh… CSS is a wonderful thing! The current temperature and weather icon are actually part of the weather forecast module in the centre column. I used CSS to move these two elements leftward relative to what their natural position would have otherwise been, then similarly I moved the forecast table upwards relative to it’s original position.
            I’m going to modify my Calendar module to allow two columns so that I can fit 8 entries over four rows, but that requires a change to the module itself.
            F 1 Reply Last reply Reply Quote 1
            • F Offline
              fabbr @j.e.f.f
              @j.e.f.f And besides reloading MM everytime you make a change is there a better way to visualize them as you start messing with the CSS?
                @fabbr You don’t need to restart MagicMirror for CSS changes. You just need to refresh your browser. And if you use the inspector, you can play around with CSS changes live in the browser.
                • G Offline
                  goprojojo
                  Nice! Could you share your css?
                  J 1 Reply Last reply Reply Quote 2
                    j.e.f.f Project Sponsor Module Developer @goprojojo
                    @goprojojo I could but it is heavily tailored to the screen resolution – 1366x768. I doubt you’d find that useful. What part in particular are your trying to duplicate?
                      spwood100
                      @j-e-f-f said in Using MM as a SmartDisplay for my Living room:
                      Would you be able to show how to align the current weather towards the clock on the left? That would be fantastic … great information board!
                      • DæmonEyesD Offline
                        DæmonEyes
                        Hey is that like a Tamil newspaper in the top_center position? I could be wrong, cause it looks similar to Malayalam, but different.
                        • E Offline
                          Egnos @j.e.f.f
                          Hi, which module did you use for the player at the bottom right?
                            @egnos said in Using MM as a SmartDisplay for my Living room:
                            That’s the Sonos module
                            https://forum.magicmirror.builders/topic/1567/mmm-sonos-to-show-what-your-sonos-is-playing
                            I’ve added a bit of my own styling to it. I’m not using it any more, though, as it takes up precious space. In fact, I’ve overhauled the entire thing. Read about it here, if you are interested:
                            http://jeffsnerdyprojects.blogspot.com/2018/04/information-center-v2.html
                            • E Offline
                              Egnos @j.e.f.f
                              @j-e-f-f Wow, very nice!
                              Thank you very much!
