    My mirror from Montreal
    22 Posts 5 Posters 16.2k Views 4 Watching
    • jcasmanJ
      jcasman
      Thanks to @lpgjg and @Mykle1 - Really appreciate the suggestions. I’ve installed mmm-moon-phases. It’s great. I installed MMM-Lunartic, and love all the extra stats. I’m struggling in CSS to get the moon image closer to the header (or a module above it). It’s just an aesthetic change. Seems like maybe the image itself has a larger border. Would like to fix that but otherwise, super cool. Thank you @Mykle1 for making such a fun module.
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @jcasman
        @jcasman
        Use these in your custom.css file and adjust accordingly.
        .MMM-Lunartic img.photo {
          max-width: 100%;
          margin-left: 0px;          /* Precisely align moon picture with these */
          margin-right: 0px;
          margin-top: 0px;
          margin-bottom: 0px;
        Yes, the image is contained in a black square (outer space?) so moving it into the region of another module might cover the other module. If so, you switch the order in the config.js for both modules (move the earlier entry to after) so that the black border of the MMM-Lunartic module will be covered by the other module.
        jcasmanJ 1 Reply Last reply
        • L
          lpgjg
          This is good to know, I also had issues with the margins since I wanted it to look as if the moon was in orbit around the earth. Eventually, I gave up and made it work with mmm-moon-phase. I will probably go back an change it now that I know how to make it work.
          thanks Mykle1
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @lpgjg
            @lpgjg
            No worries, mate. Use what works for you. I’d like to see a pic of “the moon in orbit around the earth” when you’re done. Have fun.
            L 1 Reply Last reply
            • jcasmanJ
              jcasman @Mykle1
              @Mykle1 Thanks for pointing out your css file. I mucked around in it quite a bit. Changing the margin settings did not, unfortunately, seem to change the effect very much. I was able to make it overlap with a module above it, like you pointed out. I tried negative numbers, like the examples in the comments. I ended up hiding the moon image in MMM-Lunartic, setting display: none; in the css file, but using it to display the (very cool) data about the current phase of the moon and more. I am using mmm-moon-phases to display the image of the moon. This ends up with the proper “tightness” for the moon image. (Again, this is just one person’s aesthetic change.) Thanks for making both the module, the MMM-Lunartic.js and .css files so accessible. It’s been super fun tweaking the display.
              • Mykle1M
                @jcasman
                Excellent! Are you going to take a picture/screenshot so I can see the end result?
                • jcasmanJ
                  jcasman @Mykle1
                  @Mykle1 Here you go!
                  Mykle1M L 2 Replies Last reply
                  Reply Quote 2
                  • Mykle1M
                    @jcasman
                    Well done. :thumbsup:
                    • jcasmanJ
                      jcasman @Mykle1
                      @Mykle1 Thanks for all the work on MMM-Lunartic and providing it to the community. Really fun.
                        bhepler Module Developer
                        Good looking mirror! Well done, sir.
                        • jcasmanJ
                          jcasman @bhepler
                          @bhepler Hey, thanks! :-)
                          • L
                            lpgjg @jcasman
                            @jcasman Nicely done.
                            • L
                              lpgjg @Mykle1
                              @Mykle1 I only got as close as the pic I posted…with the Earth and moon to the top left of it.
                              • L
                                lpgjg
                                Is there anyway to make the background of MMM-ISS module transparent?
                                I would like just the letters and values to come through and just have a mirror affect in the background.
                                • jcasmanJ
                                  jcasman @lpgjg
                                  @lpgjg It looks like the MMM-ISS module depends on the NASA widget. Doesn’t appear you can change that. I found a module called MMM-ISS-Information which has the option to set ‘iss-map: false’ This might be what you’re aiming at. I have not tested it, however.
