    My mirror from Montreal
    22 Posts 5 Posters 16.2k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @lpgjg
      @lpgjg
      No worries, mate. Use what works for you. I’d like to see a pic of “the moon in orbit around the earth” when you’re done. Have fun.
      L 1 Reply Last reply
      • jcasmanJ
        jcasman @Mykle1
        @Mykle1 Thanks for pointing out your css file. I mucked around in it quite a bit. Changing the margin settings did not, unfortunately, seem to change the effect very much. I was able to make it overlap with a module above it, like you pointed out. I tried negative numbers, like the examples in the comments. I ended up hiding the moon image in MMM-Lunartic, setting display: none; in the css file, but using it to display the (very cool) data about the current phase of the moon and more. I am using mmm-moon-phases to display the image of the moon. This ends up with the proper “tightness” for the moon image. (Again, this is just one person’s aesthetic change.) Thanks for making both the module, the MMM-Lunartic.js and .css files so accessible. It’s been super fun tweaking the display.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @jcasman
          @jcasman
          Excellent! Are you going to take a picture/screenshot so I can see the end result?
          jcasmanJ 1 Reply Last reply
          • jcasmanJ
            jcasman @Mykle1
            @Mykle1 Here you go!
            Mykle1M L 2 Replies Last reply
            Reply Quote 2
            • Mykle1M
              @jcasman
              Well done. :thumbsup:
              • jcasmanJ
                jcasman @Mykle1
                @Mykle1 Thanks for all the work on MMM-Lunartic and providing it to the community. Really fun.
                  bhepler Module Developer
                  Good looking mirror! Well done, sir.
                  • jcasmanJ
                    jcasman @bhepler
                    @bhepler Hey, thanks! :-)
                    • L
                      lpgjg @jcasman
                      @jcasman Nicely done.
                      • L
                        lpgjg @Mykle1
                        @Mykle1 I only got as close as the pic I posted…with the Earth and moon to the top left of it.
                        • L
                          lpgjg
                          Is there anyway to make the background of MMM-ISS module transparent?
                          I would like just the letters and values to come through and just have a mirror affect in the background.
                          • jcasmanJ
                            jcasman @lpgjg
                            @lpgjg It looks like the MMM-ISS module depends on the NASA widget. Doesn’t appear you can change that. I found a module called MMM-ISS-Information which has the option to set ‘iss-map: false’ This might be what you’re aiming at. I have not tested it, however.
