    Orange PI
    27 Posts 6 Posters 13.9k Views 5 Watching
      deemedia
      Hello
      Is it possible to install MM on Orange pi one. How to do it. Everywhere installation instructions for Rasb pi
        sdetweil @deemedia
        @deemedia what os does it run? ubuntu? just ignore the word rasb and do the manual install
        i have installed on ordoid Xu4, and yesterday Nvidia Jetson Nano
        D S 3 Replies Last reply Reply Quote 0
        • bheplerB Offline
          bhepler Module Developer
          The Orange Pi website states that it can run Ubuntu, so it should be possible to run the Magic Mirror framework on it. You’ll want to follow the instructions for a manual install - don’t use the script as it is designed specifically for the RasPi.
          I’m doing something similar now with a NanoPC-T4. It installs like a champ (I’m having other issues).
            deemedia @sdetweil
              deemedia @sdetweil
              I tried installation on Armbian. I do not know what to do next, how to solve the startup problem
              pi@orangepione:~$ npm start
              npm ERR! code ENOENT
              npm ERR! errno -2
              npm ERR! syscall open
              npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
              npm ERR! enoent This is related to npm not being able to find a file.
              npm ERR! enoent
              npm ERR!     /home/pi/.npm/_logs/2019-04-20T06_03_50_330Z-debug.log
                MadScientist
                You have to execute npm startin the MagicMirror directory, not in the home directory of your user pi. E.g. do cd MagicMirror (or /home/pi/MagicMirroror whatever your MM directory is) and then run npm start.
                  deemedia
                  Installation on the Armbian in manual mode ended in error. I do not know how to solve the problem start. There is who knows options:face_with_cold_sweat: :loudly_crying_face:
                  /home/admin/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
                  npm ERR! file sh
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno ENOENT
                  npm ERR! syscall spawn
                  npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.7.1 start script.
                  npm ERR!     /home/admin/.npm/_logs/2019-04-23T17_59_43_024Z-debug.log
                    deemedia
                    Someone installed it on the Orange Pi one? can you please give instructions
                      sdetweil @deemedia
                      @deemedia libgtk-3.so.0
                      U need to install libgtk
                      See https://askubuntu.com/questions/1091101/error-libgtk-3-so-0-not-installed-even-though-its-in-usr-lib-x86-64-linux-gnu
                        sharmstr Project Sponsor @sdetweil
                        @sdetweil My jetson nano arrived a few days ago. I bought it for this purpose. Glad to hear it worked for you.
                          sdetweil @sharmstr
                          @sharmstr I installed Ubuntu 18.04, then mm without problem. Will be working on MMM-Hotword and MMM-Assistantmk2 when I get the chance. Need to move my webcam over
                          I could not boot a 64gig SD card. Only up to 32gifg
                            deemedia
                            On the way to launch. And again a mistake. I will soon throw out this Orange PI :face_with_steam_from_nose:
                            How to solve it?:dizzy_face:
                            (electron:4035): Gtk-WARNING **: cannot open display: :0
                            npm ERR! errno 1
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! This is probably not a problem with npm. There is likely additional log                ging output above.
                            npm ERR!     /home/admin/.npm/_logs/2019-04-24T05_47_37_255Z-debug.log
                              deemedia @sdetweil
                              @sdetweil said in Orange PI:
                              жно установить libgtk
                              Thanks, it helped. But now another problem
                                deemedia
                                Maybe someone has a ready image to install on a memory card and run without these tambourines.
                                ready to donate, for a working image on Orange Pi One
                                  sdetweil @deemedia
                                  @deemedia you are running a graphical user interface, right? Some desktop. U must
                                  Also, are you trying this over vnc?
                                  Display 0 is the main UI on the device
                                    deemedia @sdetweil
                                    VNC
                                    No, not VNC, directly from the device
                                      sdetweil @deemedia
                                      @deemedia and xwindows is running?
                                        deemedia @sdetweil
                                        xwindows
                                        I did not try xwindows, I am a weak user
                                          sdetweil @deemedia
                                          @deemedia sorry, not sure I understand. Is the graphical desktop running, looks like windows. Use a mouse to launch applications from the menu bar
                                            deemedia @sdetweil
                                            н
                                            no desktop no. installed Amdebian, without a graphical interface. I tried Ubuntu 15.04 mate desktop and also does not work.
