    Orange PI
    27 Posts 6 Posters 15.3k Views 5 Watching
      bhepler Module Developer
      The Orange Pi website states that it can run Ubuntu, so it should be possible to run the Magic Mirror framework on it. You’ll want to follow the instructions for a manual install - don’t use the script as it is designed specifically for the RasPi.
      I’m doing something similar now with a NanoPC-T4. It installs like a champ (I’m having other issues).
        deemedia @sdetweil
          deemedia @sdetweil
          I tried installation on Armbian. I do not know what to do next, how to solve the startup problem
          pi@orangepione:~$ npm start
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/.npm/_logs/2019-04-20T06_03_50_330Z-debug.log
            MadScientist
            You have to execute npm startin the MagicMirror directory, not in the home directory of your user pi. E.g. do cd MagicMirror (or /home/pi/MagicMirroror whatever your MM directory is) and then run npm start.
              deemedia
              Installation on the Armbian in manual mode ended in error. I do not know how to solve the problem start. There is who knows options:face_with_cold_sweat: :loudly_crying_face:
              /home/admin/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
              npm ERR! file sh
              npm ERR! code ELIFECYCLE
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.7.1 start script.
              npm ERR!     /home/admin/.npm/_logs/2019-04-23T17_59_43_024Z-debug.log
                deemedia
                Someone installed it on the Orange Pi one? can you please give instructions
                  sdetweil @deemedia
                  @deemedia libgtk-3.so.0
                  U need to install libgtk
                  See https://askubuntu.com/questions/1091101/error-libgtk-3-so-0-not-installed-even-though-its-in-usr-lib-x86-64-linux-gnu
                    sharmstr Project Sponsor @sdetweil
                    @sdetweil My jetson nano arrived a few days ago. I bought it for this purpose. Glad to hear it worked for you.
                      sdetweil @sharmstr
                      @sharmstr I installed Ubuntu 18.04, then mm without problem. Will be working on MMM-Hotword and MMM-Assistantmk2 when I get the chance. Need to move my webcam over
                      I could not boot a 64gig SD card. Only up to 32gifg
                        deemedia
                        On the way to launch. And again a mistake. I will soon throw out this Orange PI :face_with_steam_from_nose:
                        How to solve it?:dizzy_face:
                        (electron:4035): Gtk-WARNING **: cannot open display: :0
                        npm ERR! errno 1
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! This is probably not a problem with npm. There is likely additional log                ging output above.
                        npm ERR!     /home/admin/.npm/_logs/2019-04-24T05_47_37_255Z-debug.log
                          deemedia @sdetweil
                          @sdetweil said in Orange PI:
                          жно установить libgtk
                          Thanks, it helped. But now another problem
                            deemedia
                            Maybe someone has a ready image to install on a memory card and run without these tambourines.
                            ready to donate, for a working image on Orange Pi One
                              sdetweil @deemedia
                              @deemedia you are running a graphical user interface, right? Some desktop. U must
                              Also, are you trying this over vnc?
                              Display 0 is the main UI on the device
                                deemedia @sdetweil
                                VNC
                                No, not VNC, directly from the device
                                  sdetweil @deemedia
                                  @deemedia and xwindows is running?
                                    deemedia @sdetweil
                                    xwindows
                                    I did not try xwindows, I am a weak user
                                      sdetweil @deemedia
                                      @deemedia sorry, not sure I understand. Is the graphical desktop running, looks like windows. Use a mouse to launch applications from the menu bar
                                        deemedia @sdetweil
                                        н
                                        no desktop no. installed Amdebian, without a graphical interface. I tried Ubuntu 15.04 mate desktop and also does not work.
                                          sdetweil @deemedia
                                          @deemedia must have graphical ui. Browser requires it. that is why the display 0 error
                                          D 2 Replies Last reply Reply Quote 1
                                            deemedia @sdetweil
                                            what system should I put under this piece of iron to start. Thank you so much for helping.:folded_hands:
