    Orange PI
    27 Posts 6 Posters 13.5k Views 5 Watching
      deemedia @sdetweil
      I tried installation on Armbian. I do not know what to do next, how to solve the startup problem
      pi@orangepione:~$ npm start
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2019-04-20T06_03_50_330Z-debug.log
        MadScientist
        You have to execute npm startin the MagicMirror directory, not in the home directory of your user pi. E.g. do cd MagicMirror (or /home/pi/MagicMirroror whatever your MM directory is) and then run npm start.
          deemedia
          Installation on the Armbian in manual mode ended in error. I do not know how to solve the problem start. There is who knows options:face_with_cold_sweat: :loudly_crying_face:
          /home/admin/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
          npm ERR! file sh
          npm ERR! code ELIFECYCLE
          npm ERR! errno ENOENT
          npm ERR! syscall spawn
          npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
          npm ERR! spawn ENOENT
          npm ERR!
          npm ERR! Failed at the magicmirror@2.7.1 start script.
          npm ERR!     /home/admin/.npm/_logs/2019-04-23T17_59_43_024Z-debug.log
            deemedia
            Someone installed it on the Orange Pi one? can you please give instructions
              sdetweil @deemedia
              @deemedia libgtk-3.so.0
              U need to install libgtk
              See https://askubuntu.com/questions/1091101/error-libgtk-3-so-0-not-installed-even-though-its-in-usr-lib-x86-64-linux-gnu
                sharmstr Project Sponsor @sdetweil
                @sdetweil My jetson nano arrived a few days ago. I bought it for this purpose. Glad to hear it worked for you.
                  sdetweil @sharmstr
                  @sharmstr I installed Ubuntu 18.04, then mm without problem. Will be working on MMM-Hotword and MMM-Assistantmk2 when I get the chance. Need to move my webcam over
                  I could not boot a 64gig SD card. Only up to 32gifg
                    deemedia
                    On the way to launch. And again a mistake. I will soon throw out this Orange PI :face_with_steam_from_nose:
                    How to solve it?:dizzy_face:
                    (electron:4035): Gtk-WARNING **: cannot open display: :0
                    npm ERR! errno 1
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! This is probably not a problem with npm. There is likely additional log                ging output above.
                    npm ERR!     /home/admin/.npm/_logs/2019-04-24T05_47_37_255Z-debug.log
                      deemedia @sdetweil
                      @sdetweil said in Orange PI:
                      жно установить libgtk
                      Thanks, it helped. But now another problem
                        deemedia
                        Maybe someone has a ready image to install on a memory card and run without these tambourines.
                        ready to donate, for a working image on Orange Pi One
