    Orange PI
    27 Posts 6 Posters 15.3k Views 5 Watching
      deemedia
      Someone installed it on the Orange Pi one? can you please give instructions
        sdetweil @deemedia
        @deemedia libgtk-3.so.0
        U need to install libgtk
        See https://askubuntu.com/questions/1091101/error-libgtk-3-so-0-not-installed-even-though-its-in-usr-lib-x86-64-linux-gnu
          sharmstr Project Sponsor @sdetweil
          @sdetweil My jetson nano arrived a few days ago. I bought it for this purpose. Glad to hear it worked for you.
            sdetweil @sharmstr
            @sharmstr I installed Ubuntu 18.04, then mm without problem. Will be working on MMM-Hotword and MMM-Assistantmk2 when I get the chance. Need to move my webcam over
            I could not boot a 64gig SD card. Only up to 32gifg
              deemedia
              On the way to launch. And again a mistake. I will soon throw out this Orange PI :face_with_steam_from_nose:
              How to solve it?:dizzy_face:
              (electron:4035): Gtk-WARNING **: cannot open display: :0
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.7.1 start script.
              npm ERR! This is probably not a problem with npm. There is likely additional log                ging output above.
              npm ERR!     /home/admin/.npm/_logs/2019-04-24T05_47_37_255Z-debug.log
                deemedia @sdetweil
                @sdetweil said in Orange PI:
                жно установить libgtk
                Thanks, it helped. But now another problem
                  deemedia
                  Maybe someone has a ready image to install on a memory card and run without these tambourines.
                  ready to donate, for a working image on Orange Pi One
                    sdetweil @deemedia
                    @deemedia you are running a graphical user interface, right? Some desktop. U must
                    Also, are you trying this over vnc?
                    Display 0 is the main UI on the device
                      deemedia @sdetweil
                      VNC
                      No, not VNC, directly from the device
                        sdetweil @deemedia
                        @deemedia and xwindows is running?
                          deemedia @sdetweil
                          xwindows
                          I did not try xwindows, I am a weak user
                            sdetweil @deemedia
                            @deemedia sorry, not sure I understand. Is the graphical desktop running, looks like windows. Use a mouse to launch applications from the menu bar
                              deemedia @sdetweil
                              н
                              no desktop no. installed Amdebian, without a graphical interface. I tried Ubuntu 15.04 mate desktop and also does not work.
                                sdetweil @deemedia
                                @deemedia must have graphical ui. Browser requires it. that is why the display 0 error
                                D 2 Replies Last reply Reply Quote 1
                                  deemedia @sdetweil
                                  what system should I put under this piece of iron to start. Thank you so much for helping.:folded_hands:
                                    deemedia @sdetweil
                                    Suit this ubuntu_lxde_desktop_For_OrangePi_One
                                      sdetweil @deemedia
                                      @deemedia pick one to match your hardware version.
                                      Ubuntu desktop
                                      http://www.orangepi.org/downloadresources/
                                        A Former User @sdetweil
                                        I’ve tested on my Jetson Nano (Ubuntu 18.04 / node 10.15.3 / npm 6.4.1). And building without problem. But not tested on real usage because I should wait a new DC Power (USB powered Jetson Nano is too weak to handle several USB peripherals. :D )
                                          sdetweil @Guest
                                          @Sean yeh, that device needs some serious power
                                            bhepler Module Developer
                                            Update: NanoPC T4 is a pretty good platform. The graphics aren’t quite what I had hoped. MMM-Globe (the pretty abstract one) isn’t very smooth. I did find that if the screen is in landscape mode it performs better than portrait mode. But even landscape isn’t smooth enough for my tastes. Next round of testing will be with MMM-AssistantMk2 and MMM-Hotword.
                                            Oh, and the thing is hot to the touch. It comes with a heatsink and it’s painfully hot after a couple minutes.
