    MMM-PIR or MMM-PIR-Sensor issues...
    17 Posts 7 Posters 8.0k Views 8 Watching
    • O Offline
      onis_uk
      Hi all, I’ve been building in the background for some time now but I’ve come across a problem trying to install a PIR.
      My MM project all set up and running great, but I wanted to turn off the display with either of the above PIR modules and I’ve come across some issues.
      When I add this code to my config.js after installing MMM-PIR-Sensor
      	module: 'MMM-PIR-Sensor',
      		     sensorPin: 14,
      		     powerSaving: true,
      	             powerSavingDelay: 40,
      My MM won’t load, I get a white screen which says;
      “localhost refused to connect”
      ERR_CONNECTION_REFUSED
      I’ve followed the install exactly and can’t see what’s going wrong!
      cheers onis
      • O Offline
        onis_uk
        • O Offline
          onis_uk
          Fixed it by running a script outside the modules using this method!
          https://github.com/cowboysdude/Pir-Sensor
          cheers
          onis
            MacMirror
            Hi Onis, I got the module running without a script. Did you add the user to the GPIO group and executed the command for turning the HDMI on/off?
            • cowboysdudeC Offline
              cowboysdude Module Developer @onis_uk
              @onis_uk what’s funny is that I cannot get it work any longer… since Buster came out and I upgraded it turns off but not back on…LOL
                sdetweil @cowboysdude
                @cowboysdude someone had to add a parm to the command
                Either way, i found another way which is using the command 'vcgencmd display_power 0 2' and
                'vcgencmd display_power 1 2'
                where the 0 stands for Off and 1 stands for On and the 2 stands for my display ID.
                cowboysdudeC 2 Replies Last reply Reply Quote 1
                  cowboysdude Module Developer @sdetweil
                  @sdetweil Thank you!! Been looking all day… gonna try this right now!
                    @sdetweil My old Pir Sensor does not work at all on Buster.
                      @cowboysdude eh?
                        @sdetweil if u ssh in do the two commands work?
                          IN case anyone is still looking for a way to do this since they updated the PI4 it’s easier:
                          You can use 1 of 2 methods here:
                          or [even better solution IMO]
                          https://github.com/bugsounet/MMM-NewPIR
                          bugsounetB 1 Reply Last reply Reply Quote 0
                          • bugsounetB Offline
                            bugsounet Banned @cowboysdude
                            @cowboysdude
                            • Thanks to don’t to advertise any of my modules on this forum
                            • Thanks to not offer any support of my modules on this forum
                            I repeat again (again, again ?):
                            • I am not a reference in this forum
                            • I’m a VERY BAD guys in this forum
                            • That’s why any of my modules is not on the 3rd party modules
                            S FoziF 2 Replies Last reply Reply Quote 0
                              sdetweil @bugsounet
                              @bugsounet said in MMM-PIR or MMM-PIR-Sensor issues...:
                              only because you choose it to be that way.
                                bugsounet Banned @sdetweil
                                @sdetweil sure and i assume it :)
                                [and i will continue… on this way there]
                                • FoziF Offline
                                  Fozi Project Sponsor @bugsounet
                                  …and in your own forum, too.
                                    bugsounet Banned @Fozi
                                    @fozi I know… and I don’t know how code something and blah blah blah …
                                      Mykle1 Project Sponsor Module Developer @bugsounet
                                      Gee, I’ve missed this place.
                                      No, really.
