    Looking for Beta-testers!
    Scheduled Pinned Locked Moved MagicMirror
    56 Posts 17 Posters 68.6k Views 18 Watching
    • K
      kckndrgn
      I am now on the development branch.
      I have verified that the changes fixed my “blank screen” with the language set in the config file.
      Thanks!
      • MichMichM
        MichMich
        Update: More detailed error message in case config file couldn’t be loaded.
        Please let me know if this works for you.
        PR: https://github.com/MichMich/MagicMirror/pull/391#issuecomment-237919625
        • MichMichM
          MichMich
          Please test the following PR:
          https://github.com/MichMich/MagicMirror/pull/416
          It’s merged into the current develop branch. If you are on the develop branch, please use git pull to update to the latest version.
          Thanks!
            Bangee Module Developer
            I’m now on the latest DEV version.
            I had some problems to run it with my PIR Sensor.
            this command helps to run it:
            npm rebuild --runtime=electron-prebuilt --target=0.37.8 --disturl=https://atom.io/download/atom-shell --build-from-source
            IpWithelist:
            I’ve added my Subnet to de Withelist, but I can’t access my MagicMirror using a browser:
            This device is not allowed to access your mirror.
            Please check your config.js or config.js.sample to change this.
            Would it be possible to add something like “Your IP-Adress: 192.168.0.99”?
            ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", ["192.168.0.99", "192.168.0.254"]],
            This sould add a range from 192.168.0.99-192.168.0.254, or am I wrong?
            Thanks for your help.
            • MichMichM
              MichMich
              @bangee: Check your node log. It should tell you which IP is trying to access the server. Good idea to add it to the “access denied” message. Will put it on my todo list. (PR is welcome!)
                @MichMich Thank you. I’ve had to update my config:
                the Log told me:
                Access denied to IP address: ::ffff:192.168.0.99
                It works with this:
                ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.1/24", "192.168.0.1/24"],
                  Jopyth Moderator @MichMich
                  My mirror is now also running the development version, and I am experiencing restarts more often than before. I guess it is related to # 150 since there is no error in the log. Anyway I saw this twice yesterday, but this might just be something with a newer electron version, so maybe nothing we can fix. It is still a little bit annoying.
                  @MichMich By the way, do you have any particular date in mind for the release?
                  • MichMichM
                    MichMich
                    No, can’t give you an ETA.
                    Keep me posted on the restart issue.
                      I am a little bit in the dark on the restart issue. It happens every time I change any file in my source code directory, i.e. config/config.js or even package.json.
                      All I have so far, is this appeared after I updated to development branch (hence updated all npm dependencies), plus I had to update my PIR-Sensor module (got a version XX expected, got XX error), and rebuild dependencies there also.
                      Does anyone have any idea on this? And is anyone else even seeing this behavior also? If I have time, I will try a complete reinstall and see if that fixes it.
                      • MichMichM
                        MichMich
                        Arent you running any tool that watches your directory and restarts? Like nodemon or pm2?
                          Jopyth Moderator
                          I am using pm2 but watch & reload was disabled.
                          I did a complete update, which apparently helped people before with #150, that seems to have fixed it:
                          sudo apt-get update
                          sudo apt-get upgrade
                          sudo apt-get dist-upgrade
                          sudo apt-get clean
                          sudo rpi-update
                          • G
                            gismo2006
                            @Jopyth some time ago my mirror suddenly didn’t work whit pm2. From one day to the other. I changed nothing and it works fine before. I didn’t know what happens. But then I found a little order in the display when I prompt pm2 start mm… I didn’ t rember the order but I know pm2 worked some second displayed something and then everything works fine again. …
                            Maybe you found something , too
                            Greets gismo
                            • MichMichM
                              MichMich
                              Guys, I’ve just made a modification that hides a region if all modules in a region are hidden. This should prevent unwanted margins when a region (like the top_bar) only contains hidden modules. This allows my to move the updatenotification module to the topbar.
                              Due to the nature of the change, this could cause some serious issues if it contains any missed bugs. It would be great if you guys gan pull the latest version and let me know if everything keeps working. If you’re having issues with some modules not showing up, please let me know.
                              More info about this change can be found here: https://github.com/MichMich/MagicMirror/commit/e4197012f65778f815cd73a6c7fab1a30ef3b92f
                              Thanks!
                              • E
                                ESOB @MichMich
                                @MichMich I am on the latest develop and it throws an error and just gives me a black screen:
                                > magicmirror@2.1.1 start /home/pi/MagicMirror
                                > sh run-start.sh
                                Starting MagicMirror: v2.1.1
                                Loading config ...
                                App threw an error during load
                                TypeError: Path must be a string. Received undefined
                                    at assertPath (path.js:7:11)
                                    at Object.resolve (path.js:1148:7)
                                    at loadConfig (/home/pi/MagicMirror/js/app.js:53:29)
                                    at App.start (/home/pi/MagicMirror/js/app.js:180:3)
                                    at Object. (/home/pi/MagicMirror/js/electron.js:102:6)
                                    at Module._compile (module.js:556:32)
                                    at Object.Module._extensions..js (module.js:565:10)
                                    at Module.load (module.js:473:32)
                                    at tryModuleLoad (module.js:432:12)
                                    at Function.Module._load (module.js:424:3)
                                Launching application.
                                When I jump back to Master branch it loads fine:
                                //your code> magicmirror@2.1.0 start /home/pi/MagicMirror
                                > electron js/electron.js
                                Starting MagicMirror: v2.1.0
                                Loading config ...
                                Loading module helpers ...
                                All module helpers loaded.
                                Starting server op port 8080 ...
                                Server started ...
                                Connecting socket for: MMM-Remote-Control
                                Starting node helper for: MMM-Remote-Control
                                Connecting socket for: MMM-Traffic
                                MMM-Traffic helper started ...
                                Connecting socket for: MMM-WunderGround
                                MMM-WunderGround helper started ...
                                Connecting socket for: MMM-NFL
                                Starting module: MMM-NFL
                                Starting module: newsfeed
                                ERROR! Could not find main module js
                                • SnilleS
                                  Snille Module Developer
                                  Hi there, got the same problem… It’s time for bed anyway. :)
                                    roramirez Core Contributors
                                    So… that is my mistake. I pushed fix the wrong validation :(
                                    https://github.com/MichMich/MagicMirror/pull/658
                                    • MichMichM
                                      MichMich
                                      I’ve just merged the fix!👍
                                      • SnilleS
                                        Working. :)
                                        • X
                                          XxX_Cobra_XxX
                                          @MichMich I have the same problem as ESOB:
                                          I am now also on the latest develop and it throws an error and just gives me a black screen:
                                          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'rrule-alt'
                                              at Module._resolveFilename (module.js:455:15)
                                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                              at Function.Module._load (module.js:403:25)
                                              at Module.require (module.js:483:17)
                                              at require (internal/module.js:20:19)
                                              at Object. (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:20:13)
                                          { Error: Cannot find module 'rrule-alt'
                                              at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
                                          When I go back to Master branch it loads normally.
                                          Please help me
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @XxX_Cobra_XxX
                                            @XxX_Cobra_XxX did you install the dependencies? they have changed for the develop branch
                                            X 1 Reply Last reply Reply Quote 0
                                            • 2 / 3
