    Looking for Beta-testers!
    Scheduled Pinned Locked Moved MagicMirror
    56 Posts 17 Posters 63.4k Views 18 Watching
    • MichMichM Offline
      MichMich
      Update: More detailed error message in case config file couldn’t be loaded.
      Please let me know if this works for you.
      PR: https://github.com/MichMich/MagicMirror/pull/391#issuecomment-237919625
      • MichMichM Offline
        MichMich
        Please test the following PR:
        https://github.com/MichMich/MagicMirror/pull/416
        It’s merged into the current develop branch. If you are on the develop branch, please use git pull to update to the latest version.
        Thanks!
        • BangeeB Offline
          Bangee Module Developer
          I’m now on the latest DEV version.
          I had some problems to run it with my PIR Sensor.
          this command helps to run it:
          npm rebuild --runtime=electron-prebuilt --target=0.37.8 --disturl=https://atom.io/download/atom-shell --build-from-source
          IpWithelist:
          I’ve added my Subnet to de Withelist, but I can’t access my MagicMirror using a browser:
          This device is not allowed to access your mirror.
          Please check your config.js or config.js.sample to change this.
          Would it be possible to add something like “Your IP-Adress: 192.168.0.99”?
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", ["192.168.0.99", "192.168.0.254"]],
          This sould add a range from 192.168.0.99-192.168.0.254, or am I wrong?
          Thanks for your help.
          • MichMichM Offline
            MichMich
            @bangee: Check your node log. It should tell you which IP is trying to access the server. Good idea to add it to the “access denied” message. Will put it on my todo list. (PR is welcome!)
            • BangeeB Offline
              @MichMich Thank you. I’ve had to update my config:
              the Log told me:
              Access denied to IP address: ::ffff:192.168.0.99
              It works with this:
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.1/24", "192.168.0.1/24"],
                Jopyth Moderator @MichMich
                My mirror is now also running the development version, and I am experiencing restarts more often than before. I guess it is related to # 150 since there is no error in the log. Anyway I saw this twice yesterday, but this might just be something with a newer electron version, so maybe nothing we can fix. It is still a little bit annoying.
                @MichMich By the way, do you have any particular date in mind for the release?
                • MichMichM Offline
                  MichMich
                  No, can’t give you an ETA.
                  Keep me posted on the restart issue.
                    I am a little bit in the dark on the restart issue. It happens every time I change any file in my source code directory, i.e. config/config.js or even package.json.
                    All I have so far, is this appeared after I updated to development branch (hence updated all npm dependencies), plus I had to update my PIR-Sensor module (got a version XX expected, got XX error), and rebuild dependencies there also.
                    Does anyone have any idea on this? And is anyone else even seeing this behavior also? If I have time, I will try a complete reinstall and see if that fixes it.
                    • MichMichM Offline
                      MichMich
                      Arent you running any tool that watches your directory and restarts? Like nodemon or pm2?
                        Jopyth Moderator
                        I am using pm2 but watch & reload was disabled.
                        I did a complete update, which apparently helped people before with #150, that seems to have fixed it:
                        sudo apt-get update
                        sudo apt-get upgrade
                        sudo apt-get dist-upgrade
                        sudo apt-get clean
                        sudo rpi-update
                        • G Offline
                          gismo2006
                          @Jopyth some time ago my mirror suddenly didn’t work whit pm2. From one day to the other. I changed nothing and it works fine before. I didn’t know what happens. But then I found a little order in the display when I prompt pm2 start mm… I didn’ t rember the order but I know pm2 worked some second displayed something and then everything works fine again. …
                          Maybe you found something , too
                          Greets gismo
                          • MichMichM Offline
                            MichMich
                            Guys, I’ve just made a modification that hides a region if all modules in a region are hidden. This should prevent unwanted margins when a region (like the top_bar) only contains hidden modules. This allows my to move the updatenotification module to the topbar.
                            Due to the nature of the change, this could cause some serious issues if it contains any missed bugs. It would be great if you guys gan pull the latest version and let me know if everything keeps working. If you’re having issues with some modules not showing up, please let me know.
                            More info about this change can be found here: https://github.com/MichMich/MagicMirror/commit/e4197012f65778f815cd73a6c7fab1a30ef3b92f
                            Thanks!
                            • E Offline
                              ESOB @MichMich
                              @MichMich I am on the latest develop and it throws an error and just gives me a black screen:
                              > magicmirror@2.1.1 start /home/pi/MagicMirror
                              > sh run-start.sh
                              Starting MagicMirror: v2.1.1
                              Loading config ...
                              App threw an error during load
                              TypeError: Path must be a string. Received undefined
                                  at assertPath (path.js:7:11)
                                  at Object.resolve (path.js:1148:7)
                                  at loadConfig (/home/pi/MagicMirror/js/app.js:53:29)
                                  at App.start (/home/pi/MagicMirror/js/app.js:180:3)
                                  at Object. (/home/pi/MagicMirror/js/electron.js:102:6)
                                  at Module._compile (module.js:556:32)
                                  at Object.Module._extensions..js (module.js:565:10)
                                  at Module.load (module.js:473:32)
                                  at tryModuleLoad (module.js:432:12)
                                  at Function.Module._load (module.js:424:3)
                              Launching application.
                              When I jump back to Master branch it loads fine:
                              //your code> magicmirror@2.1.0 start /home/pi/MagicMirror
                              > electron js/electron.js
                              Starting MagicMirror: v2.1.0
                              Loading config ...
                              Loading module helpers ...
                              All module helpers loaded.
                              Starting server op port 8080 ...
                              Server started ...
                              Connecting socket for: MMM-Remote-Control
                              Starting node helper for: MMM-Remote-Control
                              Connecting socket for: MMM-Traffic
                              MMM-Traffic helper started ...
                              Connecting socket for: MMM-WunderGround
                              MMM-WunderGround helper started ...
                              Connecting socket for: MMM-NFL
                              Starting module: MMM-NFL
                              Starting module: newsfeed
                              ERROR! Could not find main module js
                              • SnilleS Offline
                                Snille Module Developer
                                Hi there, got the same problem… It’s time for bed anyway. :)
                                If you cant find it, make it and share it!
                                Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                                  roramirez Core Contributors
                                  So… that is my mistake. I pushed fix the wrong validation :(
                                  https://github.com/MichMich/MagicMirror/pull/658
                                  • MichMichM Offline
                                    MichMich
                                    I’ve just merged the fix!👍
                                    • SnilleS Offline
                                      Working. :)
                                      • X Offline
                                        XxX_Cobra_XxX
                                        @MichMich I have the same problem as ESOB:
                                        I am now also on the latest develop and it throws an error and just gives me a black screen:
                                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'rrule-alt'
                                            at Module._resolveFilename (module.js:455:15)
                                            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                            at Function.Module._load (module.js:403:25)
                                            at Module.require (module.js:483:17)
                                            at require (internal/module.js:20:19)
                                            at Object. (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:20:13)
                                        { Error: Cannot find module 'rrule-alt'
                                            at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
                                        When I go back to Master branch it loads normally.
                                        Please help me
                                        • strawberry 3.141S Offline
                                          strawberry 3.141 Project Sponsor Module Developer @XxX_Cobra_XxX
                                          @XxX_Cobra_XxX did you install the dependencies? they have changed for the develop branch
                                          X 1 Reply Last reply Reply Quote 0
                                          • X Offline
                                            XxX_Cobra_XxX @strawberry 3.141
                                            @strawberry-3.141 I have installed the dependencies now with ‘npm install’ and it works! ;-)
                                            Thank you very much
                                            • 2 / 3
