    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 944.5k Views 74 Watching
    • LordyL
      Lordy @TyFusion
      @TyFusion said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
      MMM-DarkSkyForecast
      Installation
      1)Navigate into your MagicMirror modules folder and execute
      git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git.
      2)Enter the new MMM-DarkSkyForecast directory and execute npm install.                                                       3) reboot
      Did you follow these instructions?
      • T
        ttarzan @TyFusion
        @TyFusion I think you have to exchange the decimal point for a dot at latitude.
        Try “latitude: “39.462900”,”
        LordyL 1 Reply Last reply
        • LordyL
          Lordy @ttarzan
          @ttarzan
          You might be right, I overlook that tonight.
          • drippyerD
            drippyer
            Just wanted to let folks know that DarkSky is no longer accepting new users to the API now that they have been acquired by Apple.
            Cr4z33C 1 Reply Last reply
              Yeah… not sure what I’m going to do about this yet… Need to rewrite my weather module AGAIN due to API going belly-up. Any suggestions on a good, free API?
              H M 2 Replies Last reply
              • H
                Hadr1en Project Sponsor @j.e.f.f
                @j-e-f-f maybe try yr.no ? it’s free :)
                J 1 Reply Last reply
                • N
                  numb3rs
                  https://openweathermap.org/api
                    j.e.f.f Project Sponsor Module Developer @Hadr1en
                    @Hadr1en @numb3rs Thanks! Will look into both of these.
                    T 1 Reply Last reply
                    • T
                      trividar @j.e.f.f
                      @j-e-f-f it is possible to use animated icons (4c) for the main icon?
                        PH1TCH
                        @j-e-f-f Great module, definitely my favorite weather module so far!
                        2 things would make it perfect in my opinion: Feels like temperature and sunrise/sunset data.
                        Do you have any plans to add those in the future?
                        Thank You!
                          michaelsfp @j.e.f.f
                          @j-e-f-f The best replacement for DarkSky that I’ve found is https://www.climacell.co/weather-api/ since its hyper-local. Free tier gets you 30,000 calls/month.
                          lavolp3L 1 Reply Last reply
                          • Cr4z33C
                            Cr4z33 @drippyer
                            @drippyer said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                            Maybe I shouldn’t say it, but… you can find many working DarkSky API codes around (that can be used simultaneously by more than one user).
                            Just do a proper search in Google Images and here you go. 😂
                            • lavolp3L
                              lavolp3 Module Developer @michaelsfp
                              @michaelsfp said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                              This one sounds really interesting! Thanks! Seems to have minutely data for Europe as well which is rare.
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              • Feedy88F
                                Feedy88
                                OpenWeatherMaps now introduced a new OneCall-API which is similar to the old DarkSky. There is even a table for migrating from DarkSky to OpenWeather. Maybe someone who has coding skills could see rebuild this lovely module? In the end Dark Sky API will be discontinued completely so everyone will need to look out for something else :)
                                  solei
                                  @michael5r What is the command line that allows me to reduce the spaces in the “forescast” table?
                                  cual es la linea de comando que me permite reducir los espacios en la tabla de “forescast”?
                                    sdetweil @lavolp3
                                    @lavolp3 @Mykle1 has converted one of his weather modules to climacell.
                                    I have converted weather on another platform too.
                                      mm_mtl
                                      I am having issue it says LOADING…
                                      here is my config
                                      module: “MMM-DarkSkyForecast”,
                                      header: “Weather”,
                                      position: “top_right”,
                                      classes: “default everyone”,
                                      disabled: false,
                                      apikey: " from climacell*",
                                      latitude: “45.582152”,
                                      longitude: “-73.584595”,
                                      iconset: “4c”,
                                      concise: false,
                                      forecastLayout: “table”
                                      please help :(
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @mm_mtl
                                        @mm_mtl
                                        You can’t use a Climacell API key with MMM-DarkSkyForecast.
                                          mm_mtl @Mykle1
                                          @Mykle1
                                          any other key I can use ?
                                          • Mykle1M
                                            @mm_mtl
                                            Each module has directions on how to acquire the proper API, or it should. Darksky requires a Darksky API key but they no longer issue free keys. You would have to purchase one in that case. Free Climacell API keys work with modules utilizing Climacell data, and so forth, and so on. You already have a Climacell key. That will work with modules using Climacell data
                                            Please refer to the readme file of each module you wish to use
                                            BKeyportB 1 Reply Last reply
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
