    Fresh Install
    49 Posts 6 Posters 22.6k Views 6 Watching
      @sdetweil needs to be /boot/config.txt
        sdetweil @johnnyboy
        @johnnyboy # is a comment, so whatever is after # on that line is ignored
        johnnyboyJ 1 Reply Last reply Reply Quote 0
        • johnnyboyJ Offline
          johnnyboy @sdetweil
          Yeah… the text that says " File name to write: /boot/config.tx"
          That is hard written in grey… below that it gives options… G get help C cancel M-D Dos Format M-M Mac format M-A Append M-P Prepend M-B Backup file ^ to files
            sdetweil @johnnyboy
            @johnnyboy yes, just confirming the filename, you can change it if u need to… you can edit a NEW file and have NO name specified in advance…
              johnnyboy @sdetweil
              @sdetweil said in Fresh Install:
              So how do i proceed? If I click ^cancel, i go back to my entry… then as soon as i click ^o to save, it goes to thst part that says file name…
              I cannot save and exit past there.
              I cannot hit ^x to exit as it wont work there… as if i need to select an option from the boxes below… I can only select ^c to cancel and go back.
                sdetweil @johnnyboy
                @johnnyboy you hit enter
                then it saves the file
                then u hit ctrl-x to exit the editor
                  johnnyboy @sdetweil
                  Ok… but I just re-booted… then back into terminal… back into boot config.txt… and there is display_rotate=1 right at very top of the config.txt window in terminal…
                  I also looked into File Manager - Boot - and see there is another 2 x saved copys of config.txt docs…
                  So it seems it did save, but not executed to portrait on re-boot?
                    sdetweil @johnnyboy
                    @johnnyboy ok, I can’t help with that. I searched for instructions and passed them along… I don’t have any portrait on pi… I do on ubuntu, but they have a UI that does it live… click, push a button
                      display_rotate=1
                      Isn’t display_rotate=1 landscape? Wouldn’t portrait be display_rotate=0?
                      scratching my head
                        sdetweil @Mykle1
                        @Mykle1 pages says
                          My bad. Senior moment. :-)
                            johnnyboy @Mykle1
                            @Mykle1
                            😔… oh well… my new lease of life with my MM was very short lived.
                            My mirror is fixed in portrait… so having the system in Lanscape is of no use to me at all.
                            Surely not every user here is using MM in Landscape?
                              sdetweil @johnnyboy
                              @johnnyboy no… just that we TWO don’t know how to fix it…
                                johnnyboy @sdetweil
                                Ok… well can only thank you for your great help on this… at least I have an updated Pi.
                                Should I start a new thread asking about portrait mode? Doubt everyone is reading this thread and would comment on how to achieve that?
                                  sdetweil @johnnyboy
                                  @johnnyboy updated pi? did u use my upgrade script?
                                    johnnyboy @sdetweil
                                    Ahhhhhhh… no, only the install… i shall go and see the upgrade script now.
                                      sdetweil @johnnyboy
                                      @johnnyboy install is for new, upgrade is for previous installed, get to latest
                                      so you would have to rename the folders back before trying
                                      we have a version update every 3 months… you can imagine the trouble folks run into
                                        johnnyboy @sdetweil
                                        Yeah, I renamed original MM folder, and just started afresh with your Install script to give me a fresh start… just incase there were any bits that would take forever to find, then fix, on old MM…
                                        just done the upgrade before seeing your reply, and obviously it reported that no modules found needing npm refresh.
                                        Fingers x there is a Portrait fix going about, as cannot afford another build in Landscape mode
                                        • evroomE Offline
                                          evroom @johnnyboy
                                          @johnnyboy said in Fresh Install:
                                          Please read this thread:
                                          https://forum.magicmirror.builders/topic/9730/led-monitor-vertical-setup-how?_=1591998940597
                                          Perhaps it helps .
                                          MagicMirror version: 2.37.0
                                          • BKeyportB Offline
                                            BKeyport Module Developer
                                            You may have to use the display utility within the desktop manager. see here: https://pimylifeup.com/raspberry-pi-rotate-screen/
                                            johnnyboyJ 1 Reply Last reply Reply Quote 1
                                            • 2 / 3
