    Fresh Install
    49 Posts 6 Posters 24.1k Views 6 Watching
      sdetweil @BKeyport
      @BKeyport he has a some mods… so, trying to help get it up and running and find them
      • johnnyboyJ
        johnnyboy @sdetweil
        @sdetweil said in Fresh Install:
        @johnnyboy said in Fresh Install:
        udonano/boot/config.txt
        always a space between command and path
        sudo nano /boot/config.txt
        Thanks… that got me in… i entered that txt in a space… rebooted… and still in landscape?
        Tried again, entered sudo nano /boot/config.txt … same as you say with spaces… but now the terminal text that wss within the config has gone… and at bottom it says [Directory ‘boot’ does not exist ]
        I then look in the boot folder, and i now have - config.tx… config.txt save 1… config.txt save 2… and config.tct save 3 and within all 3 saved ones, it shows - display_rotate=1
        johnnyboyJ 1 Reply Last reply
        • johnnyboyJ
          johnnyboy @johnnyboy
          @johnnyboy
          Ok… got back in after a reboot… how do i enter display_rotate=1
          Do i find a space and type it in… and how do i save that entry before re-booting?
            sdetweil @johnnyboy
            @johnnyboy hit enter, add a new line, type the text, hit ctrl-o to save, ctrl-x to exit
            • johnnyboyJ
              johnnyboy @sdetweil
              do i enter # before text, same as everything else in there or simply that text on its own?
              johnnyboyJ S 2 Replies Last reply
              • johnnyboyJ
                @johnnyboy
                display_rotate=1
                Then I click on Ctrl o… and it asks "file name to write: boot/config.txt
                  @sdetweil needs to be /boot/config.txt
                    sdetweil @johnnyboy
                    @johnnyboy # is a comment, so whatever is after # on that line is ignored
                    • johnnyboyJ
                      johnnyboy @sdetweil
                      Yeah… the text that says " File name to write: /boot/config.tx"
                      That is hard written in grey… below that it gives options… G get help C cancel M-D Dos Format M-M Mac format M-A Append M-P Prepend M-B Backup file ^ to files
                        sdetweil @johnnyboy
                        @johnnyboy yes, just confirming the filename, you can change it if u need to… you can edit a NEW file and have NO name specified in advance…
                        • johnnyboyJ
                          johnnyboy @sdetweil
                          So how do i proceed? If I click ^cancel, i go back to my entry… then as soon as i click ^o to save, it goes to thst part that says file name…
                          I cannot save and exit past there.
                          I cannot hit ^x to exit as it wont work there… as if i need to select an option from the boxes below… I can only select ^c to cancel and go back.
                            sdetweil @johnnyboy
                            @johnnyboy you hit enter
                            then it saves the file
                            then u hit ctrl-x to exit the editor
                            • johnnyboyJ
                              johnnyboy @sdetweil
                              Ok… but I just re-booted… then back into terminal… back into boot config.txt… and there is display_rotate=1 right at very top of the config.txt window in terminal…
                              I also looked into File Manager - Boot - and see there is another 2 x saved copys of config.txt docs…
                              So it seems it did save, but not executed to portrait on re-boot?
                                sdetweil @johnnyboy
                                @johnnyboy ok, I can’t help with that. I searched for instructions and passed them along… I don’t have any portrait on pi… I do on ubuntu, but they have a UI that does it live… click, push a button
                                • Mykle1M
                                  display_rotate=1
                                  Isn’t display_rotate=1 landscape? Wouldn’t portrait be display_rotate=0?
                                  scratching my head
                                    sdetweil @Mykle1
                                    @Mykle1 pages says
                                    Mykle1M 1 Reply Last reply
                                    • Mykle1M
                                      My bad. Senior moment. :-)
                                      • johnnyboyJ
                                        johnnyboy @Mykle1
                                        @Mykle1
                                        😔… oh well… my new lease of life with my MM was very short lived.
                                        My mirror is fixed in portrait… so having the system in Lanscape is of no use to me at all.
                                        Surely not every user here is using MM in Landscape?
                                          sdetweil @johnnyboy
                                          @johnnyboy no… just that we TWO don’t know how to fix it…
                                          • johnnyboyJ
                                            johnnyboy @sdetweil
                                            Ok… well can only thank you for your great help on this… at least I have an updated Pi.
                                            Should I start a new thread asking about portrait mode? Doubt everyone is reading this thread and would comment on how to achieve that?
                                            • 2 / 3
