    Fresh Install
    49 Posts 6 Posters 22.4k Views 6 Watching
    • johnnyboyJ Offline
      johnnyboy @sdetweil
      @sdetweil said in Fresh Install:
      @johnnyboy yes, just confirming the filename, you can change it if u need to… you can edit a NEW file and have NO name specified in advance…
      So how do i proceed? If I click ^cancel, i go back to my entry… then as soon as i click ^o to save, it goes to thst part that says file name…
      I cannot save and exit past there.
      I cannot hit ^x to exit as it wont work there… as if i need to select an option from the boxes below… I can only select ^c to cancel and go back.
        sdetweil @johnnyboy
        @johnnyboy you hit enter
        then it saves the file
        then u hit ctrl-x to exit the editor
        johnnyboyJ 1 Reply Last reply Reply Quote 0
          johnnyboy @sdetweil
          Ok… but I just re-booted… then back into terminal… back into boot config.txt… and there is display_rotate=1 right at very top of the config.txt window in terminal…
          I also looked into File Manager - Boot - and see there is another 2 x saved copys of config.txt docs…
          So it seems it did save, but not executed to portrait on re-boot?
            sdetweil @johnnyboy
            @johnnyboy ok, I can’t help with that. I searched for instructions and passed them along… I don’t have any portrait on pi… I do on ubuntu, but they have a UI that does it live… click, push a button
              display_rotate=1
              Isn’t display_rotate=1 landscape? Wouldn’t portrait be display_rotate=0?
              scratching my head
                sdetweil @Mykle1
                @Mykle1 pages says
                  My bad. Senior moment. :-)
                    johnnyboy @Mykle1
                    @Mykle1
                    😔… oh well… my new lease of life with my MM was very short lived.
                    My mirror is fixed in portrait… so having the system in Lanscape is of no use to me at all.
                    Surely not every user here is using MM in Landscape?
                      sdetweil @johnnyboy
                      @johnnyboy no… just that we TWO don’t know how to fix it…
                        johnnyboy @sdetweil
                        Ok… well can only thank you for your great help on this… at least I have an updated Pi.
                        Should I start a new thread asking about portrait mode? Doubt everyone is reading this thread and would comment on how to achieve that?
                          sdetweil @johnnyboy
                          @johnnyboy updated pi? did u use my upgrade script?
                            johnnyboy @sdetweil
                            Ahhhhhhh… no, only the install… i shall go and see the upgrade script now.
                              sdetweil @johnnyboy
                              @johnnyboy install is for new, upgrade is for previous installed, get to latest
                              so you would have to rename the folders back before trying
                              we have a version update every 3 months… you can imagine the trouble folks run into
                                johnnyboy @sdetweil
                                Yeah, I renamed original MM folder, and just started afresh with your Install script to give me a fresh start… just incase there were any bits that would take forever to find, then fix, on old MM…
                                just done the upgrade before seeing your reply, and obviously it reported that no modules found needing npm refresh.
                                Fingers x there is a Portrait fix going about, as cannot afford another build in Landscape mode
                                • evroomE Offline
                                  evroom @johnnyboy
                                  @johnnyboy said in Fresh Install:
                                  Please read this thread:
                                  https://forum.magicmirror.builders/topic/9730/led-monitor-vertical-setup-how?_=1591998940597
                                  Perhaps it helps .
                                  MagicMirror version: 2.37.0
                                  • BKeyportB Offline
                                    BKeyport Module Developer
                                    You may have to use the display utility within the desktop manager. see here: https://pimylifeup.com/raspberry-pi-rotate-screen/
                                    johnnyboyJ 1 Reply Last reply Reply Quote 1
                                      johnnyboy @BKeyport
                                      @BKeyport
                                      @evroom
                                      Thanks for your time on this guys…
                                      I saw reply’s on my other post too, so will be getting this done today.
                                      I remember back a couple years when I first did this, that I had to adjust the modules to fit, and adjust screen to edges/frame… so no doubt this will need done again within CSS… but I have a back up of all my folders, so will have these on hand to help with that.
                                      Again, thanks to all for your time… and I will report back on my progress.
                                        johnnyboy @johnnyboy
                                        Just an update as promised.
                                        Erased SD Card and flashed Buster onto it, fresh install of Sam’s script, and all works perfect.
                                        Managed to rotate screen to portrait using display_hdmi_rotate=1 within the boot/ Config.txt
                                        Thanks to everyone who helped me here… really appreciate your time.
                                          RoddyJoff
                                          @sdetwell
                                          Brilliant!
                                          I came across magic mirror about 10 days ago and since then have been struggling to install it without errors or ending up down a rabbit.
                                          I spent hours in containers at the docks, dockers in containers and containers in containers - at one point I thought I was in the Sargasso Sea I was I was making no headway headway.
                                          And then I found this forum I’ve no idea how I missed it before but this script from Sam works a treat and I can’t wait to start configuring.
                                          Do you think I almost went the Dakboard way - shivers!
                                          I have a lot of ideas for my mirror but also I need to learn a lot about it however now that I have such a stable installation says on the box I can’t wait.
                                          Thank you ever so much Sam, I will no doubt be back with more questions.
                                          Regards from a Flixton in the UK.
                                          R S 2 Replies Last reply Reply Quote 0
                                            RoddyJoff @RoddyJoff
                                            @RoddyJoff sorry about the typing!
                                            • 2 / 3
