    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 931.8k Views 74 Watching
      Yeah… not sure what I’m going to do about this yet… Need to rewrite my weather module AGAIN due to API going belly-up. Any suggestions on a good, free API?
      H M 2 Replies Last reply Reply Quote 1
      • H
        Hadr1en Project Sponsor @j.e.f.f
        @j-e-f-f maybe try yr.no ? it’s free :)
        • N
          numb3rs
          https://openweathermap.org/api
            j.e.f.f Project Sponsor Module Developer @Hadr1en
            @Hadr1en @numb3rs Thanks! Will look into both of these.
            • T
              trividar @j.e.f.f
              @j-e-f-f it is possible to use animated icons (4c) for the main icon?
                PH1TCH
                @j-e-f-f Great module, definitely my favorite weather module so far!
                2 things would make it perfect in my opinion: Feels like temperature and sunrise/sunset data.
                Do you have any plans to add those in the future?
                Thank You!
                  michaelsfp @j.e.f.f
                  @j-e-f-f The best replacement for DarkSky that I’ve found is https://www.climacell.co/weather-api/ since its hyper-local. Free tier gets you 30,000 calls/month.
                  lavolp3L 1 Reply Last reply Reply Quote 1
                  • Cr4z33C
                    Cr4z33 @drippyer
                    @drippyer said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                    Just wanted to let folks know that DarkSky is no longer accepting new users to the API now that they have been acquired by Apple.
                    Maybe I shouldn’t say it, but… you can find many working DarkSky API codes around (that can be used simultaneously by more than one user).
                    Just do a proper search in Google Images and here you go. 😂
                    • lavolp3L
                      lavolp3 Module Developer @michaelsfp
                      @michaelsfp said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                      This one sounds really interesting! Thanks! Seems to have minutely data for Europe as well which is rare.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      • Feedy88F
                        Feedy88
                        OpenWeatherMaps now introduced a new OneCall-API which is similar to the old DarkSky. There is even a table for migrating from DarkSky to OpenWeather. Maybe someone who has coding skills could see rebuild this lovely module? In the end Dark Sky API will be discontinued completely so everyone will need to look out for something else :)
                          solei
                          @michael5r What is the command line that allows me to reduce the spaces in the “forescast” table?
                          cual es la linea de comando que me permite reducir los espacios en la tabla de “forescast”?
                            sdetweil @lavolp3
                            @lavolp3 @Mykle1 has converted one of his weather modules to climacell.
                            I have converted weather on another platform too.
                              mm_mtl
                              I am having issue it says LOADING…
                              here is my config
                              module: “MMM-DarkSkyForecast”,
                              header: “Weather”,
                              position: “top_right”,
                              classes: “default everyone”,
                              disabled: false,
                              apikey: " from climacell*",
                              latitude: “45.582152”,
                              longitude: “-73.584595”,
                              iconset: “4c”,
                              concise: false,
                              forecastLayout: “table”
                              please help :(
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @mm_mtl
                                @mm_mtl
                                You can’t use a Climacell API key with MMM-DarkSkyForecast.
                                  mm_mtl @Mykle1
                                  @Mykle1
                                  any other key I can use ?
                                  • Mykle1M
                                    @mm_mtl
                                    Each module has directions on how to acquire the proper API, or it should. Darksky requires a Darksky API key but they no longer issue free keys. You would have to purchase one in that case. Free Climacell API keys work with modules utilizing Climacell data, and so forth, and so on. You already have a Climacell key. That will work with modules using Climacell data
                                    Please refer to the readme file of each module you wish to use
                                    • BKeyportB
                                      BKeyport Module Developer @Mykle1
                                      @Mykle1 They’re not even issuing paid ones. This module is dead to new users as a result.
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @BKeyport
                                        @BKeyport
                                        Yes, if you’re talking about Darksky. We were discussing Climacel as well, which does issue free API keys. But you already knew that, being the head investigator of the MM forum.
                                        • BKeyportB
                                          har har, Mykle. :)
                                          You know if anyone has used Climacel data for a module? That looks really promising… (For now, knowing how weather companies get bought up)
                                            sdetweil @BKeyport
                                            @BKeyport u are joking, right?
                                            MMM-Climacell-Hourly
                                            MMM-BMW-CC
                                            BKeyportB 1 Reply Last reply Reply Quote 1
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
