    690 Posts 77 Posters 3.0m Views 70 Watching
      sdetweil @Lagmin
      @Lagmin edit config.js and set language: to the value u need. note that this is all of mm, some other things will need to be translated.
      • L Offline
        Lagmin
        Thank you, it worked for my other modules.
        For this module I have problem, it is showing only Rise, Daylight and Set. All other are ‘undefined’. Someone knows the solution?
        Here is my config:
           module: 'MMM-NOAA3',
        position: 'top_left',
               provider: "openweather", // From list above
               apiKey: "key",        // From one of the providers listed above
               airKey: "key",
               css: "NOAA4",                   // THIS MUST CONTAIN A CSS STYLE NAME
           userlat: "52.429248", //MUST HAVE BOTH
               userlon: "20.962540"  //MUST HAVE BOTH
          Mykle1 Project Sponsor Module Developer @Lagmin
          @Lagmin said in MMM-NOAA - Another Weather Module:
          Here you go, please update it and by the way, could you please tell me how to implement this language to my MagicMirror module?
          I forwarded to the author. He will add it to the module, at which time, you will have to run git pull in the MMM-NOAA3 directory. Your config language should be language: "pl",
          • cowboysdudeC Offline
            pl file added for Polish translation. Thank you for taking the time to make it. As Mykle1 says do a ‘git pull’ in the MMM-NOAA3 directory.
            • L Offline
              Lagmin
              No problem, not much time. Do you know maybe what can be a solution to my problem showing only 3 results, please?
                Have you installed the dependencies?
                • L Offline
                  Lagmin @Mykle1
                  @Mykle1 Ok, I got it, it is “working”.
                  I used this simple config:
                         provider: "must be in quotes", // From list above
                         apiKey: "YOUR API KEY",        // From one of the providers listed above
                         airKey: "YOUR API KEY",
                         css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
                     userlat: "xxxx", //MUST HAVE BOTH
                         userlon: "xxxx"  //MUST HAVE BOTH
                  But:
                  1. I don’t have % for Humidity, inHg for Pressure…
                  2. How I can translate WIND? I don’t have it in translation file (same for AQI, UV).
                  3. I don’t have forecast for 4 days below.
                  Do you know what can be the problem?
                    @Lagmin
                    I’m guessing that the data is not complete for all locations so you may not see % for Humidity, inHg for Pressure… or that information is not present in the data (for some reason).
                    You can add “Wind” to the translation file of your language and put in the translation. I’ve given an example below. Then send a PR to the author and he will add it to the repo.
                    "Sun":"Sun",
                    "No Wind": "No Wind",
                    "Wind": "Yours",
                    "Humidity": "Humidity",
                      @Lagmin
                      Just spoke with the author. Some of the providers are not supplying the data they once were or they’ve changed the way they provide the data. This module uses several different providers so try another one and see if you get better results.
                      Keeping this module functioning using all the different providers must be a monumental task. It may take a long time for the author to fix any of it, assuming he has the time.
                      • L Offline
                        Lagmin @Mykle1
                        @Mykle1 Well I tried changing coordinates for our capital city of Poland - Warsaw, but it is still not showing forecast. I also tried to change for weatherbit (previously used openweather) but with weatherbit it doesn’t even show forecast - (Prognoza na 4 dni).
                          @Lagmin
                          Yes, understood. I’m using my darksky api key until it is no longer valid. Like you, my OpenWeather api key doesn’t show the 4 day forecast. I spoke with the author and he is extremely busy with work so he doesn’t have much time to troubleshoot his modules. You can fork the repo and fix it if you like. :-)
                            sdetweil @Mykle1
                            @Mykle1 yeh hourly for 4 days, or daily for 7 days are in the openweather free apikey access, but ONLY by using the one all api
                              Yes, I know. I’m using it in my MMM-BMW-OW module. :-)
                                sdetweil @Mykle1
                                @Mykle1 I know. we did it at the same time.
                                was adding info for others
                                  majdzik84 @Pielo
                                  @Pielo how did you make the frame with temperature and humidity? I would like to get something like this by sending data via mqtt
                                    msulzer
                                    Hi everyone, this module looks really great. Is there a possibility not to show certain items such as AQI, UV etc.?
                                      cowboysdude Module Developer @msulzer
                                      @msulzer Anything is possible LOL Just go in and edit them out of the getDom section then they can’t show.
                                      If you need help let me know. I can whittle it down for you, PM me ;)
                                      • N Offline
                                        n0v4
                                        Dear cowboysdude,
                                        thanks a lot for the great Module. I’m trying to implement it.
                                        Just to know…totally new to it.
                                        Full install and config added. But now the MagicMirror staies black completally.
                                        When i remove the config information, the Mirror is working nomarlly.
                                        Has this to do with the API’s?
                                        Thanks for your help.
                                          sdetweil @n0v4
                                          @n0v4 probably this https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                                          • N Offline
                                            n0v4 @sdetweil
                                            @sdetweil thanks for your link.
                                            but the Mirror is working without the MMM-NOAA-Another Weather Module activated.
                                            As soons as i activate it, the screen stayes black.
                                            in the link i couldn’t find any solution.
                                            Any other ideas?
                                            Thanks.
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
