    690 Posts 77 Posters 3.3m Views 70 Watching
    • L
      Lagmin
      Thank you, it worked for my other modules.
      For this module I have problem, it is showing only Rise, Daylight and Set. All other are ‘undefined’. Someone knows the solution?
      Here is my config:
         module: 'MMM-NOAA3',
      position: 'top_left',
             provider: "openweather", // From list above
             apiKey: "key",        // From one of the providers listed above
             airKey: "key",
             css: "NOAA4",                   // THIS MUST CONTAIN A CSS STYLE NAME
         userlat: "52.429248", //MUST HAVE BOTH
             userlon: "20.962540"  //MUST HAVE BOTH
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Lagmin
        @Lagmin said in MMM-NOAA - Another Weather Module:
        Here you go, please update it and by the way, could you please tell me how to implement this language to my MagicMirror module?
        I forwarded to the author. He will add it to the module, at which time, you will have to run git pull in the MMM-NOAA3 directory. Your config language should be language: "pl",
        • cowboysdudeC
          pl file added for Polish translation. Thank you for taking the time to make it. As Mykle1 says do a ‘git pull’ in the MMM-NOAA3 directory.
          • L
            Lagmin
            No problem, not much time. Do you know maybe what can be a solution to my problem showing only 3 results, please?
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Have you installed the dependencies?
              L 1 Reply Last reply
              • L
                Lagmin @Mykle1
                @Mykle1 Ok, I got it, it is “working”.
                I used this simple config:
                       provider: "must be in quotes", // From list above
                       apiKey: "YOUR API KEY",        // From one of the providers listed above
                       airKey: "YOUR API KEY",
                       css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
                   userlat: "xxxx", //MUST HAVE BOTH
                       userlon: "xxxx"  //MUST HAVE BOTH
                But:
                1. I don’t have % for Humidity, inHg for Pressure…
                2. How I can translate WIND? I don’t have it in translation file (same for AQI, UV).
                3. I don’t have forecast for 4 days below.
                Do you know what can be the problem?
                Mykle1M 2 Replies Last reply
                • Mykle1M
                  @Lagmin
                  I’m guessing that the data is not complete for all locations so you may not see % for Humidity, inHg for Pressure… or that information is not present in the data (for some reason).
                  You can add “Wind” to the translation file of your language and put in the translation. I’ve given an example below. Then send a PR to the author and he will add it to the repo.
                  "Sun":"Sun",
                  "No Wind": "No Wind",
                  "Wind": "Yours",
                  "Humidity": "Humidity",
                  • Mykle1M
                    @Lagmin
                    Just spoke with the author. Some of the providers are not supplying the data they once were or they’ve changed the way they provide the data. This module uses several different providers so try another one and see if you get better results.
                    Keeping this module functioning using all the different providers must be a monumental task. It may take a long time for the author to fix any of it, assuming he has the time.
                    • L
                      Lagmin @Mykle1
                      @Mykle1 Well I tried changing coordinates for our capital city of Poland - Warsaw, but it is still not showing forecast. I also tried to change for weatherbit (previously used openweather) but with weatherbit it doesn’t even show forecast - (Prognoza na 4 dni).
                      • Mykle1M
                        @Lagmin
                        Yes, understood. I’m using my darksky api key until it is no longer valid. Like you, my OpenWeather api key doesn’t show the 4 day forecast. I spoke with the author and he is extremely busy with work so he doesn’t have much time to troubleshoot his modules. You can fork the repo and fix it if you like. :-)
                          sdetweil @Mykle1
                          @Mykle1 yeh hourly for 4 days, or daily for 7 days are in the openweather free apikey access, but ONLY by using the one all api
                          • Mykle1M
                            Yes, I know. I’m using it in my MMM-BMW-OW module. :-)
                              sdetweil @Mykle1
                              @Mykle1 I know. we did it at the same time.
                              was adding info for others
                                majdzik84 @Pielo
                                @Pielo how did you make the frame with temperature and humidity? I would like to get something like this by sending data via mqtt
                                  msulzer
                                  Hi everyone, this module looks really great. Is there a possibility not to show certain items such as AQI, UV etc.?
                                  • cowboysdudeC
                                    cowboysdude Module Developer @msulzer
                                    @msulzer Anything is possible LOL Just go in and edit them out of the getDom section then they can’t show.
                                    If you need help let me know. I can whittle it down for you, PM me ;)
                                    • N
                                      n0v4
                                      Dear cowboysdude,
                                      thanks a lot for the great Module. I’m trying to implement it.
                                      Just to know…totally new to it.
                                      Full install and config added. But now the MagicMirror staies black completally.
                                      When i remove the config information, the Mirror is working nomarlly.
                                      Has this to do with the API’s?
                                      Thanks for your help.
                                        sdetweil @n0v4
                                        @n0v4 probably this https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                                        N 1 Reply Last reply
                                        • N
                                          n0v4 @sdetweil
                                          @sdetweil thanks for your link.
                                          but the Mirror is working without the MMM-NOAA-Another Weather Module activated.
                                          As soons as i activate it, the screen stayes black.
                                          in the link i couldn’t find any solution.
                                          Any other ideas?
                                          Thanks.
                                            sdetweil @n0v4
                                            @n0v4 the topic posted defined work for you to do
                                            when the screen is black, what do the messages say in the place u start MM.
                                            either npm start or
                                            pm2
                                            if pm2, then pm2 logs --lines=nnn show the results (nnn= number, default 15)
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
