    MMM-RottenTomatoes displays awaiting update
    25 Posts 10 Posters 12.0k Views 10 Watching
      sdetweil @airs747
      @airs747 said in MMM-RottenTomatoes displays awaiting update:
      ’m think about a better way (take the first movie on the site?) and commit to github
      find the github repo for the module you fixed,
      fork it (now YOU have a linked ‘copy’)
      make the same changes, commit to YOUR copy
      and then offer a Pull Request (new pull request button) to the source to fix the problem for all
      lavolp3L 1 Reply Last reply
        4r3st3r
        Hi, thanks for all the help so far! When I cloned the parnic’s rt-scraper and MMM-RottenTomatoes fork it still just displayed “awaiting update”. Has anyone else managed to get this module fixed?
          rdemets @airs747
          @airs747 Hi. I tried that, but I didn’t find any instance of homepage-top-box-office in index.js. I can see in the code source the movies_sidebar, but I don’t know where to place it. Can you please give more details about what you did ? I’ve installed RottenTomatoes via parnic code, and the rt-scrapper linked to it. Thank you very much.
            rdemets @tomyboy96
            @tomyboy96 Same here, did you get it to work ? Thanks
            T 1 Reply Last reply
            • T
              tomyboy96 Project Sponsor @rdemets
              @rdemets
              Nope… still nothing…
              • lavolp3L
                @sdetweil @airs747
                There is already a fix that is PRd to the rt-scraper module. Unfortunately since February already.
                The problem is that it would need to be merged and published as an npm module to be properly installed here.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • T
                  tomyboy96 Project Sponsor @lavolp3
                  @lavolp3
                  Is this something that can be installed manually?
                  • lavolp3L
                    lavolp3 Module Developer @tomyboy96
                    @tomyboy96 I would try to overwrite index.js with the one from the PR.
                    MIT License
                    Copyright (c) 2017 Adam Moses
                    Permission is hereby granted, free of charge, to any person obtaining a copy
                    of this software and associated documentation files (the "Software"), to deal
                    in the Software without restriction, including without limitation the rights
                    to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
                    copies of the Software, and to permit persons to whom the Software is
                    furnished to do so, subject to the following conditions:
                    The above copyright notice and this permission notice shall be included in all
                    copies or substantial portions of the Software.
                    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
                    IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
                    FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
                    AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
                    LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
                    OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
                    SOFTWARE.
                    // parses the HTML body that the request operation received
                    // uses the cheerio package to achieve this
                    function parseRottenTomatoesHTML(fileData) {
                        var cheerio = require("cheerio");
                        // prep the return object
                        var allTomatoData = { openingThisWeek: [ ]
                                               , boxOffice: [ ]
                                               , comingSoon: [ ] };
                        var errorFlag = true;
                        // sanity check that this is rotten tomatoes web html
                        if (fileData.indexOf('Rotten Tomatoes') != -1) {
                            // set error flag to false for passing sanity check
                            errorFlag = false;
                            // load the html into the cheerio doc
                            var fullDoc = cheerio.load(fileData);
                            // find the stub for movies opening this week
                            var openingThisWeekDoc = cheerio.load(fullDoc('[id="opening-this-week"]').html());
                            // iterate through movies and strip useful parts, add each to return object
                            openingThisWeekDoc('tr').each(function() {
                                var movieDoc = cheerio.load(openingThisWeekDoc(this).html());
                                var movieMeter = movieDoc('.media-lists__td-rating').text().trim();
                                var movieTitle = movieDoc('.media-lists__td-title').text().trim();
                                var movieDate  = movieDoc('.media-lists__td-date').text().trim();
                                var movieObj = {
                                    meter: movieMeter,
                                    title: movieTitle,
                                    date: movieDate
                                allTomatoData.openingThisWeek[allTomatoData.openingThisWeek.length] = movieObj;
                            // find the stub for top box office this week
                            var topBoxOfficeDoc = cheerio.load(fullDoc('[id="top-box-office"]').html());
                            topBoxOfficeDoc('tr').each(function() {
                                var movieDoc = cheerio.load(topBoxOfficeDoc(this).html());
                                var movieGross = movieDoc('.media-lists__td-date').text().trim();
                                var movieObj = {
                                    meter: movieMeter,
                                    title: movieTitle,
                                    gross: movieGross
                                allTomatoData.boxOffice[allTomatoData.boxOffice.length] = movieObj;
                            // find the stub for top movies coming soon
                            var topComingSoonDoc = cheerio.load(fullDoc('[id="coming-soon-theaters"]').html());
                            topComingSoonDoc('tr').each(function() {
                                var movieDoc = cheerio.load(topComingSoonDoc(this).html());
                                var movieObj = {
                                    meter: movieMeter,
                                    title: movieTitle,
                                    date: movieDate
                                allTomatoData.comingSoon[allTomatoData.comingSoon.length] = movieObj;
                        // return error flag and the data
                        return {error: errorFlag, data: allTomatoData};
                    // makes a call to get the HTML from the rotten tomatoes front page
                    // uses the request package to achieve this
                    function requestRottenTomatoesHTML(callback) {
                        var request = require("request");
                        request({ uri: "http://www.rottentomatoes.com" },
                            function(error, response, body) {
                                if (!error) {
                                    var parsedData = parseRottenTomatoesHTML(body);
                                    if (parsedData.error == false)
                                        callback(false, parsedData.data);
                                    else
                                        callback(true, null);
                                else {
                    // the export function exposed via the package
                    // uses a callback since the request call itself is asynchronous
                    exports.getRottenTomatoesScraperData = function(callback) {
                        requestRottenTomatoesHTML(callback);
                    //  --- the end ---
                    That would be the manual DIRTY way. But since the PR is from Feb and not merged yet it is getting more unlikely.
                    Don’t know if this has been tried already
                    T S 2 Replies Last reply
                    • T
                      @lavolp3
                      Nope not working…
                      if you change the id’s to “movies_sidebar”
                      and uri: “http://www.rottentomatoes.com/m/dream_horse”
                      It seems like it’s loading again. but the loading is not correct.
                      would be super good if there would be a way to manually add the PR just replacing the index do not work.
                        sdetweil @lavolp3
                        @lavolp3 where did the pr come from? what repo? git clone that repo to install and test
                        • lavolp3L
                          @sdetweil it’s old stuff as I see, has been explained before already
                          https://forum.magicmirror.builders/post/70295
                          When I install @parnic’s fork,
                          1. I have a node.js error since the NodeHelper has not been declared in this file.
                            This can be resolved by adding
                          var NodeHelper = require("node_helper")
                          below the declaration of the rt-scraper.
                          1. then see only the headers and no movies as has been described above.
                          That’s the problem with scrapers. Small cosmetic changes in the website break them.
                          lavolp3L S 2 Replies Last reply
                          • lavolp3L
                            lavolp3 Module Developer @lavolp3
                            RT has obviously changed their content more towards TV shows since cinemas are not well visited at the moment.
                              sdetweil @lavolp3
                              @lavolp3 yeh, one of the TV show scrapers failed too for similar cause.
                              • T
                                Still nothing new here?
                                Saw that https://github.com/parnic/MMM-RottenTomatoes has gotten a new push but still seems like the same problem.
                                • lavolp3L
                                  @tomyboy96 same for me. No movies showing up.
                                  • lavolp3L
                                    @lavolp3 I tried to dig a bit deeper into the rt-scraper module again and it seems the references for the elements are all different from the current page.
                                    The output of the module is empty and therefore we only see the headlines and no content.
                                    I don’t think I’ll be able to fix it.
