    MMM-RottenTomatoes displays awaiting update
    25 Posts 10 Posters 9.8k Views 10 Watching
    • H Offline
      haywire
      Sorry to hear it didn’t work for you. I am making the assumption your using the original pull which were from https://github.com/AdamMoses-GitHub/NPMJS-rt-scraper.
      Unfortunately, I modified the original MMM-RottenTomatoes, so I don’t have a like for a like environment, but assumed correction would work for the original module.
      The root of the problem is Rotten Tomato new web format, which is part of rt-scraper (which you found).
      As indicate my fix were based on another user correction. You can attempt to pull or replace using his build.
      https://github.com/parnic/NPMJS-rt-scraper
      He has also updated his repo for RottenTomatoes module it self and updated the dependency. I haven’t tried it, but seem he best overall re-package solution.
      https://github.com/parnic/MMM-RottenTomatoes
      If that still doesn’t work and have time I can re-package my update, but it would be base on slight modified version of MMM-RottenTomatoes.
      I T 2 Replies Last reply Reply Quote 0
      • I Offline
        ifzer0c00lsucked @haywire
        @haywire it worked. took some time for the first update but after that it has been working perfectly. THANKS!
        • T Offline
          tomyboy96 Project Sponsor @haywire
          Hey @haywire!
          I tried this but it did not work for me…
          Tried removing old MMM-RottenTomatoes and installing https://github.com/parnic/MMM-RottenTomatoes
          It got the “Awaiting update” message fixed but the only thing showing up now is the:
          box office, opening this week, coming soon
          without any movies.
          Using the same config.js as I did for the old MMM-RottenTomatoes
          Also tried manually removing rt-scraper and then cloning from https://github.com/parnic/NPMJS-rt-scraper but still no success…
          Any ideas?
            airs747
            I found a (dirty) workaround.
            Inspecting https://www.rottentomatoes.com/m/dream_horse, you can see the sidebar that used to be on the homepage. The structure is the same as before, except that the name of the div-element is different than assumed in the rt-scraper code.
            So, this is what I did to get it working:
            1. Go to the node-modules/rt-scraper directory in your MagicMirror installation dir.
            2. Edit index.js
            3. Replace the three instances of “homepage-top-box-office” with “movies_sidebar”
            4. Replace the request uri rottentomatoes.com to rottentomatoes.com/m/dream_horse
            5. Restart MagicMirror and you should now see the RT movie listing appearing again.
            Now, this is dirty, because of the Dream Horse link. I’m think about a better way (take the first movie on the site?) and commit to github. But for now we can at least enjoy the movie listings again.
            S R 2 Replies Last reply Reply Quote 0
              sdetweil @airs747
              @airs747 said in MMM-RottenTomatoes displays awaiting update:
              find the github repo for the module you fixed,
              fork it (now YOU have a linked ‘copy’)
              make the same changes, commit to YOUR copy
              and then offer a Pull Request (new pull request button) to the source to fix the problem for all
              • 4 Offline
                4r3st3r
                Hi, thanks for all the help so far! When I cloned the parnic’s rt-scraper and MMM-RottenTomatoes fork it still just displayed “awaiting update”. Has anyone else managed to get this module fixed?
                  rdemets @airs747
                  @airs747 Hi. I tried that, but I didn’t find any instance of homepage-top-box-office in index.js. I can see in the code source the movies_sidebar, but I don’t know where to place it. Can you please give more details about what you did ? I’ve installed RottenTomatoes via parnic code, and the rt-scrapper linked to it. Thank you very much.
                    rdemets @tomyboy96
                    @tomyboy96 Same here, did you get it to work ? Thanks
                    • T Offline
                      tomyboy96 Project Sponsor @rdemets
                      @rdemets
                      Nope… still nothing…
                      • lavolp3L Offline
                        @sdetweil @airs747
                        There is already a fix that is PRd to the rt-scraper module. Unfortunately since February already.
                        The problem is that it would need to be merged and published as an npm module to be properly installed here.
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
