MMM-RottenTomatoes displays awaiting update
25 Posts 10 Posters 8.7k Views 10 Watching
  • E Offline
    EdO
    The MMM-RottenTomatoes module has been displaying "Awaiting update for a couple of days now yet when I go and do a git pull I’m told the module is up to date. Any idea what is going on.
    • H Offline
      haywire
      Rotten tomato changed to there web format recently. Small changes are needed to the NPMJS-rt-scraper index.js file to support the changes. My changes were base @Parnic changes.
      Below is my update index.js replacing the installed package rt-scaper index.js will correct the issue.
      https://github.com/haywirecoder/NPMJS-rt-scraper/blob/master/index.js.
      D 1 Reply Last reply Mar 6, 2020, 5:29 PM Reply Quote 0
      • E Offline
        EdO
        Thanks, I’ll try that tonight.
          Dizzydude @haywire
          @haywire Thanks for this. I’m a newbie, could you walk me through the steps of updating this file with the one that you provided? I tried searching my MMM-RottenTomatoes folder for any mention of index.js or rt-scraper and nothing came up.
          EDIT: Found the file, located here: /MagicMirror/modules/node_modules/rt-scraper/index.js. I’ve copied and pasted the text from the git link however it’s still Awaiting Update. Not sure if I did something wrong.
          • I Offline
            ifzer0c00lsucked
            I also copied and pasted your code and it is still stuck in awaiting update? Any help getting this cool little module to work would be greatly appreciated.
            • H Offline
              haywire
              Sorry to hear it didn’t work for you. I am making the assumption your using the original pull which were from https://github.com/AdamMoses-GitHub/NPMJS-rt-scraper.
              Unfortunately, I modified the original MMM-RottenTomatoes, so I don’t have a like for a like environment, but assumed correction would work for the original module.
              The root of the problem is Rotten Tomato new web format, which is part of rt-scraper (which you found).
              As indicate my fix were based on another user correction. You can attempt to pull or replace using his build.
              https://github.com/parnic/NPMJS-rt-scraper
              He has also updated his repo for RottenTomatoes module it self and updated the dependency. I haven’t tried it, but seem he best overall re-package solution.
              https://github.com/parnic/MMM-RottenTomatoes
              If that still doesn’t work and have time I can re-package my update, but it would be base on slight modified version of MMM-RottenTomatoes.
              I T 2 Replies Last reply Mar 8, 2020, 12:32 AM Reply Quote 0
              • I Offline
                ifzer0c00lsucked @haywire
                @haywire it worked. took some time for the first update but after that it has been working perfectly. THANKS!
                • T Offline
                  tomyboy96 Project Sponsor @haywire
                  Hey @haywire!
                  I tried this but it did not work for me…
                  Tried removing old MMM-RottenTomatoes and installing https://github.com/parnic/MMM-RottenTomatoes
                  It got the “Awaiting update” message fixed but the only thing showing up now is the:
                  box office, opening this week, coming soon
                  without any movies.
                  Using the same config.js as I did for the old MMM-RottenTomatoes
                  Also tried manually removing rt-scraper and then cloning from https://github.com/parnic/NPMJS-rt-scraper but still no success…
                  Any ideas?
                  R 1 Reply Last reply May 12, 2020, 11:24 AM Reply Quote 0
                    airs747
                    I found a (dirty) workaround.
                    Inspecting https://www.rottentomatoes.com/m/dream_horse, you can see the sidebar that used to be on the homepage. The structure is the same as before, except that the name of the div-element is different than assumed in the rt-scraper code.
                    So, this is what I did to get it working:
                    1. Go to the node-modules/rt-scraper directory in your MagicMirror installation dir.
                    2. Edit index.js
                    3. Replace the three instances of “homepage-top-box-office” with “movies_sidebar”
                    4. Replace the request uri rottentomatoes.com to rottentomatoes.com/m/dream_horse
                    5. Restart MagicMirror and you should now see the RT movie listing appearing again.
                    Now, this is dirty, because of the Dream Horse link. I’m think about a better way (take the first movie on the site?) and commit to github. But for now we can at least enjoy the movie listings again.
                    S R 2 Replies Last reply May 2, 2020, 6:07 PM Reply Quote 0
                      sdetweil @airs747
                      @airs747 said in MMM-RottenTomatoes displays awaiting update:
                      find the github repo for the module you fixed,
                      fork it (now YOU have a linked ‘copy’)
                      make the same changes, commit to YOUR copy
                      and then offer a Pull Request (new pull request button) to the source to fix the problem for all
                      L 1 Reply Last reply Aug 10, 2020, 8:55 PM Reply Quote 0
