    MMM-RottenTomatoes displays awaiting update
    25 Posts 10 Posters 11.8k Views 10 Watching
    • T Offline
      tomyboy96 Project Sponsor @haywire
      Hey @haywire!
      I tried this but it did not work for me…
      Tried removing old MMM-RottenTomatoes and installing https://github.com/parnic/MMM-RottenTomatoes
      It got the “Awaiting update” message fixed but the only thing showing up now is the:
      box office, opening this week, coming soon
      without any movies.
      Using the same config.js as I did for the old MMM-RottenTomatoes
      Also tried manually removing rt-scraper and then cloning from https://github.com/parnic/NPMJS-rt-scraper but still no success…
      Any ideas?
        airs747
        I found a (dirty) workaround.
        Inspecting https://www.rottentomatoes.com/m/dream_horse, you can see the sidebar that used to be on the homepage. The structure is the same as before, except that the name of the div-element is different than assumed in the rt-scraper code.
        So, this is what I did to get it working:
        1. Go to the node-modules/rt-scraper directory in your MagicMirror installation dir.
        2. Edit index.js
        3. Replace the three instances of “homepage-top-box-office” with “movies_sidebar”
        4. Replace the request uri rottentomatoes.com to rottentomatoes.com/m/dream_horse
        5. Restart MagicMirror and you should now see the RT movie listing appearing again.
        Now, this is dirty, because of the Dream Horse link. I’m think about a better way (take the first movie on the site?) and commit to github. But for now we can at least enjoy the movie listings again.
        S R 2 Replies Last reply Reply Quote 0
          sdetweil @airs747
          @airs747 said in MMM-RottenTomatoes displays awaiting update:
          find the github repo for the module you fixed,
          fork it (now YOU have a linked ‘copy’)
          make the same changes, commit to YOUR copy
          and then offer a Pull Request (new pull request button) to the source to fix the problem for all
          • 4 Offline
            4r3st3r
            Hi, thanks for all the help so far! When I cloned the parnic’s rt-scraper and MMM-RottenTomatoes fork it still just displayed “awaiting update”. Has anyone else managed to get this module fixed?
              rdemets @airs747
              @airs747 Hi. I tried that, but I didn’t find any instance of homepage-top-box-office in index.js. I can see in the code source the movies_sidebar, but I don’t know where to place it. Can you please give more details about what you did ? I’ve installed RottenTomatoes via parnic code, and the rt-scrapper linked to it. Thank you very much.
                rdemets @tomyboy96
                @tomyboy96 Same here, did you get it to work ? Thanks
                • T Offline
                  tomyboy96 Project Sponsor @rdemets
                  @rdemets
                  Nope… still nothing…
                  • lavolp3L Offline
                    @sdetweil @airs747
                    There is already a fix that is PRd to the rt-scraper module. Unfortunately since February already.
                    The problem is that it would need to be merged and published as an npm module to be properly installed here.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    • T Offline
                      tomyboy96 Project Sponsor @lavolp3
                      @lavolp3
                      Is this something that can be installed manually?
                      • lavolp3L Offline
                        lavolp3 Module Developer @tomyboy96
                        @tomyboy96 I would try to overwrite index.js with the one from the PR.
                        MIT License
                        Copyright (c) 2017 Adam Moses
                        Permission is hereby granted, free of charge, to any person obtaining a copy
                        of this software and associated documentation files (the "Software"), to deal
                        in the Software without restriction, including without limitation the rights
                        to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
                        copies of the Software, and to permit persons to whom the Software is
                        furnished to do so, subject to the following conditions:
                        The above copyright notice and this permission notice shall be included in all
                        copies or substantial portions of the Software.
                        THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
                        IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
                        FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
                        AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
                        LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
                        OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
                        SOFTWARE.
                        // parses the HTML body that the request operation received
                        // uses the cheerio package to achieve this
                        function parseRottenTomatoesHTML(fileData) {
                            var cheerio = require("cheerio");
                            // prep the return object
                            var allTomatoData = { openingThisWeek: [ ]
                                                   , boxOffice: [ ]
                                                   , comingSoon: [ ] };
                            var errorFlag = true;
                            // sanity check that this is rotten tomatoes web html
                            if (fileData.indexOf('Rotten Tomatoes') != -1) {
                                // set error flag to false for passing sanity check
                                errorFlag = false;
                                // load the html into the cheerio doc
                                var fullDoc = cheerio.load(fileData);
                                // find the stub for movies opening this week
                                var openingThisWeekDoc = cheerio.load(fullDoc('[id="opening-this-week"]').html());
                                // iterate through movies and strip useful parts, add each to return object
                                openingThisWeekDoc('tr').each(function() {
                                    var movieDoc = cheerio.load(openingThisWeekDoc(this).html());
                                    var movieMeter = movieDoc('.media-lists__td-rating').text().trim();
                                    var movieTitle = movieDoc('.media-lists__td-title').text().trim();
                                    var movieDate  = movieDoc('.media-lists__td-date').text().trim();
                                    var movieObj = {
                                        meter: movieMeter,
                                        title: movieTitle,
                                        date: movieDate
                                    allTomatoData.openingThisWeek[allTomatoData.openingThisWeek.length] = movieObj;
                                // find the stub for top box office this week
                                var topBoxOfficeDoc = cheerio.load(fullDoc('[id="top-box-office"]').html());
                                topBoxOfficeDoc('tr').each(function() {
                                    var movieDoc = cheerio.load(topBoxOfficeDoc(this).html());
                                    var movieGross = movieDoc('.media-lists__td-date').text().trim();
                                    var movieObj = {
                                        meter: movieMeter,
                                        title: movieTitle,
                                        gross: movieGross
                                    allTomatoData.boxOffice[allTomatoData.boxOffice.length] = movieObj;
                                // find the stub for top movies coming soon
                                var topComingSoonDoc = cheerio.load(fullDoc('[id="coming-soon-theaters"]').html());
                                topComingSoonDoc('tr').each(function() {
                                    var movieDoc = cheerio.load(topComingSoonDoc(this).html());
                                    var movieObj = {
                                        meter: movieMeter,
                                        title: movieTitle,
                                        date: movieDate
                                    allTomatoData.comingSoon[allTomatoData.comingSoon.length] = movieObj;
                            // return error flag and the data
                            return {error: errorFlag, data: allTomatoData};
                        // makes a call to get the HTML from the rotten tomatoes front page
                        // uses the request package to achieve this
                        function requestRottenTomatoesHTML(callback) {
                            var request = require("request");
                            request({ uri: "http://www.rottentomatoes.com" },
                                function(error, response, body) {
                                    if (!error) {
                                        var parsedData = parseRottenTomatoesHTML(body);
                                        if (parsedData.error == false)
                                            callback(false, parsedData.data);
                                        else
                                            callback(true, null);
                                    else {
                        // the export function exposed via the package
                        // uses a callback since the request call itself is asynchronous
                        exports.getRottenTomatoesScraperData = function(callback) {
                            requestRottenTomatoesHTML(callback);
                        //  --- the end ---
                        That would be the manual DIRTY way. But since the PR is from Feb and not merged yet it is getting more unlikely.
                        Don’t know if this has been tried already
                        T S 2 Replies Last reply Reply Quote 0
                        • T Offline
                          @lavolp3
                          Nope not working…
                          if you change the id’s to “movies_sidebar”
                          and uri: “http://www.rottentomatoes.com/m/dream_horse”
                          It seems like it’s loading again. but the loading is not correct.
                          would be super good if there would be a way to manually add the PR just replacing the index do not work.
                            sdetweil @lavolp3
                            @lavolp3 where did the pr come from? what repo? git clone that repo to install and test
                            • lavolp3L Offline
                              @sdetweil it’s old stuff as I see, has been explained before already
                              https://forum.magicmirror.builders/post/70295
                              When I install @parnic’s fork,
                              1. I have a node.js error since the NodeHelper has not been declared in this file.
                                This can be resolved by adding
                              var NodeHelper = require("node_helper")
                              below the declaration of the rt-scraper.
                              1. then see only the headers and no movies as has been described above.
                              That’s the problem with scrapers. Small cosmetic changes in the website break them.
                              lavolp3L S 2 Replies Last reply Reply Quote 0
                              • lavolp3L Offline
                                lavolp3 Module Developer @lavolp3
                                RT has obviously changed their content more towards TV shows since cinemas are not well visited at the moment.
                                  sdetweil @lavolp3
                                  @lavolp3 yeh, one of the TV show scrapers failed too for similar cause.
                                  • T Offline
                                    Still nothing new here?
                                    Saw that https://github.com/parnic/MMM-RottenTomatoes has gotten a new push but still seems like the same problem.
                                    • lavolp3L Offline
                                      @tomyboy96 same for me. No movies showing up.
                                      • lavolp3L Offline
                                        @lavolp3 I tried to dig a bit deeper into the rt-scraper module again and it seems the references for the elements are all different from the current page.
                                        The output of the module is empty and therefore we only see the headlines and no content.
                                        I don’t think I’ll be able to fix it.
