    A whole lot upgrades to my MagicMirror, finally!
    23 Posts 9 Posters 14.2k Views 7 Watching
    • FoziF
      Fozi Project Sponsor @banbutcher
      @banbutcher Hi, it’s the MMM-withings module https://github.com/kodymallory/MMM-withings.
        banbutcher
        ah i see… so its taken from the nokia apps! Im looking for the same but with either ios or google fit!
        thanks for your reply! :)
          Congrats on your second build!
          Also, flattering to see so many of my modules in use. Thank you!
          FoziF 1 Reply Last reply
          • FoziF
            Fozi Project Sponsor @j.e.f.f
            @j-e-f-f I have to thank YOU!!:folded_hands_medium_skin_tone:
              sparkgap-code @Fozi
              @Fozi
              Congratulations for your magic mirror, really very nice. I wanted to ask you: do you have memory problems on the electron process when running the MMM-withings module? for me with every data loading, the memory used increases.
              • FoziF
                Fozi Project Sponsor @sparkgap-code
                @sparkgap-code I have no Memory issues with this module. What I experienced a few times is that some modules don’t play well together and memory problems occur. I had that with MMM-Rain-Map and MMM-GoogleRoute. Each of the modules was fine alone. As soon as both were activated I ran into memory overflow. Lastly I gave up on GoogleRoute as I had no real need for it.
                  sparkgap-code @Fozi
                  @Fozi Hi, I solved it by extending the update time to two hours and eliminating some features present in the chartJS. Now I am in the TEST phase but for now it seems to be fine.
                  • cowboysdudeC
                    Looks great!!! :)
                    Here’s my new look
                    FoziF C mumblebajM 3 Replies Last reply
                    • FoziF
                      Fozi Project Sponsor @cowboysdude
                      @cowboysdude thanks, mate! Your new look is fantastic! I love the clean and structured layout where you get information at a glance. Which home automation system or sensors/actors do you use?
                        cyberphox @cowboysdude
                        @cowboysdude I’m loving my Home Assistant too! Also interested in what sensors you are using?
                        • mumblebajM
                          mumblebaj Module Developer @cowboysdude
                          @cowboysdude What module are you using for the phone information?
                          Love the clean layout. Looks awesome
                          • cowboysdudeC
                            cowboysdude Module Developer @Fozi
                            @Fozi I am using a TON of sensors. Temp/Humid sensors, water leak sensors, motion sensors. My thermostat is a Honeywell so there’s a work around to show that and make it work. My door lock is zwave… I have a ton of switches and smart LED bulbs… switches are GE single pole and bulbs are made by CREE and Samsung. I have also ordered a Samsung Motion sensor…
                            Waiting for my two Arduino’s to build my USB Motion sensors to turn monitors on and off… those parts should all get here this week! :)
                            Are you on HA forum?
                            It’s what I wanted this to do from the beginning :)
                            Temp/Humidity Sensors
                            Motion Sensors
                            • cowboysdudeC
                              cowboysdude Module Developer @cyberphox
                              @cyberphox See you knew what I was doing LOL
                              I’m using Motion sensors, water leak sensors, my phone as a sensor, zigbee switches and led bulbs. My door lock is a zwave lock. The Thermostat is a honeywell work around someone in HA built.
                              NOW I can finally have what I’ve wanted all along. A 32" touch screen info panel. This is just the beginning, I plan on adding a ton more!
                              Mykle1M 1 Reply Last reply
                              • Mykle1M
                                @cowboysdude
                                Make me one! Now!
                                • cowboysdudeC
                                  cowboysdude Module Developer @mumblebaj
                                  @mumblebaj I would share it but it’s not a module for MM. It’s a Home Assistant sensor ‘module’
