    A whole lot upgrades to my MagicMirror, finally!
    23 Posts 9 Posters 14.0k Views 7 Watching
      cyberphox @Fozi
      @Fozi I just saw the pin instructions on the readme page…thank you though…I’m gonna maybe use this or a FireTv stick remote to switch pages…
      • FoziF Offline
        Fozi Project Sponsor @cyberphox
        @cyberphox That’s a cool idea!
          banbutcher
          hi,
          What module did you use for your health data (weight etc)
          thanks
          Richie
          • FoziF Offline
            Fozi Project Sponsor @banbutcher
            @banbutcher Hi, it’s the MMM-withings module https://github.com/kodymallory/MMM-withings.
              banbutcher
              ah i see… so its taken from the nokia apps! Im looking for the same but with either ios or google fit!
              thanks for your reply! :)
                Congrats on your second build!
                Also, flattering to see so many of my modules in use. Thank you!
                FoziF 1 Reply Last reply Reply Quote 1
                • FoziF Offline
                  Fozi Project Sponsor @j.e.f.f
                  @j-e-f-f I have to thank YOU!!:folded_hands_medium_skin_tone:
                    sparkgap-code @Fozi
                    @Fozi
                    Congratulations for your magic mirror, really very nice. I wanted to ask you: do you have memory problems on the electron process when running the MMM-withings module? for me with every data loading, the memory used increases.
                    • FoziF Offline
                      Fozi Project Sponsor @sparkgap-code
                      @sparkgap-code I have no Memory issues with this module. What I experienced a few times is that some modules don’t play well together and memory problems occur. I had that with MMM-Rain-Map and MMM-GoogleRoute. Each of the modules was fine alone. As soon as both were activated I ran into memory overflow. Lastly I gave up on GoogleRoute as I had no real need for it.
                        sparkgap-code @Fozi
                        @Fozi Hi, I solved it by extending the update time to two hours and eliminating some features present in the chartJS. Now I am in the TEST phase but for now it seems to be fine.
                        • cowboysdudeC Offline
                          Looks great!!! :)
                          Here’s my new look
                          FoziF C mumblebajM 3 Replies Last reply Reply Quote 1
                          • FoziF Offline
                            Fozi Project Sponsor @cowboysdude
                            @cowboysdude thanks, mate! Your new look is fantastic! I love the clean and structured layout where you get information at a glance. Which home automation system or sensors/actors do you use?
                              cyberphox @cowboysdude
                              @cowboysdude I’m loving my Home Assistant too! Also interested in what sensors you are using?
                              • mumblebajM Offline
                                mumblebaj Module Developer @cowboysdude
                                @cowboysdude What module are you using for the phone information?
                                Love the clean layout. Looks awesome
                                  cowboysdude Module Developer @Fozi
                                  @Fozi I am using a TON of sensors. Temp/Humid sensors, water leak sensors, motion sensors. My thermostat is a Honeywell so there’s a work around to show that and make it work. My door lock is zwave… I have a ton of switches and smart LED bulbs… switches are GE single pole and bulbs are made by CREE and Samsung. I have also ordered a Samsung Motion sensor…
                                  Waiting for my two Arduino’s to build my USB Motion sensors to turn monitors on and off… those parts should all get here this week! :)
                                  Are you on HA forum?
                                  It’s what I wanted this to do from the beginning :)
                                  Temp/Humidity Sensors
                                  Motion Sensors
                                    cowboysdude Module Developer @cyberphox
                                    @cyberphox See you knew what I was doing LOL
                                    I’m using Motion sensors, water leak sensors, my phone as a sensor, zigbee switches and led bulbs. My door lock is a zwave lock. The Thermostat is a honeywell work around someone in HA built.
                                    NOW I can finally have what I’ve wanted all along. A 32" touch screen info panel. This is just the beginning, I plan on adding a ton more!
                                      @cowboysdude
                                      Make me one! Now!
                                        cowboysdude Module Developer @mumblebaj
                                        @mumblebaj I would share it but it’s not a module for MM. It’s a Home Assistant sensor ‘module’
