    A whole lot upgrades to my MagicMirror, finally!
    23 Posts 9 Posters 13.3k Views 7 Watching
      Congrats on your second build!
      Also, flattering to see so many of my modules in use. Thank you!
      FoziF 1 Reply Last reply Reply Quote 1
      • FoziF Offline
        Fozi Project Sponsor @j.e.f.f
        @j-e-f-f I have to thank YOU!!:folded_hands_medium_skin_tone:
          sparkgap-code @Fozi
          @Fozi
          Congratulations for your magic mirror, really very nice. I wanted to ask you: do you have memory problems on the electron process when running the MMM-withings module? for me with every data loading, the memory used increases.
          • FoziF Offline
            Fozi Project Sponsor @sparkgap-code
            @sparkgap-code I have no Memory issues with this module. What I experienced a few times is that some modules don’t play well together and memory problems occur. I had that with MMM-Rain-Map and MMM-GoogleRoute. Each of the modules was fine alone. As soon as both were activated I ran into memory overflow. Lastly I gave up on GoogleRoute as I had no real need for it.
              sparkgap-code @Fozi
              @Fozi Hi, I solved it by extending the update time to two hours and eliminating some features present in the chartJS. Now I am in the TEST phase but for now it seems to be fine.
              • cowboysdudeC Offline
                Looks great!!! :)
                Here’s my new look
                FoziF C mumblebajM 3 Replies Last reply Reply Quote 1
                • FoziF Offline
                  Fozi Project Sponsor @cowboysdude
                  @cowboysdude thanks, mate! Your new look is fantastic! I love the clean and structured layout where you get information at a glance. Which home automation system or sensors/actors do you use?
                    cyberphox @cowboysdude
                    @cowboysdude I’m loving my Home Assistant too! Also interested in what sensors you are using?
                    • mumblebajM Offline
                      mumblebaj Module Developer @cowboysdude
                      @cowboysdude What module are you using for the phone information?
                      Love the clean layout. Looks awesome
                        cowboysdude Module Developer @Fozi
                        @Fozi I am using a TON of sensors. Temp/Humid sensors, water leak sensors, motion sensors. My thermostat is a Honeywell so there’s a work around to show that and make it work. My door lock is zwave… I have a ton of switches and smart LED bulbs… switches are GE single pole and bulbs are made by CREE and Samsung. I have also ordered a Samsung Motion sensor…
                        Waiting for my two Arduino’s to build my USB Motion sensors to turn monitors on and off… those parts should all get here this week! :)
                        Are you on HA forum?
                        It’s what I wanted this to do from the beginning :)
                        Temp/Humidity Sensors
                        Motion Sensors
                          cowboysdude Module Developer @cyberphox
                          @cyberphox See you knew what I was doing LOL
                          I’m using Motion sensors, water leak sensors, my phone as a sensor, zigbee switches and led bulbs. My door lock is a zwave lock. The Thermostat is a honeywell work around someone in HA built.
                          NOW I can finally have what I’ve wanted all along. A 32" touch screen info panel. This is just the beginning, I plan on adding a ton more!
                            @cowboysdude
                            Make me one! Now!
                              cowboysdude Module Developer @mumblebaj
                              @mumblebaj I would share it but it’s not a module for MM. It’s a Home Assistant sensor ‘module’
