    Bathroom Magic Mirror
    67 Posts 25 Posters 104.0k Views 27 Watching
    • E
      evgeniy88
      Thanks for your posts. At first I was skeptical about the idea of gluing a mirror on silicone, but now I want to use your design.
      • spitzlbergerjS
        spitzlbergerj Project Sponsor Module Developer
        Thanks a lot
        Josef
        Regards
        Josef
        http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
        • T
          tootiemac3
          Thank you for all this info.
          I am at the very start of my magic mirror journey and came across you mirror which is simply fantastic.
          I noticed you had metal LED buttons on the side of your frame which I would like to install one in mine for powering opn/off.
          Having looked at button tutorials I see most are just 2 jumper wires to the GIPO is this the same for your buttons?
          How is the LED powered?
          thanks!
          Vicki
          • spitzlbergerjS
            please forgive the late reply. It slipped through.
            I use these buttons: https://smile.amazon.de/gp/product/B00JSEX1A0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
            These have separate connections for “nomaly closed” NC and “normaly open” NO. And there are also the connections for the button LED.
            But I did not connect the LEDs. Otherwise, besides the LED of the toothbrush and the LED of the mouthwash and the LED of the razor and … another LED would burn. Then I could slowly save the ceiling lighting in the bathroom :-)
            Regards
            Josef
              PeterKatana
              Hi Josef,
              Looks very impressive. Which source do you use for the wooden frame?
              Thanks a lot
              Peter
              spitzlbergerjS 1 Reply Last reply
              • spitzlbergerjS
                spitzlbergerj Project Sponsor Module Developer @PeterKatana
                Hi @PeterKatana,
                What do you mean by source?
                The frame is made of beech wood. You can buy it from a wood dealer or carpenter. I have taken solid wood shelf savior made of beech from the hardware store. These are glued rod-wise and therefore torsion-resistant.
                Regards
                Josef
                Regards
                Josef
                P 1 Reply Last reply
                  PeterKatana @spitzlbergerj
                  @spitzlbergerj said in Bathroom Magic Mirror:
                  Hi Josef,
                  thanks for the recommendation. I will search here for a carpenter. A miter saw I should have. Before I lived in Aschheim, that was easier. Now I am jobwise in Göppingen. Will search around.
                  I am curious for your next project you announced.
                  Stay safe !
                  Br Peter
                  • spitzlbergerjS
                    Hallo @PeterKatana,
                    Ich kann dir den Rahmen auch zuschneiden, wenn du mir die Maße sagst. Vielleicht kommst du ja mal nach Oberschleißheim oder in die Nähe.
                    Grüße
                    Sepp
                    Regards
                    Josef
                      SuneRadich
                      Your mirror looks amazing, but I am wondering. How is the electronics holding up, being put in a bathroom with alot of moisture? I cant see you did anything extra to keep moisture out of the mirror?
                      • spitzlbergerjS
                        spitzlbergerj Project Sponsor Module Developer @SuneRadich
                        Hi @SuneRadich ,
                        all electrical connections are clamped together in junction boxes for damp locations. The Raspberry Pi is also in such a box. Only the connections of the screen are in their original box, which in my view is not specially protected against moisture.
                        So far, there have been no problems and even if you remove the mirror, you won’t see anything scorched or similar damage.
                        Regards
                        Josef
                        Regards
                        Josef
                          MaXi-XCeL Project Sponsor
                          Just amazing! So well executed. Thank you for the inspiration! :)
                            Servus @spitzlbergerj ,
                            danke für Dein Angebot. Ich habe gestern noch nach Deiner Empfehlung einen Schreiner gefunden. Hoffe, der bekommt das jetzt hin. Falls das nicht klappen sollte, komme ich gern auf Dein Angebot zurück. Ist ja mein erster MM insofern vermute ich, das ich sowieso mit 100 Fragen zurück komme und vielleicht auch den Rahmen wieder verändern muss. Wir werden sehen. Tolle Community übrigens !
                            Grüße Peter
                            • spitzlbergerjS
                              @PeterKatana, alles klar, melde dich einfach. Ich werde morgen den MagicAlibert weiterbauen. Die Spiegel sollten nächste Woche kommen ;-)
                              Regards
                              Josef
                                Hallo @spitzlbergerj,
                                eine Frage kommt mir noch in den Sinn: Ich habe meinen Spiegel so designed, dass ich einen IR Frame (Touch Screen) mit verwenden kann. Was ist denn Deine Meinung zu solchen Dingen. Im Bad wahrscheinlich nicht so praktisch, aber ich dachte im Flur, wenn man noch Aktivitäten steuern mag …wie Musik, oder das Display im Karusell …
                                Vielen Dank ! Vg Peter
                                • spitzlbergerjS
                                  Hi @PeterKatana,
                                  im Bad würde ich das nicht machen. Der Woman Acceptance Faktor würde vermutlich rasant in den Keller gehen, wenn auf dem Spiegel ständig “Dapper” (wie man in Bayern sagt) sind.
                                  Ich habe einen Spiegel mit einen Standard 7" Raspberry Monitor. Aber selbst da habe ich Touch am Ende nie benutzt. Es sind bei mir einfach InfoSchirme. Aktionen löse ich über Schalter, Taster, … aus.
                                  Regards
                                  Josef
                                  P 2 Replies Last reply
                                    Hi @spitzlbergerj ,
                                    Du hast schon Recht. Der Woman Acceptance Factor würde sicher darunter leiden. So richtig viele Anwendungsfälle außer vielleicht Musik steuern oder bei den Nachrichten weiterschalten fallen mir auch nicht ein. Mal schaun. Ich bau das mal zusammen mit dem IR Frame. Vielleicht entstehen da noch Szenarien, wo es sinnvoll ist.
                                    Danke für Deine Einschätzung !
                                    Vg Peter
                                    • E
                                      ernade @spitzlbergerj
                                      Beech wood
                                      Hi, A really nice work.
                                      could I ask you how do you rotate the imageod the screen in portrait?
                                      I am havin some difficulty to let’s happen in my screen. It goes to blue screen (of course not Windows blue screen).
                                      Raspeberry 4 B
                                      G 1 Reply Last reply
                                      • G
                                        George @ernade
                                        @ernade Hi, try this in custom.css file:
                                        body {
                                        margin: 0;
                                        position: absolute;
                                        transform: rotate(90deg);
                                        transform-origin: bottom left;
                                        width: 100vh;
                                        height: 100vw;
                                        object-fit: cover;
                                        top: -100vw;
                                        visibility: visible;
                                        or try this:
                                        Most mirrors tend to be portrait, whereas screens are normally landscape. Normally we could make some changes to /boot/config.txt to easily rotate the screen, but with Raspberry Pi 4’s fancy new graphics support, this is no longer possible. To rotate your display 90º so it fits your mirror, open a Terminal and enter the following:
                                        /etc/xdg/lxsession/LXDE-pi/autostart
                                        Now add this line to the end of the file:
                                        @xrandr --output HDMI-2 --rotate right
                                        Save the file (CTRL+X) and reboot. Your display should now be portrait.
                                        E 1 Reply Last reply
                                        • E
                                          ernade @George
                                          @george
                                          Thank you so much for your quick response and I will try as soon as I have some time.
                                          I will let you know.
                                          Bests
                                            Hi @spitzlbergerj ,
                                            kann ich Dich einmal um Rat fragen ? Du hast ja hier im Forum schon einiges gesehen und einige Projekte hinter Dir. Ich habe seinerzeit einen MM mit einem relativ großen Monitor geplant. Dummerweise den Spiegel etwas zu klein bestellt (Ich wollte einen IR Frame Rahmen mit einbauen). So, jetzt neuen Spiegel bestellt. Hatte aber den Monitor ohne Gehäuse bereits an der Wand hängen (Vesa Mount). Meine Frau war begeistert, weil er so viele interessante Dinge angezeigt hat. Dummerweise hatte aber das LCD Panel dadurch, das ich das Gehäuse (oder zumindest das Cover) entfernt hatte, keinen richtigen Halt. nach 2-3 Wochen fing das LCD Panel sich an zu bewegen auf dem Monitor. Das LCD Panel selber ist ja nur eine sehr dünne Platte. Dahinter liegt dann das gesamte Backlight. Jetzt habe ich auf dem Panel eine Menge bunter Streifen, die wahrscheilich daher entstanden sind, das es verrutscht ist auf dem Backlight Panel. Hast Du mit so etwas Erfahrung. Ich würde halt bevor ich einen neuen Monitor kaufe, versuche den alten zu retten. Danke und Vg Peter
                                            • 3 / 4
