    Bathroom Magic Mirror
    67 Posts 25 Posters 101.2k Views 27 Watching
    • spitzlbergerjS Offline
      spitzlbergerj Project Sponsor Module Developer
      Thanks a lot
      Josef
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
      • T Offline
        tootiemac3
        Thank you for all this info.
        I am at the very start of my magic mirror journey and came across you mirror which is simply fantastic.
        I noticed you had metal LED buttons on the side of your frame which I would like to install one in mine for powering opn/off.
        Having looked at button tutorials I see most are just 2 jumper wires to the GIPO is this the same for your buttons?
        How is the LED powered?
        thanks!
        Vicki
          please forgive the late reply. It slipped through.
          I use these buttons: https://smile.amazon.de/gp/product/B00JSEX1A0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
          These have separate connections for “nomaly closed” NC and “normaly open” NO. And there are also the connections for the button LED.
          But I did not connect the LEDs. Otherwise, besides the LED of the toothbrush and the LED of the mouthwash and the LED of the razor and … another LED would burn. Then I could slowly save the ceiling lighting in the bathroom :-)
          Regards
          Josef
            PeterKatana
            Hi Josef,
            Looks very impressive. Which source do you use for the wooden frame?
            Thanks a lot
            Peter
            spitzlbergerjS 1 Reply Last reply Reply Quote 0
              spitzlbergerj Project Sponsor Module Developer @PeterKatana
              Hi @PeterKatana,
              What do you mean by source?
              The frame is made of beech wood. You can buy it from a wood dealer or carpenter. I have taken solid wood shelf savior made of beech from the hardware store. These are glued rod-wise and therefore torsion-resistant.
              Regards
              Josef
              Regards
              Josef
                PeterKatana @spitzlbergerj
                @spitzlbergerj said in Bathroom Magic Mirror:
                Hi Josef,
                thanks for the recommendation. I will search here for a carpenter. A miter saw I should have. Before I lived in Aschheim, that was easier. Now I am jobwise in Göppingen. Will search around.
                I am curious for your next project you announced.
                Stay safe !
                Br Peter
                  Hallo @PeterKatana,
                  Ich kann dir den Rahmen auch zuschneiden, wenn du mir die Maße sagst. Vielleicht kommst du ja mal nach Oberschleißheim oder in die Nähe.
                  Grüße
                  Sepp
                  Regards
                  Josef
                    SuneRadich
                    Your mirror looks amazing, but I am wondering. How is the electronics holding up, being put in a bathroom with alot of moisture? I cant see you did anything extra to keep moisture out of the mirror?
                      spitzlbergerj Project Sponsor Module Developer @SuneRadich
                      Hi @SuneRadich ,
                      all electrical connections are clamped together in junction boxes for damp locations. The Raspberry Pi is also in such a box. Only the connections of the screen are in their original box, which in my view is not specially protected against moisture.
                      So far, there have been no problems and even if you remove the mirror, you won’t see anything scorched or similar damage.
                      Regards
                      Josef
                      Regards
                      Josef
                        MaXi-XCeL Project Sponsor
                        Just amazing! So well executed. Thank you for the inspiration! :)
                          Servus @spitzlbergerj ,
                          danke für Dein Angebot. Ich habe gestern noch nach Deiner Empfehlung einen Schreiner gefunden. Hoffe, der bekommt das jetzt hin. Falls das nicht klappen sollte, komme ich gern auf Dein Angebot zurück. Ist ja mein erster MM insofern vermute ich, das ich sowieso mit 100 Fragen zurück komme und vielleicht auch den Rahmen wieder verändern muss. Wir werden sehen. Tolle Community übrigens !
                          Grüße Peter
                            @PeterKatana, alles klar, melde dich einfach. Ich werde morgen den MagicAlibert weiterbauen. Die Spiegel sollten nächste Woche kommen ;-)
                            Regards
                            Josef
                              Hallo @spitzlbergerj,
                              eine Frage kommt mir noch in den Sinn: Ich habe meinen Spiegel so designed, dass ich einen IR Frame (Touch Screen) mit verwenden kann. Was ist denn Deine Meinung zu solchen Dingen. Im Bad wahrscheinlich nicht so praktisch, aber ich dachte im Flur, wenn man noch Aktivitäten steuern mag …wie Musik, oder das Display im Karusell …
                              Vielen Dank ! Vg Peter
                                Hi @PeterKatana,
                                im Bad würde ich das nicht machen. Der Woman Acceptance Faktor würde vermutlich rasant in den Keller gehen, wenn auf dem Spiegel ständig “Dapper” (wie man in Bayern sagt) sind.
                                Ich habe einen Spiegel mit einen Standard 7" Raspberry Monitor. Aber selbst da habe ich Touch am Ende nie benutzt. Es sind bei mir einfach InfoSchirme. Aktionen löse ich über Schalter, Taster, … aus.
                                Regards
                                Josef
                                P 2 Replies Last reply Reply Quote 0
                                  Hi @spitzlbergerj ,
                                  Du hast schon Recht. Der Woman Acceptance Factor würde sicher darunter leiden. So richtig viele Anwendungsfälle außer vielleicht Musik steuern oder bei den Nachrichten weiterschalten fallen mir auch nicht ein. Mal schaun. Ich bau das mal zusammen mit dem IR Frame. Vielleicht entstehen da noch Szenarien, wo es sinnvoll ist.
                                  Danke für Deine Einschätzung !
                                  Vg Peter
                                  • E Offline
                                    ernade @spitzlbergerj
                                    Beech wood
                                    Hi, A really nice work.
                                    could I ask you how do you rotate the imageod the screen in portrait?
                                    I am havin some difficulty to let’s happen in my screen. It goes to blue screen (of course not Windows blue screen).
                                    Raspeberry 4 B
                                    • G Offline
                                      George @ernade
                                      @ernade Hi, try this in custom.css file:
                                      body {
                                      margin: 0;
                                      position: absolute;
                                      transform: rotate(90deg);
                                      transform-origin: bottom left;
                                      width: 100vh;
                                      height: 100vw;
                                      object-fit: cover;
                                      top: -100vw;
                                      visibility: visible;
                                      or try this:
                                      Most mirrors tend to be portrait, whereas screens are normally landscape. Normally we could make some changes to /boot/config.txt to easily rotate the screen, but with Raspberry Pi 4’s fancy new graphics support, this is no longer possible. To rotate your display 90º so it fits your mirror, open a Terminal and enter the following:
                                      /etc/xdg/lxsession/LXDE-pi/autostart
                                      Now add this line to the end of the file:
                                      @xrandr --output HDMI-2 --rotate right
                                      Save the file (CTRL+X) and reboot. Your display should now be portrait.
                                      • E Offline
                                        ernade @George
                                        @george
                                        Thank you so much for your quick response and I will try as soon as I have some time.
                                        I will let you know.
                                        Bests
                                          Hi @spitzlbergerj ,
                                          kann ich Dich einmal um Rat fragen ? Du hast ja hier im Forum schon einiges gesehen und einige Projekte hinter Dir. Ich habe seinerzeit einen MM mit einem relativ großen Monitor geplant. Dummerweise den Spiegel etwas zu klein bestellt (Ich wollte einen IR Frame Rahmen mit einbauen). So, jetzt neuen Spiegel bestellt. Hatte aber den Monitor ohne Gehäuse bereits an der Wand hängen (Vesa Mount). Meine Frau war begeistert, weil er so viele interessante Dinge angezeigt hat. Dummerweise hatte aber das LCD Panel dadurch, das ich das Gehäuse (oder zumindest das Cover) entfernt hatte, keinen richtigen Halt. nach 2-3 Wochen fing das LCD Panel sich an zu bewegen auf dem Monitor. Das LCD Panel selber ist ja nur eine sehr dünne Platte. Dahinter liegt dann das gesamte Backlight. Jetzt habe ich auf dem Panel eine Menge bunter Streifen, die wahrscheilich daher entstanden sind, das es verrutscht ist auf dem Backlight Panel. Hast Du mit so etwas Erfahrung. Ich würde halt bevor ich einen neuen Monitor kaufe, versuche den alten zu retten. Danke und Vg Peter
                                            @peterkatana
                                            hallo Peter, damit habe ich leider recht wenig Erfahrung. Ich hatte zwar mal einen Monitor, der Farbstreifen produzierte, das geschah aber, als ich ihn in die Aussparung meiner AluDibond Platte einsetzte. Die Aussparung war an den Ecken zu eng und so habe ich das Panel beim Reindrücken beschädigt. Sowas ist praktisch nicht mehr zu heilen.
                                            So wie ich Deinen Bericht lese, denke ich auch, dass es das Panel verzogen hat. Dann ist vermutlich nicht mehr viel zu retten. Aber wie gesagt, da bin ich Laie.
                                            Vielleicht findest du in einem PC-Hardware Forum jemanden, der dir das genauer sagen kann.
                                            Sorry, dass ich da nicht weiterhelfen kann.
                                            Viele Grüße
                                            Sepp
                                            Regards
                                            Josef
                                            • 3 / 4
