    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 697.6k Views 57 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @j.e.f.f
      @j-e-f-f said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
      @swvalenti yes you can. The weather alerts are part of the summary section. OpenWeather returns such a short summary that I didn’t think it necessary to make two separate configure. Two ways to turn off the alerts:
      • set summary : false
      • if you want the summary but not the alerts, you can hide them in your custom css as follows:
      .MMM-OpenWeatherForecast .weather-alert {
        display: none;
      I think I’ll look at a way to truncate weather alerts so they don’t take up so much space.
      Awesome thanks @j-e-f-f !
        dkhorse74 @j.e.f.f
        @j-e-f-f
        Thanks Jeff!!
          shiryu1031 @j.e.f.f
          @j-e-f-f I see, thank you for your help. I thought it can be done because the example picture on Github is in km/h, but for myself, I am only seeing m/s as you mentioned. I guess it can not be change from m/s to km/h?
          • karsten13K Offline
            karsten13 @j.e.f.f
            @j-e-f-f
            I don’t think there is much I can do here.
            yes, I’m aware of this. Sent a mail to openweathermap.org and will let you know if I ever get a response …
            • O Offline
              OberfragGER @karsten13
              Did anyone have an idea how to chage the timeformat from sundown?
              Now its displayed: 6:20… i want to have 18:20
              I already changed the rest.
                karsten13 @OberfragGER
                @oberfragger
                label_sunriseTimeFormat: "k:mm",
                • O Offline
                  @karsten13 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                  label_sunriseTimeFormat: “k:mm”,
                  Not working: :(
                  			iconset: "3c",
                  			label_hourlyTimeFormat: "k[ Uhr]",
                  			label_sunriseTimeFormat: "hh:mm",
                  			label_sunsetTimeFormat: "k:mm",
                  			label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"]
                  i also tried:
                  label_sunsetTimeFormat: "hh:mm",
                  also not working. The sunset on top is still not in german timeformat.
                  karsten13K J 2 Replies Last reply Reply Quote 0
                    @oberfragger said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                    there is no property label_sunsetTimeFormat, only label_sunriseTimeFormat, remove the not existing one …
                      j.e.f.f Project Sponsor Module Developer @OberfragGER
                      @oberfragger
                      There is only one property that is used for both sunrise and sunset: label_sunriseTimeFormat. In your example above, you’ve specified hh:mm for this property, which displays 12h time, not 24h time.
                      Change your config from this:
                      iconset: "3c",
                      to this:
                      iconset: "3c",
                      label_sunriseTimeFormat: "k:mm",  // change the format for this one
                      O 1 Reply Last reply Reply Quote 1
                        j.e.f.f Project Sponsor Module Developer @shiryu1031
                        @shiryu1031 The screenshots you see in GitHub were incorrect. My old code for Dark Sky was using km/h, and I hadn’t replaced the label with m/s when I took these screen shots. So the screenshots are actually illustrating a bug! The actual speed value shown is m/s, but the label is incorrect as km/h. :beaming_face_with_smiling_eyes:
                        I thought about it, and it would take me just as much time to fix the screen shots as it would to add the capability to convert m/s into km/h. So now there is a new config parameter: displayKmhForWind. If you add this to your config and set it to true, m/s wind speed will be converted and displayed as km/h. This parameter only works when units is set to "metric" or "standard". If you’re using "imperial" you will always see mph.
                        Do a git pull in your installed MMM-OpenWeatherForecast directory to get the updated code.
                          j.e.f.f Project Sponsor Module Developer @swvalenti
                          @swvalenti I’ve made a modification that now truncates alerts to no more than 3 lines of description. This is controlled with CSS so if you’ve like to adjust this for more or less lines, you can do so in your custom CSS file as follows:
                          .MMM-OpenWeatherForecast .weather-alert .weather-alert-description {
                            -webkit-line-clamp: 3; /* adjust this as desired */
                          do a git pull in your installed MMM-OpenWeatherForecast directory to get the latest code.
                          swvalentiS 1 Reply Last reply Reply Quote 0
                          • O Offline
                            OberfragGER @j.e.f.f
                            @j-e-f-f Thx a lot! Its working now as expected.
                              @j-e-f-f thanks bro!
                                mielu80
                                It is somehow possible to show the unit of measurement for the temperature (in my case, “C” for Celsius) ?
                                Thank you.
                                swvalentiS J 2 Replies Last reply Reply Quote 0
                                  swvalenti Project Sponsor @mielu80
                                  @j-e-f-f Last thing is it possible to just get the red to display and nothing else? Yea that’s right it’s FN 69 out here in NJ!
                                    karsten13
                                    concerning the duplicate weather alerts and mix up between german and english I got an answer from openweathermap.org:
                                    Currently we receive data in such format from the provider. The development team is working on the new version of alerts, which should eliminate such behavior.
                                      j.e.f.f Project Sponsor Module Developer @mielu80
                                      @mielu80 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                      Yes. You can do that in your custom.css file.
                                      For the big current temperature display:
                                      .MMM-OpenWeatherForecast .current-conditions-wrapper .current.temperature:after {
                                          content: "C";
                                      In the extra current conditions Hi/Lo display:
                                      .MMM-OpenWeatherForecast .extra-current-conditions-wrapper  . temperature-container . high-temperature:after,
                                      .MMM-OpenWeatherForecast .extra-current-conditions-wrapper  . temperature-container . low-temperature:after {
                                          content: "C";
                                      In the hourly forecast items:
                                      .MMM-OpenWeatherForecast .forecast-item.hourly .temperature-container:after {
                                          content: "C";
                                      In the daily forecast Hi/Lo display:
                                      .MMM-OpenWeatherForecast .forecast-item.daily .high-temperature:after,
                                      .MMM-OpenWeatherForecast .forecast-item.daily .low-temperature:after {
                                          content: "C";
                                      In all of the examples above, whatever you specify for content will be displayed. So if you wanted F for Fahrenheit, you would specify content: "F";
                                        @swvalenti said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                        Yes, you can do this in your custom.css file.
                                        To hide the description and alert source:
                                        .MMM-OpenWeatherForecast .weather-alert .weather-alert-description,
                                        .MMM-OpenWeatherForecast .weather-alert .weather-alert-source {
                                            display: none;
                                        To change the size of the red title text:
                                        .MMM-OpenWeatherForecast .weather-alert .weather-alert-title {
                                           font-size: 17px; /* adjust this */
                                        alternatively, to change the size of the alert icon:
                                            background-size: 30px 26px;  /* width height */
                                            background-position: 6px 10px;  /* top left */
                                        If you change the size of the icon, you may want to adjust the title padding as well:
                                          padding-left: 36px; /* adjust this */
                                        EVERYTHING is in this module has a CSS class applied to it so you can tailor every last little bit to your specific needs. Take a look at MMM-OpenWeatherForecast.css for existing CSS rules and mmm-openweather-forecast.njk to see what classes have been applied to which UI elements.
                                          julien-vancouver
                                          Just a quick thanks for the module !
                                            pwalsh2202
                                            I’m looking to see if I can get just a truncated text-based description of the upcoming weather.
                                            When I search for a location on the openweathermap.org site, I do see the site gathers this data “Heavy intensity rain. Moderate breeze. The high will be 68°F, the low will be 50°F.”, which is exactly what I’m looking to display on my mirror, but I don’t see how this might be communicated via the API.
                                            On OWM’s page, I don’t even see this data provided in the sample API calls provided. Is there a way for your module to provide this data or does this require one of the paid APIs? Thank you for all of the effort you’ve put into this.
                                            • 12
                                            • 13
                                            • 3 / 13
