    updated installer script available for testing
    211 Posts 18 Posters 319.4k Views 19 Watching
      bdream
      then I will start thinking update to Windows10, latest in case I get trouble with MM 2.6.0
      cheers, bdream
        sdetweil @bdream
        @bdream 2.9 is current version.
          bdream
          that is, why I wnated to update to 2.9
          cheers, bdream
            sdetweil @BD0G
            @BD0G said in Anyone want to try updated installer...:
            XXABI_1.3.9’ not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: versionGLIBCXX_3.4.21’
            I have found a fix, allowing jessie to continue to work… added fix to latest installer…
            thanks for your help
            • swvalentiS Offline
              swvalenti Project Sponsor
              Tried using the updated install script but get this error. I did killall node
              and it said that node: no process found
              install log being saved to /home/pi/MagicMirror/installers/install.log
              No LSB modules are available.
              Updating packages ...
              Installing helper tools ...
              Reading package lists... Done
              Building dependency tree
              Reading state information... Done
              build-essential is already the newest version (12.3).
              curl is already the newest version (7.52.1-5+deb9u9).
              git is already the newest version (1:2.11.0-3+deb9u4).
              unzip is already the newest version (6.0-21+deb9u2).
              wget is already the newest version (1.18-5+deb9u3).
              The following packages were automatically installed and are no longer required:
                coinor-libipopt1v5 libcommon-sense-perl libdbi1 libencode-locale-perl
                libfile-which-perl libhttp-daemon-perl libhttp-date-perl
                libhttp-message-perl libio-html-perl libipc-sharelite-perl libjson-perl
                libjson-xs-perl liblwp-mediatypes-perl libmumps-seq-4.10.0 libraw15 librrd8
                librrds-perl libtimedate-perl libtypes-serialiser-perl liburi-perl realpath
              Use 'sudo apt autoremove' to remove them.
              0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
              Check current Node installation ...
              Node currently installed. Checking version number.
              Minimum Node version: v10.1.0
              Installed Node version: v9.11.2
              Node should be upgraded.
              A Node process is currently running. Can't upgrade.
              Please quit all Node processes and restart the installer.
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $ killall node
              pi@raspberrypi:~ $
                sdetweil @swvalenti
                @swvalenti the code is doing a
                pgrep "node"
                to test, do
                ps -ef | grep node
                so, they are usually running as /usr/bin/node, killall won’t kill those
                swvalentiS 1 Reply Last reply Reply Quote 0
                  swvalenti Project Sponsor @sdetweil
                  @sdetweil said in Anyone want to try updated installer...:
                  ps -ef | grep node
                  pi@raspberrypi:~ $ ps -ef | grep node
                  pi        5623  5392  0 13:11 pts/0    00:00:00 grep --color=auto node
                  pi       19082   648  0 Nov12 ?        00:51:53 node /home/pi/node-sonos-http-api/server.js
                  I dont even have this module anymore I thought it was deleted…what do I need to do in order to make the update work?
                    sdetweil @swvalenti
                    @swvalenti said in Anyone want to try updated installer...:
                    19082
                    kill -9 19082
                      Still won’t work did the kill command
                      pi@raspberrypi:~ $ kill -9 19082
                      pi@raspberrypi:~ $
                      pi@raspberrypi:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                              \______/
                      pi@raspberrypi:~ $
                      bash: kill: (19082) - No such process
                      pi@raspberrypi:~ $
                                              \______/
                      pi@raspberrypi:~ $
                      pi@raspberrypi:~ $
                        sdetweil @swvalenti
                        @swvalenti looks like it gets restarted…
                        again… you killed it before u ran installer
                        ps -ef | grep node
                          @sdetweil that is correct, can I somehow delete this node process as I don’t even use that module anymore?
                            sdetweil @swvalenti
                            @swvalenti yes, somehow… I don’t know how it got added…
                            can u do a
                            pm2 status
                              pi@raspberrypi:~ $ pm2 status
                              │ Name        │ id │ mode  │ status │ ↺       │ cpu │ memory │
                              │ mm          │ 1  │ N/A   │ fork   │ stopped │ 176 │ 0%     │ 0 B       │
                              │ omx_stream1 │ 2  │ N/A   │ fork   │ stopped │ 61  │ 0%     │ 0 B       │
                              │ omx_stream2 │ 3  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                              │ omx_stream3 │ 4  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                              │ server      │ 0  │ 1.6.5 │ fork   │ online  │ 3   │ 0.4%   │ 40.0 MB   │
                               Use `pm2 show <id|name>` to get more details about an app
                              pi@raspberrypi:~ $
                                sdetweil @swvalenti
                                @swvalenti i would guess server
                                pm2 stop server
                                  @sdetweil Awesome that worked thanks Sam!
                                    sdetweil @swvalenti
                                    @swvalenti cool… maybe I should dump out the ps -ef list if I find that problem…
                                      @sdetweil So I renamed the old magicmirror folder and updated. Now the updates stripped modules and config.js. They are not in the new magicmirror folder at all…what gives?
                                        sdetweil @swvalenti
                                        @swvalenti this is not an update, it is a NEW install…
                                        so you have to copy from the old mm folder to the new…
                                        if u wanted to UPDATE then u should run the UPDATE script
                                        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                                          @sdetweil Well I am an idiot, so I can just delete the new MagicMirror folder and then run the update in the other?
                                            sdetweil @swvalenti
                                            @swvalenti yes… UPDATE just gets you the new MagicMirror version. currently 2.9.0
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 7 / 11
