    new update/upgrade script, ready for testing
    328 Posts 27 Posters 702.0k Views 24 Watching
      sdetweil @satsatt
      @satsatt ok, was gonna ask for this
      alias git='LANGUAGE=en_US.UTF-8 git"
      git status
      unalias git
        satsatt
        @sdetweil said in new update/upgrade script, ready for testing:
        unalias git
        uh not ok
        pi@raspberrypi:~/MagicMirror $ alias git='LANGUAGE=en_US.UTF-8 git"
        > git status
        > unalias git
          sdetweil @satsatt
          @satsatt sorry, bad paste
          alias git='LANGUAGE=en_US.UTF-8 git'
          git status
          unalias git
            satsatt
            git status
            pi@raspberrypi:~/MagicMirror $ git status
            On branch master
            Your branch is behind 'origin/master' by 2639 commits, and can be fast-forwarded.
              (use "git pull" to update your local branch)
            Changes to be committed:
              (use "git reset HEAD <file>..." to unstage)
            	modified:   package-lock.json
            	modified:   vendor/package-lock.json
            Untracked files:
              (use "git add <file>..." to include in what will be committed)
            	installers/dumpactivemodules.js
              sdetweil @satsatt
              @satsatt great!.. thank you… can u try the update script again
                satsatt
                pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                doing test run = false
                update log will be in /home/pi/MagicMirror/installers/upgrade.log
                saving custom.css
                apply: Zeile 88: alias: git: Nicht gefunden.
                upgrading from version 2.6.0 to 2.8.0
                fetching latest revisions
                error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                überschrieben werden:
                package-lock.json
                Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                Abbruch
                there were merge errors
                you should examine and resolve them
                using the command git log --oneline --decorate
                de57daa (grafted, HEAD -> master, tag: v2.6.0) Merge pull request #1498 from MichMich/develop
                restoring custom.css
                apply: Zeile 256: [: ~=: Zweistelliger (binärer) Operator erwartet.
                  satsatt
                  sorry need to be away from terminal for 10h - thank’s alot
                    sdetweil @satsatt
                    @satsatt ok, when u have time , try the script again… thanks SO much for your help
                    • BKeyportB Offline
                      BKeyport Module Developer
                      Love this concept - question though - from what I’ve read (bits and pieces admittedly), it looks like it only handles the main software - could this be expanded to traverse your module directories and update them, so it could be run, say nightly, to check for and apply updates to everything?
                        rabbit83ka
                        Hi, great work! I Just used the script to update to 2.9.0 - the only thing I had to do manually was a
                        git reset --hard
                        before running the script (and afterwards restoring my backup of custom.css).
                          sdetweil @BKeyport
                          @BKeyport it could… it does traverse the modules already, but it currently only does the npm install part (to update to the current runtime dependencies) … but I could extend it easily to check for module updates (like the updatenotifier default module does) , and apply those
                          i am trying to get this tested so we can get it into the base (and off of my dropbox)
                            sdetweil @rabbit83ka
                            @rabbit83ka u should not have had to do the git reset --hard… please tell me why?
                            and my script saves and restores custom.css too
                              bhepler Module Developer
                              I just gave this a try on my house mirror. I didn’t apply and received the following output:
                              doing test run = true
                              saving custom.css
                              bash: line 92: [: !=: unary operator expected
                              upgrading from version 2.8.0 to 2.9.0
                              there are 1 local files that are different than the master repo
                                 package-lock.json
                              any *-lock.json files do not need to be saved
                              do you want to save these files for later   (Y/n)?n
                              skipping restore for package-lock.json, doing test run
                              processing dependency changes for active modules with package.json files
                              processing for module MMM-MovieListings . please wait
                              skipped processing for MMM-MovieListings, doing test run
                              processing for module MMM-Ring . please wait
                              skipped processing for MMM-Ring, doing test run
                              processing for module MMM-DarkSkyForecast . please wait
                              skipped processing for MMM-DarkSkyForecast, doing test run
                              bash: line 260: [: !=: unary operator expected
                              This seems wrong. What can I do to help?
                                sdetweil @bhepler
                                @bhepler ok, try again, fixed… assumed locale was set, wasn’t
                                • BKeyportB Offline
                                  @sdetweil I will clearly keep it watched… thanks for the info!
                                    rabbit83ka @sdetweil
                                    @sdetweil Same error than @satsatt
                                    I had to restore custom.css because the git-reset deleted it (script backed up custom.css correctly).
                                      @rabbit83ka hm… can u send me the install.log? same userid as here on gmail
                                      i fixed the error that @satsatt had (or so I thought)
                                      i check for english locale, if not set or not current, I add an alias to use english to get the right message output
                                      then restore the the alias or remove it…
                                        @rabbit83ka said in new update/upgrade script, ready for testing:
                                        yes, starting with version 2.9.0 they will no longer track it so changes should not be lost…
                                        I will leave the save/restore in
                                          Used your update/upgrade script last night. No issues. Thank you, Sam. :thumbsup:
                                          MM 2.8.0 -> 2.9.0
                                          Ubuntu 18.04.3
                                            sdetweil @Mykle1
                                            @Mykle1 cool… did u have extra modules also ?
                                            • 16
                                            • 17
                                            • 3 / 17
