    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 403.6k Views 51 Watching
    • PointPubMediaP Offline
      PointPubMedia @ostfilinchen
      @ostfilinchen Already did my git pull this morning…
      lolobyteL 1 Reply Last reply Reply Quote 0
      • cowboysdudeC Offline
        cowboysdude Module Developer @ostfilinchen
        @ostfilinchen All that will do is download the upper image files… not the icons.
        You have to add that your custom.css like in the example above.
        The icons are pretty standard and used in, I think, every weather module here… they are icons outside the module and are not included…so you have to colorize them yourself.
        • O Offline
          ostfilinchen @cowboysdude
          @cowboysdude no. If you Set the Parameter coloricon to true, all weather Icons shown colored. I have nothing Set in my custom.css. all colorsets Come from weatherunderground.css
          • lolobyteL Offline
            lolobyte @PointPubMedia
            @PointPubMedia
            same issue.
            The Day forecast doesn’t show the cloud’s as picture.
            • RedNaxR Offline
              RedNax Module Developer
              Just pushed a new version which fixes all this. Give it a try!
              lolobyteL 1 Reply Last reply Reply Quote 2
              • lolobyteL Offline
                lolobyte @RedNax
                @RedNax
                All looks good. Thank you for your fast reaction.
                • C Offline
                  c502
                  @RedNax Thanks for the awesome module. I do have one question however…
                  Is there a way to change the current Beaufort wind speed to mph?
                  RedNaxR 1 Reply Last reply Reply Quote 1
                  • RedNaxR Offline
                    RedNax Module Developer @c502
                    @c502
                    Hi!
                    Pull the new version and add
                    windunits: "mph",
                    to your config…
                      Mykle1 Project Sponsor Module Developer @RedNax
                      @RedNax
                      This is a stunningly beautiful and informative module and the many config options must make it a favorite of anyone that uses it. I tip my hat to you.
                      With that, may I make a humble request regarding fctext? I love this option but it can change from 3 lines to as many as 7 lines. Would it be possible to limit, or set, the amount of lines displayed. Or, could the text decrease in size as more information needs to be displayed, taking up the same amount of space?
                      RedNaxR 1 Reply Last reply Reply Quote 0
                      • RedNaxR Offline
                        RedNax Module Developer @Mykle1
                        @Mykle1 Hi,
                        Thank you for your kind words. I’ve now pushed a version that will dynamically scale the fontsize/line length of the forecast text. Give it a go! :D
                        O Mykle1M 2 Replies Last reply Reply Quote 0
                        • O Offline
                          ostfilinchen @RedNax
                          @RedNax now it don’t Looks good:
                          the FC-Text goes above the lines. Can u please check this?
                          • RedNaxR Offline
                            Doesn’t seem to happen on my setup…
                            Is your issue that the % sign is on a seperate line?
                            0_1487331607607_upload-38ed4333-3e1c-4b88-ac81-22ecf1a8ca03
                            O 2 Replies Last reply Reply Quote 0
                            • O Offline
                              @RedNax no. The lines under and above the forecasttest are not toll the right side of the text.
                                @RedNax said in Weatherunderground - currently - hourly - daily - configurable:
                                I have to run off to work right now but I will “give it a go” as soon as I get home. I’ll let you know. Thanks for this.:thumbsup:
                                • O Offline
                                  @RedNax i can’t say why but now after a while, it looks correct.
                                  • RedNaxR Offline
                                    RedNax Module Developer @ostfilinchen
                                    @ostfilinchen There’s a new version. I left my test in which just used metric. Imperial users wouldn’t be happy. I’ve also added trim to the wordwrap function so here aren’t any trailing spaces
                                      bminer1
                                      Im still only getting the Icons. How do i get those nicer pictures?
                                      • strawberry 3.141S Offline
                                        strawberry 3.141 Project Sponsor Module Developer @bminer1
                                        @bminer1 Did you try coloricon: true?
                                        B 2 Replies Last reply Reply Quote 0
                                          bminer1 @strawberry 3.141
                                          @strawberry-3.141
                                          I swear you guys are way too talented! Fixed.
                                            @strawberry-3.141 Im sure you can help me out with something else. The wind direction in the forecast is pushing the module really far into the center of the screen. Is there a way i can change the forecast wind direction to shrink it up a bit? Everything at the top seems to be really far in space. I know i could always go back to the vertical but i like the horizontal too.
                                            strawberry 3.141S RedNaxR 2 Replies Last reply Reply Quote 0
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 5 / 10
