    Fresh Install
    49 Posts 6 Posters 20.1k Views 6 Watching
      sdetweil @johnnyboy
      @johnnyboy hit enter, add a new line, type the text, hit ctrl-o to save, ctrl-x to exit
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @sdetweil
        do i enter # before text, same as everything else in there or simply that text on its own?
        johnnyboyJ S 2 Replies Last reply Reply Quote 0
          johnnyboy @johnnyboy
          @johnnyboy
          display_rotate=1
          Then I click on Ctrl o… and it asks "file name to write: boot/config.txt
            sdetweil
            @sdetweil needs to be /boot/config.txt
              sdetweil @johnnyboy
              @johnnyboy # is a comment, so whatever is after # on that line is ignored
                johnnyboy @sdetweil
                Yeah… the text that says " File name to write: /boot/config.tx"
                That is hard written in grey… below that it gives options… G get help C cancel M-D Dos Format M-M Mac format M-A Append M-P Prepend M-B Backup file ^ to files
                  sdetweil @johnnyboy
                  @johnnyboy yes, just confirming the filename, you can change it if u need to… you can edit a NEW file and have NO name specified in advance…
                    johnnyboy @sdetweil
                    @sdetweil said in Fresh Install:
                    So how do i proceed? If I click ^cancel, i go back to my entry… then as soon as i click ^o to save, it goes to thst part that says file name…
                    I cannot save and exit past there.
                    I cannot hit ^x to exit as it wont work there… as if i need to select an option from the boxes below… I can only select ^c to cancel and go back.
                      sdetweil @johnnyboy
                      @johnnyboy you hit enter
                      then it saves the file
                      then u hit ctrl-x to exit the editor
                        johnnyboy @sdetweil
                        Ok… but I just re-booted… then back into terminal… back into boot config.txt… and there is display_rotate=1 right at very top of the config.txt window in terminal…
                        I also looked into File Manager - Boot - and see there is another 2 x saved copys of config.txt docs…
                        So it seems it did save, but not executed to portrait on re-boot?
                          sdetweil @johnnyboy
                          @johnnyboy ok, I can’t help with that. I searched for instructions and passed them along… I don’t have any portrait on pi… I do on ubuntu, but they have a UI that does it live… click, push a button
                            display_rotate=1
                            Isn’t display_rotate=1 landscape? Wouldn’t portrait be display_rotate=0?
                            scratching my head
                              sdetweil @Mykle1
                              @Mykle1 pages says
                                My bad. Senior moment. :-)
                                  johnnyboy @Mykle1
                                  @Mykle1
                                  😔… oh well… my new lease of life with my MM was very short lived.
                                  My mirror is fixed in portrait… so having the system in Lanscape is of no use to me at all.
                                  Surely not every user here is using MM in Landscape?
                                    sdetweil @johnnyboy
                                    @johnnyboy no… just that we TWO don’t know how to fix it…
                                      johnnyboy @sdetweil
                                      Ok… well can only thank you for your great help on this… at least I have an updated Pi.
                                      Should I start a new thread asking about portrait mode? Doubt everyone is reading this thread and would comment on how to achieve that?
                                        sdetweil @johnnyboy
                                        @johnnyboy updated pi? did u use my upgrade script?
                                          johnnyboy @sdetweil
                                          Ahhhhhhh… no, only the install… i shall go and see the upgrade script now.
                                            sdetweil @johnnyboy
                                            @johnnyboy install is for new, upgrade is for previous installed, get to latest
                                            so you would have to rename the folders back before trying
                                            we have a version update every 3 months… you can imagine the trouble folks run into
                                            • 2 / 3
