    MMM-Remote-Control after upd MM to 2.1.0
    14 Posts 6 Posters 12.1k Views 6 Watching
    • L Offline
      lolobyte
      when i choose “edit modules” the MMM-Remote-Control does’t show any module.
      It mean there are no modules loaded. But more than 6 modules are running at the mirror.
      Any ideas?
        schlachtkreuzer6
        did you update the dependencies?
          Steff
          Just did the update with git pull && npm install, I can report that at least my MMM-Remote-Control works exactly as beforehand, showing all modules.
          • L Offline
            lolobyte @schlachtkreuzer6
            @schlachtkreuzer6
            I only made a
            git pull
            and the answer was.
            Already up-to-date.
              schlachtkreuzer6 @lolobyte
              @lolobyte git pull && npm install ?
              L 2 Replies Last reply Reply Quote 0
              • L Offline
                @schlachtkreuzer6
                i have now also done the npm install in the remote control folder…
                The issue remain.
                I’ll try a comlete new install of the module! :-(
                  @lolobyte nonono you need to npm install the hole thing ^^ wait take a look here: https://forum.magicmirror.builders/topic/1306/v2-1-x-updates
                  • L Offline
                    @schlachtkreuzer6
                    The problem remains.
                    pm2 logs mm, doesn’t give me a real answer about the issue.
                      jean_pol56
                      I had the same problem.
                      I deleted the option: “disabled” (Set disabled to true to skip creating the module.) ) in my modules and everything works , MMM-Remote-Control show modules.
                      • L Offline
                        lolobyte @jean_pol56
                        @jean_pol56
                        YES, damn, more than 2 hours wasted wit this issue.
                        If you un-comment the “disabled: true.” argument, your remote module won’t work correctly.
                        If you change the status from “true” to “false”, your remote module works again.
                                            module: 'helloworld',
                                            position: 'bottom_bar',
                                            classes: 'small bright', // Add your own styling. Optional.
                                    //      disabled: true, // verursacht Fehler in MMM-Remote-Control Modul
                                                    text: 'TEST TEST TEST!',
                          AAPS
                          Why is this necessary? Do I only need to do it for the “helloworld” module?
                          • L Offline
                            lolobyte @AAPS
                            @AAPS
                            Hello,
                            No, it’s surly only a example for one Module.
                            It was my intention with the command
                            disabled: true,
                            to quick disable a module in the config.js and not to comment out all single module step.
                            The problem with the remote module is, the modules aren’t really disabled, they running in the background an slow down the system.!
                              Jopyth Moderator
                              Does anyone know, what causes the problem? How do I reproduce the issue? Just a random config with one module disabled? If someone has a working small example (config), please post here or in the github issue.
                              I will see if I can fix it on the weekend.
                              Helpful sticky: How to troubleshoot
                              • L Offline
                                lolobyte @Jopyth
                                @Jopyth
                                This system doesen’t let me upload some file for you.
                                The this way.
                                Here is the sample config with issues.
                                /* Magic Mirror Config Sample
                                • By Michael Teeuw http://michaelteeuw.nl
                                • MIT Licensed.
                                var config = {
                                port: 8080,
                                ipWhitelist: [
                                “127.0.0.1”,
                                “::ffff:127.0.0.1”,
                                “::1”,
                                “::ffff:192.168.1.1/24”,
                                language: ‘de’,
                                timeFormat: 24,
                                units: ‘metric’,
                                		module: 'alert',
                                		disabled: false,
                                		module: "updatenotification",
                                		position: "top_center",
                                		disabled: false,
                                		module: 'MMM-Advent',
                                		position: 'bottom_center',
                                		disabled: true,
                                			updateInterval: 10 * 60 * 1000,
                                			marks: 0, //default is 24
                                			height: 300,
                                			showFlameBeforeStart: false,
                                //			start: ["2016-11-27 00:00:01", "2016-12-11 00:00:01", "2016-12-18 00:00:01", "2016-12-04 00:00:01"],
                                //			end: ["2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59"],
                                			start: "2016-01-01 00:00:01", //Geburtstag Anfang
                                			end: "2016-01-01 23:59:59", //Geburtstag Ende
                                //			start: "2016-12-01 00:00:01", //Eine Kerze; default is "2016-12-01 08:00:00"
                                //			end: "2016-12-24 23:59:59", //Eine Kerze; default is "2016-12-24 22:00:00"
                                			enableAnimation: true,
                                			fontColor: "#000000", //default is #000000 (black)
                                			candleColor: "#FFFFFF", //default is #FFFFFF (white)
                                		disabled: true,
                                			text: 'Alles Gute!',
                                		module: 'clock',
                                		position: 'top_left',
                                		disabled: false,
                                			displaySeconds: true,
                                			clockBold: false,
                                			showDate: true,
                                			displayType: 'digital', // Possible values: digital, analog, or both
                                			analogSize: '190px',
                                			analogFace: 'face-012', // 'simple' border, none, or face-### (value between 001 and 012)
                                			analogPlacement: 'right', // top, right, bottom, or left
                                			analogShowDate: 'top', // false, top or bottom
                                			secondsColor: '#888888', // any HTML RGB Color
                                	//		timezone: 'Etc/GMT+10', // America/New_York, America/Santiago, Etc/GMT+10
                                		module: 'MMM-Remote-Control',
                                		disabled: false,
                                	//	uncomment the following line to show the URL of the remote control on the mirror
                                		position: 'top_center'
                                	//	you can hide this module afterwards from the remote control itself
                                if (typeof module !== ‘undefined’) {module.exports = config;}
                                and this one wich is running.
                                • MIT Licensed.
                                var config = {
                                port: 8080,
                                ipWhitelist: [
                                “127.0.0.1”,
                                “::ffff:127.0.0.1”,
                                “::1”,
                                language: ‘de’,
                                timeFormat: 24,
                                units: ‘metric’,
                                		module: 'alert',
                                		disabled: false,
                                		disabled: false,
                                			height: 300,
                                		module: 'clock',
                                		disabled: false,
                                			clockBold: false,
                                			showDate: true,
                                		disabled: false,
                                [0_1483538699038_config.js.bak-abgespeckt_01](Uploading 100%)
                                [0_1483538731854_config.js.bak_abgespeckt_02](Uploading 100%)
