    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 687.7k Views 57 Watching
      bassin12 @sdetweil
      When I try the code in the config.js I get this in the logs
      [29.08.2022 10:22.03.630] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:22 ** ERROR ** null
      [29.08.2022 10:22.03.639] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 10:22 ** ERROR ** Error: Request failed with status code 401
        sdetweil @bassin12
        @bassin12 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
        yes, bug in his code…
        use the code I posted on page one to extend the error reporting
        but it returns 401 as well…
          DDE12
          Is there a solution for this error? Is it something I’ve done or something in the module code?
          [MMM-OpenWeatherForecast] 12-Nov-22 23:49 ** ERROR ** Error: Request failed with status code 401
            sdetweil @DDE12
            @DDE12 401 eror is unauthorized
            so the apikey you are using has expired
              DDE12 @sdetweil
              I setup the default weather module with OpenWeather and it is working with the key I have. I obtained the key a few days ago. Is it the same key for MMM-OpenWeatherForecast?
                sdetweil @DDE12
                @DDE12 no idea
                the module says go here
                https://home.openweathermap.org/users/sign_up
                the default weather openWeathermap provide says
                https://home.openweathermap.org/users/sign_in
                so it would seem the same key
                the module uses this path
                https://api.openweathermap.org/data/2.5/onecall?"
                the default module uses this
                		apiVersion: "2.5",
                		apiBase: "https://api.openweathermap.org/data/"
                                        +apiVersion+"onecall?"
                so, they appear the same
                  DDE12 @sdetweil
                  I put in a new key just to see but still have the same 401 error. When I installed the module I got
                  npm WARN old lockfile
                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                  added 4 packages, and audited 391 packages in 50s
                  1 package is looking for funding
                    run `npm fund` for details
                  39 vulnerabilities (2 low, 15 moderate, 19 high, 3 critical)
                  To address all issues, run:
                    npm audit fix
                  Run `npm audit` for details.
                  I did not run audit fix. Is there something that I need to do with the install?
                    sdetweil @DDE12
                    @DDE12 NEVER run audit fix…
                    i don’t know why the MMM-OpenWeatherForecast is failing ,
                    other than it says unauthorized. i would open an issue for the author.
                      j.e.f.f Project Sponsor Module Developer
                      @DDE12 Could you share your config? Also be sure put your API key in quotes in the configuration. If you aren’t using quotes, this could be a reason why the module is giving you the 401 error
                        DDE12
                        @j-e-f-f
                        I can, but I think I figured it out last night without changing anything in MM or the module. I initially signed up for the free account on OpenWeatherMap. Last night I signed up for the One Call by Call https://openweathermap.org/api and MMM-OpenWeatherForecast starting working. Before signing up, I tested my API in a browser at https://api.openweathermap.org/data/2.5/onecall?lat=someLatitude&lon=someLongitude&appid=secretAPI
                        and at https://api.openweathermap.org/data/3.0/onecall?lat=someLatitude&lon=someLongitude&appid=secretAPI
                        and both reported 401 error. After signing up, the module began working in MM. This does require a credit card and subscribers get 1000 free calls per day. Subscribers can set the maximum number of calls in their dashboard to prevent going over and getting charged. This doesn’t seem like it would be too much of a problem if users set the module’s config appropriately.
                        I’m guessing that the module is trying to get data that is no longer free and some API’s are grandfathered ?? Or I misunderstood what type of account I needed from the start.
                        Where is the API address in the module’s code?
                        Let me know if I can provide further information.
                        T S 2 Replies Last reply Reply Quote 0
                        • T Offline
                          trividar @DDE12
                          If the Module doesn’t load the informations change ```
                          “https://api.openweathermap.org/data/3.0/onecall”
                          to
                          “https://api.openweathermap.org/data/3.0/onecall?”
                          an it should work!
                            sdetweil @DDE12
                            @DDE12 the API url is in the node_helper.js
                            we recently add a Parm to enable picking v3 of the API vs 2.5 (old free).
                            the add on modules need to do the same
                            • Y Offline
                              yk
                              Fantastic work! I was using the previous DarkSkyForecast version - easy shift to this one.
                              I’m trying to put the hourly data and daily data in the same “row” across using tiled view instead of 2 rows. I’m happy to edit the njk file (have tweaked a bit haven’t gotten it “just right” yet). Any ideas? I gather it’s something with the hourly and daily divs.
                              Is data available to get mm of precipitation in the hourly and daily blocks? It shows % chance - keen to add precipitation instead.
                              Thanks!!
                              • Y Offline
                                yk @yk
                                @yk said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                Thanks!!
                                Replying to my own post incase someone else wants a single row for 3 hours and 3 days. You’ll need to comment out lines 191, 309, 315, 318 in the njk file. This results in a single row readable left to right hours then days. It’s a useful view if you’re using a full width view.
                                  justbob
                                  So what’s the solution for the 401 error?
                                  The key works in default weather module, but in this one it’s not.
                                  @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                  Can you elaborate why?
                                  I for one don’t like seeing vulnerabilities and critical messages anywhere, and letting security flaws linger…
                                    sdetweil @justbob
                                    @justbob audit fix forces changes, and many times drags in breaking changes that we can do nothing about.
                                    we are not running a web site w hundreds of random users, and are not dragging in other page content with their scripts. we are calling apis…
                                    so the risks for (y)our site is extremely small…
                                    I don’t know the answer on openweathermap.
                                    • C Offline
                                      chris1971
                                      I am using MMM-DarkSkyForecast - everything was fine, but today the module is not loading anymore. Are there any changes or known issues? Do I have to swith to another module?
                                      Thx, Chris
                                      • BKeyportB Offline
                                        BKeyport Module Developer @chris1971
                                        @chris1971 DarkSky is dead. You’ll have to switch. Apple bought 'em up and is shutting down the APIs.
                                        • C Offline
                                          chris1971
                                          Thanks for the Info. Hope that the switch to Open Weather will be smooth. Long time ago that I have modified something on the mirror…
                                            sdetweil @chris1971
                                            @chris1971 @BKeyport
                                            there is a replacement API. same parns
                                            just different url
                                            was posted here in the last few months.
                                            no time to search right now
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
