    MM2 not loading text
    22 Posts 4 Posters 10.1k Views 3 Watching
    • B
      Beth
      hi i made my MM2 a year or so ago and it has worked fine but recently on boot it will show the mm2 screen and then not load the text it just shows a black screen i have tried to log into vnc but the RPI refuses the connection i tried swapping RPI’s and that didn’t work i also can’t open a command window or shut it down what should i do?
      • cowboysdudeC
        cowboysdude Module Developer @Beth
        @beth run it in ‘dev mode’ and see what the output is.
          sdetweil @cowboysdude
          @cowboysdude they can’t get into the machine… vnc doesn’t connect
          swvalentiS 1 Reply Last reply Reply Quote 0
          • swvalentiS
            swvalenti Project Sponsor @sdetweil
            Did the IP change by chance? Check to see if IP is static and ssh into pi that way.
            • B
              Beth @swvalenti
              @swvalenti how do i check?
                sdetweil @Beth
                @beth check your router to see if the system has a reserved address
                u can find its address with
                ifconfig command in a terminal window
                ethxx is ethernet wired
                wlanxx is wireless lan
                • swvalentiS
                  @Beth what Sam said
                  • B
                    Beth
                    UPDATE: there is a command window that papers on the boot up screen it does not leave i connected keyboard/mouse to it and can enter commands like a terminal window although pm2start will not work and npm start gives the following err (note i copied this by hand so there may be slight imperfections)
                    npm ERR! code ENOENT
                    npm ERR! sysca11 open
                    npm ERR! path /home/pi/package . json
                    npm ERR! errno -2
                    npm ERR! enoent no such file or directory, open ‘/home/pi/package . jason’
                    npm ERR! enoent This is related to npm not being able to find a file.
                    npm ERR! enoent
                      sdetweil @Beth
                      @beth said in MM2 not loading text:
                      /home/pi/
                      u are not in the MagicMirror folder for npm start
                      and its pm2 start (notice the space)
                      pm2 status will show u the pm2 currently managed apps
                      • B
                        Beth @sdetweil
                        @sdetweil i did that and it gave me the following err:
                        [PM2] spawning PM2 daemon with pm2 _home=/home/pi.pm2
                        [PM2] PM2 successfully daemonized
                        [PM2] [ERROR] Script not found: /home/pi/MagicMirror/mm.sh
                          sdetweil @Beth
                          ok, you used some old instructions, cause the file was moved to the installers folder a long time ago…
                          pm2 status
                          pm2 delete xx
                          where xx is the number of the line in the status (usually 0)
                          or the name in the line
                          pm2 save
                          then use my script to fixup pm2
                          see https://github.com/sdetweil/MagicMirror_scripts
                          the last command listed, fixuppm2.sh is the one u want to copy/paste to your terminal window
                          • B
                            Beth
                            @sdetweil how do i use your script?
                              sdetweil @Beth
                              it says
                              fixuppm2.sh, cut/paste this line into the terminal window on your device
                              • B
                                Beth @sdetweil
                                @sdetweil also i did the command and it said to type pm2 save so i did (i don’t remember the txt) then it gave me a err and said if i want to force save to type pm2 save --force i did that and now when i plug in the pi after showing the mm2 screen it just goes to a black screen
                                  sdetweil @Beth
                                  @beth this is the line you copy/pasted
                                  bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                  right?
                                  u don’t need to git clone this repo, just copy/paste the line
                                    sdetweil @Beth
                                    @beth black screen is another problem… (but pm2 launched MM on boot, so pm2 is ok)
                                    typically it means a library needed by one of the MM modules you are using is missing
                                    (we removed some dead libraries, in 2.16 and 2.17, but many modules didn’t document needing them, so oops…)
                                    SO, you need to look at the logs
                                    minimize MM, alt-spacebar, n
                                    then open a terminal window
                                    ctrl-alt-t
                                    then type
                                    pm2 logs – lines=100
                                    and look for module not found
                                    we know about
                                    request
                                    rrule-alt
                                    valid-url
                                    • B
                                      Beth
                                      i can’t “minimize” mm2 it is just a black screen with a terminal window it just shows the mm2 logo and to the left a terminal window (it is rlly weird and looks the same as the backround all black)on the bottom left (below the terminal window) it says dphys-swapfile.service
                                        sdetweil @Beth
                                        @beth that is something else.
                                        do you have ssh enabled?
                                        • B
                                          Beth @sdetweil
                                          @sdetweil i don’t have ssh although i do have vnc
                                            sdetweil @Beth
                                            @beth I think that is hung before mm gets running. the bottom message is a boot time message
