    [MMM-Buttons] Connect multiple buttons to send configurable notifications
    40 Posts 15 Posters 40.1k Views 14 Watching
    • P
      PointPubMedia
      Anyone have an example of a switching profile using Buttons + ProfileSwitcher ?
      • M
        Mar @PointPubMedia
        @PointPubMedia
                                module: 'MMM-ProfileSwitcher',
                                        includeEveryoneToDefault: true,
                                        ignoreModules: ["alert", "updatenotification"],
                                        enterMessages: false,
                                        leaveMessages: false,
                                        defaultTime: 15000,
                                        timers: {
                                                "PAGE2":{profile:"default"}, //Switch to defaultClass after defaultTime
                                module: 'MMM-Buttons',
                                minShortPressTime: 0,
                                maxShortPressTime: 1000,
                                minLongPressTime: 3000,
                                buttons: [
                                                pin:23,
                                                longPress: undefined,
                                                shortPress: {
                                                        notification: "CURRENT_PROFILE",
                                                        payload: "PAGE2"
                                                pin: 22,
                                                shortPress: {
                                                        payload: "default"
        • B
          B4rth
          can this module be used to send notification to the newsfeed module?
          I can’t get it to work, not throuht sending it directly nether over the remote-module.
          Have anyone have done it and can help me?
          • J
            Jopyth Moderator @B4rth
            @B4rth Please note that a notification never has a dedicated receiver. It is always a broadcast to all other modules. But sending notifications should definitely work with the module. Is your button working? If you are struggling with the correct URL for sending notifications, you can use this fiddle to build the correct URL.
            The below config should be a simple example for showing an alert (it sends a notification to all modules and the alert module reacts to it):
                    buttons: [
                            pin: 25,
                            longPress: {
                                notification: "SHOW_ALERT",
                                payload: {"title": "Hello World", "message": "Long Press!"}
                            shortPress: {
                                payload: {"title": "Hello World", "message": "Short Press!"}
            Make sure to check that you are using the correct pin number and change the notification config, if you want another module to react.
            Helpful sticky: How to troubleshoot
            • P
              PointPubMedia
              Hey guys…
              Is it me or having this module + ProfileSwitcher + Facial are not working well together.
              I have no issue using the buttons + ProfileSwitcher as I can toggle between profile! Facial recognize me but switch to nothing…
              • J
                Jopyth Moderator @PointPubMedia
                @PointPubMedia Did you check out this section? There are some changes needed to make both work together smoothly.
                • R
                  RickyTerzis
                  Hi…i am a new user here. In my case sing a python test program i can see every single instance of my button press is registered instantly. But in the mirror it seems MMM-Buttons doesnt register pushes unless sometimes I double or triple click.
                  • J
                    Jopyth Moderator @RickyTerzis
                    @RickyTerzis I released changes from the development branch, can you try experimenting with the new activeLow setting? Maybe you used the inverse wiring to the one I anticipated?
                    • P
                      pedroken
                      Hi, @Jopyth, great job on all modules that you developed. They’re great!
                      I`m trying to send a hide module action to the MMM-Remote-Control module in order to hide the clock (I already know that the id is module_2_clock).
                      I can’t get it to work with MMM-Buttons. The button is working (worked with an alert), but I think that I doing the wrong thing on the parameters of the HIDE module action.
                                  pin: 5,
                                  shortPress: {
                                     title: "Hide clock Test",
                                      notification: "REMOTE_ACTION",
                                      payload: {"action": "HIDE", "identifier": "module_2_clock"}
                      Can you or someone give me a clue?
                      I’d be greateful, thanks!
                      • J
                        Jopyth Moderator @pedroken
                        @pedroken I think you almost got it, just use module instead of identifier:
                        payload: {"action": "HIDE", "module": "module_2_clock"}
                        P 1 Reply Last reply Reply Quote 3
                        • P
                          pedroken @Jopyth
                          This post is deleted!
                          • P
                            pedroken
                            • SnilleS
                              Snille Module Developer
                              • J
                                Johans
                                @Jopyth
                                have installed the module, just small maybe stupid question. (i have no skills in electronics)
                                when you talk about pin 24, pin 25, do you mean GPIO24 - GPIO25 ?
                                • A
                                  AxLed Module Developer
                                  Hello Power Users,
                                  i also have a problem with MMM-Buttons, that Buttonpress is only sometimes recognized if i press twice or triple.
                                  Intension:
                                  I want to change MMM-Pages with to buttons, to move left/right through my pages.
                                  MMM-Remote-Control is set up and works.
                                  Moving through pages work bei MMM-Remote-Control Links and sendnotification.
                                  My setup:
                                  Raspberry 1 B+
                                  2 Buttons (circuit closed when pressed)
                                  connected between 1: GND an BCM26; 2: GND and BMC20
                                  I tested the buttons with a python script an they are recognized
                                  I searched this forum and still have some questions.
                                  1. Do Buttons on GND work or do i have to put them on +3,3V with a resistor instead?
                                  2. how do i use activeLow in MMM-Buttons Configuration? … activeLow: true ?
                                  Looking forward getting some tips.
                                  Regards AxLed
                                  cruunnerrC 1 Reply Last reply Reply Quote 0
                                  • cruunnerrC
                                    cruunnerr @AxLed
                                    @AxLed said in [MMM-Buttons] Connect multiple buttons to send configurable notifications:
                                    Maybe play around with the min and max Presstime.
                                    Wondering that this works with the module… when u press the Button the gpio would be set to low which is equal to 0.
                                    Afaik this isn’t possible through the module. Maybe u find a solution in the web, fo how changing the input state detection.
                                    And yes, u should use resistors for giving the GPIO a defined state when not pressing. When u don’t want to connect them physically (but i recommend) u could use the internal resistors (check below on this site http://wiringpi.com/the-gpio-utility/)
                                    So normal way (or the way i used) is to connect the button like this:
                                    Bild Text
                                    • A
                                      @cruunnerr
                                      Thanks for the tips, you made my day, it works now.
                                      What i did: Changed the wiring from negativ (GND) to 3.3V (with resistor) as shown on picture of cruunnerr wiring diagram.
                                      No i try to get a rotary switch and got it working, as i need some WAF (Woman acceptance faktor) for my mirror.
                                      Regards
                                      AxLED
                                      cruunnerrC 1 Reply Last reply Reply Quote 1
                                      • cruunnerrC
                                        cruunnerr @AxLed
                                        We could open a petition XD
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @cruunnerr
                                          @cruunnerr
                                          Your wiring diagram is fantastic. Is that a program?
                                          • cruunnerrC
                                            cruunnerr @Mykle1
                                            @Mykle1
                                            Jap, its called Fritzing
