    MMM-CalendarExt3
    679 Posts 82 Posters 2.7m Views 86 Watching
      almightyyoshi @sdetweil
      Ha! I was replying to yours. @MMRIZE hadn’t popped up in my feed when I replied. I thought I refreshed when I got on, but possibly not.
      • mumblebajM Offline
        mumblebaj Module Developer @sdetweil
        @sdetweil month_09 (wrong i guess) and month_9 (correct i guess)
          sdetweil @mumblebaj
          @mumblebaj dang computers!!! so picky,!
            What’s worse, I had an example right above it that I knew worked, and I still didn’t register that the 09 was the issue.
            • O Offline
              Ottosophie @almightyyoshi
              Hello, since the switch to Cal3, I no longer see any events in my calendar. I tried with the French holiday calendar, and it works, I added lots of events in mine, but nothing worked. Looks like it’s coming from my ICS file. An idea ? (translated with Google)
                sdetweil @Ottosophie
                @Ottosophie did u set a specific list of cals to read from in the cx3 config?
                did u add a name field to the cal entry in the base calendar module,?
                I’m guessing
                I just installed cx3 multiple times without any issue.
                • O Offline
                  Ottosophie @sdetweil
                  @sdetweil Thank you for your answer, I only restarted my raspberry several times and all my events came back, weird.
                  O 1 Reply Last reply Reply Quote 1
                  • O Offline
                    Ottosophie @Ottosophie
                    I have another question, is it possible for an event to be written on 2 lines so that we can see the end instead of the 3 small dots? Thanks
                    • O Offline
                      onryanti
                      Is it possible to set this as a rolling calendar forward where only the current week is shown in the top. Dont need the historical days to be shown?
                        sdetweil @onryanti
                        @onryanti set weeks in view=1
                        O O 2 Replies Last reply Reply Quote 0
                        • 12
                        • 13
                        • 14
                        • 15
                        • 16
                        • 67
                        • 68
                        • 14 / 68
