    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 99.1k Views 16 Watching
    • B
      broberg Project Sponsor
      Description:
      A simple module to put a countdown to an event, displays days left to the set date.
      Displays one line when the day is here and another one when the event is over.
      Screenshots:
      Download:
      [card:brobergp/MMM-doomsDay]
      Version 0.4 (16/3 2017)
      Added the option to change text when the day has passed,
      suggested by @Snille !
      Version 0.3
      Fixed half day bug, also increased the update interval so it now updates every hour instead.
      Version 0.2
      Fixed hour issue, not displaying the event in the morning.
      Version 0.1
      Quick and dirty, try it, should work.
      Mykle1M 2 Replies Last reply Reply Quote 7
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @broberg
        @broberg said in MMM-doomsDay - The countdown module,:
        Simple and elegant, I did, it does.
        Actually, I think you must have read my mind. I toyed with another module that has a burning candle. The name escapes me, but it was a countdown type module. Nice, but not for me. However, your module is just what I was looking for. It’s running now as a test for tomorrow but I can already tell you that this module is here to stay in my setup. I like that it doesn’t demand a lot of screen real estate and I am delighted that you included the css file so I don’t have to ask how to modify it in the forums.
        I’m a fan! Thanks for another perfect addition to my mirror.
        • Mykle1M
          @broberg
          i just checked before running off to work. Yesterday, I set a an event for today so that I could see the end result but the module still displays “1 Day Left” as it does in the picture above. The only thing I changed in the sample config was the date of the event and what it should say when the event arrived. I left the time untouched as you suggested. I have a short work day today so I’ll take a look at it when I get home
          B 2 Replies Last reply Reply Quote 0
          • B
            broberg Project Sponsor @Mykle1
            @Mykle1 humm, okey, probably because the function to round it up thinks it’s more than 0.5 days left and thus rounds it up to 1 instead of down to zero.
            Have to adjust the code a bit
            • J
              Jopyth Moderator @Mykle1
              @Mykle1 My advent module? Even though @broberg hasn’t mentioned it, it seems he based his work on that module.
              A feature suggestion from my side: It would feel more like an urgent thing closing in, if it could also show hours/minutes/seconds, too. Maybe use a formatting string for a moment.js duration? If I have some time, I might make a PR.
              Helpful sticky: How to troubleshoot
              B Mykle1M 2 Replies Last reply Reply Quote 0
              • B
                @Mykle1 Okey, I changed up some variables and I’m not able to test them myself, when you get home, could do a git pull on the doomsday module and test it out for me?
                • B
                  broberg Project Sponsor @Jopyth
                  @Jopyth Yes, I stripped out that module for this one, kept the start function and removed the rest since It was a bit over my head at the moment :)
                  Took me a lot longer than I’m willing to admit just to get the code to compare dates!
                  Actually thought about the hour/minute countdown as well, but decided to keep it real basic.
                  I figured you don’t really put that many hours in front of the mirror that it would be that important to see so much detail of the countdown. (And if you look the update interval is set to 5 hours just to keep it in the ballpark)
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Jopyth
                    @Jopyth said in MMM-doomsDay - The countdown module,:
                    My advent module?
                    Yes, that was it. :thumbsup_tone1:
                    • Mykle1M
                      when you get home, could do a git update on the doomsday module and test it out for me?
                      This is what I get when I attempted a git update as you suggested.
                      pi@Pi3:~/MagicMirror/modules/MMM-doomsDay $ git update
                      git: ‘update’ is not a git command. See ‘git --help’.
                      Did you mean this?
                      update-ref
                      I don’t want to mess anything up so I’ll wait till you advise further, thanks
                      strawberry 3.141S B 2 Replies Last reply Reply Quote 0
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @Mykle1
                        @Mykle1 git pull
                        • B
                          @Mykle1 sorry my bad mixing up stuff, git pull is the command to use in the Mmm-doomsday folder
                          • B
                            A second to slow,@strawberry-3-141 beat me to it :)
                            • Mykle1M
                              A photo finish? Thanks to both of you. :thumbsup_tone1:
                                  			module: 'MMM-doomsDay',
                                  			position: 'top_left', // This can be any of the regions, best results in center regions
                                      			doomsDay: "2017-02-24 24:00:00",  // the end day of the countdown, format is YYYY-MM-DD HH:MM:SS,
                                      			toWhat: 'Open the pool!',  // the title of your countdown event
                              				present: 'We are gonna rock',  //  What it should say on doomsDay date
                              				singular: `Day Left`, // what it should say when it's only one day left, default is `Day Left`
                              				plural: 'Days Left', // what it should say when it's more days left, default is `Days Left`
                              Ok, now the display says, “Open the pool!”, but underneath is says, “0 Days Left”
                              • B
                                @Mykle1 okey, then my fix didn’t do what I thought. I have restored it to as before, do a new git pull to get the last version again.
                                I will have to fix the half-day bug when I get back home :)
                                • Mykle1M
                                  ok, will do. Sorry about the troubles
                                  • B
                                    @Mykle1 no worries, first versions always have bugs :D
                                    • Mykle1M
                                      I see you have a new designation.
                                      Congratulations, Mr. Module Developer!
                                      • Mykle1M
                                        Just a follow up. I did the git pull to go back to the original version as you advised. I didn’t disable the module but I did set a new doomsDay for Tuesday. (This was yesterday) The module correctly reported “4 Days Left”. but as of this morning, it still reads "4 Days Left.
                                        • B
                                          @Mykle1 Finally home, and I believe I have fixed this issue now!
                                          do a new git pull and it should work in the mornings as well :D
                                          @illskool You should also do an update on this module! :D
                                          • Mykle1M
                                            Thanks bro. Gonna do that right now.
                                            Ok, I have my test running for tomorrow. The module is correctly displaying “1 Day Left”
                                                			position: 'top_right', // This can be any of the regions, best results in center regions
                                                    			doomsDay: "2017-02-27 24:00:00", // the end day of the countdown
                                                    			toWhat: 'Build Bed!', // the title of your countdown event
                                            				present: 'Get to it!',
                                            				singular: 'Day Left', // what it should say when it's only one day left, default is `Day Left`
                                            • 1 / 4
