    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 234.6k Views 13 Watching
    • pugslyP Offline
      pugsly
      Its been ok since I restarted so I am keeping an eye on it.
      On another note, why do some configuration items use " ", some use ’ ’ and others don’t have any quotation marks at all?
      I changed all of mine to ’ ’
        djsunrise19
        Thanks @pugsly, I checked that again, only with the following config:
        		module: 'MMM-Wunderground',
        		position: 'top_right',
        			apikey: 'XXXXXX',
        			pws: 'locid:NLXX8014;loctype:1'
        Result is still a black screen. I can see that error on the console (on my computer):
        Cannot GET /modules/MMM-Wunderground//MMM-Wunderground.js
        But the file is in the folder. Weird!
          djsunrise19
          Perhaps I found something: The Filename is: MMM-WunderGround.js. Tha app is looking for MMM-Wunderground.js. If I change the filename to MMM-Wunderground.js, the mirror starts, but the Module don’t work.
          I only see this:
          0_1464276980611_upload-f8788a81-cd89-4a52-806e-da102ea6f282
            djsunrise19
            Any ideas?
              djsunrise19
              I cloned your repo to MMM-WunderGround and edited the module name also. Now it works. You should change your Readme.
              Thanks for the cool module ;).
              RedNaxR 1 Reply Last reply Reply Quote 2
              • RedNaxR Offline
                RedNax Module Developer @djsunrise19
                @djsunrise19 Thanks for spotting my mistake :D I’ve modified the readme accordingly. Enjoy!
                  MagicCrumps1
                  it’s taking me forever but How do i change pws: ‘locid:’ for san francisco? I cant find the location ID for my city using google
                  • strawberry 3.141S Offline
                    Can be any WU api location info.
                    US Example: NY/New_York
                    Example: locid:NLXX8014;loctype:1
                    so just change it to CA/San_Francisco
                      MagicCrumps1
                      I’m getting a blank screen. Any idea why?
                      		module: 'MMM-WunderGround',
                      		header: 'Weather Forecast',
                      		    apikey: 'a1fa37eaff91b5450c',
                      		    pws: 'CA/San_Francisco',
                      		    fctext: '1',
                      			  fcdaycount: '5',
                      			  fcdaystart: '0',
                      			  hourly: '1',
                      			  hourlyinterval: '3',
                      				hourlycount: '2',
                      				alerttime: 1000,
                      				alerttruncatestring: 'english:'
                      RedNaxR 1 Reply Last reply Reply Quote 0
                      • RedNaxR Offline
                        Config looks good, could you have a look at your logs?
                        See here for some troubleshootign info: https://forum.magicmirror.builders/topic/86/how-to-troubleshoot
                        • RedNaxR Offline
                          RedNax Module Developer @MagicCrumps1
                          @MagicCrumps1 On the other hand, you api key seems to be invalid. (if the key in your post is indeed your key):
                            "response": {
                            "version":"0.1",
                            "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
                            "features": {
                          	"error": {
                          		"type": "keynotfound"
                          		,"description": "this key does not exist"
                            MagicCrumps1 @RedNax
                            This post is deleted!
                              @RedNax Still not working. Sorry, I should have included that I added a few extra keys to my personal api key thus making them invalid.
                              Loading config …
                              Loading module helpers …
                              Initializing new module helper …
                              No helper found for module: MMM-WunderGround.
                              All module helpers loaded.
                              Starting server op port 8080 …
                              Server started …
                              Starting module: newsfeed
                              Sockets connected & modules started …
                              Launching application.
                              • KirAsh4K Offline
                                KirAsh4 Moderator
                                That looks like everything did load up properly there. There’s a way to look at electron’s console logs but I don’t know what the keystroke is (maybe CTRL-W?). But, at times like this, I find it’s easier/faster for me to debug by using a different machine with Chrome/Firefox and load up the mirror that way by going to the rpi’s IP and port: http://10.0.0.1:8080 (assuming your rpi’s IP is 10.0.0.1, change it to match yours.) Black screen or not, you can always hit F12 on a windows browser and pull up the console log. Look for Javascript errors.
                                  MagicCrumps1
                                  Thanks KirAsh4 and RedNax! I resolved it. What happened was that I entered
                                  locationid: ‘5391959’
                                  on the currentweather module.
                                  I decided to delete the locationid key and left it blank and voila! It works now! You guys rock!
                                    MagicCrumps1
                                    @RedNax do you happen to know why my MMM-WunderGround module is not showing the forecast?
                                    0_1465449394807_upload-42252077-f895-4414-a919-4178207675af
                                    • RedNaxR Offline
                                      Any errors in the console or the web inspector?
                                        Shockwave
                                        This module is fantastic, thank you. I was wondering about getting weather for multiple areas. Is there a way to do that within the program or would I need to copy the directory to say, MMM-WunderGround2?
                                        • RedNaxR Offline
                                          RedNax Module Developer @Shockwave
                                          @Shockwave Thanks :) To use the module twice you can just enter multiple wunderground config sections in your config.js. It will then display both. There is no need to install the actual module twice.
                                            Shockwave @RedNax
                                            @RedNax Hey thanks for the quick response! I have 2 locations up and running and great. Unfortunately I now have another question. :smile: There is a special weather statement for one of my 2 locations, and it popped up an alert which is really cool. However, the popup alert just said, Special Statement, which is just the subject text, for lack of a better description. Is that the expected behavior?
                                            Special Statement
                                            Issued: 1:49 PM EDT Jun. 27, 2016 – National Weather Service
                                            … A strong thunderstorm with intense lightning will impact central
                                            Oconee County until 230 PM EDT…
                                            At 148 PM EDT… Doppler radar was tracking a strong thunderstorm
                                            with intense lightning 5 miles northwest of Walhalla… or near
                                            Oconee State Park… moving southeast at 25 mph.
                                            Locations to be impacted include…
                                            Walhalla… Westminster… Oconee State Park… Lake Keowee and Mountain
                                            Rest.
                                            In addition to intense lightning… pea size hail and wind gusts up to
                                            40 mph will be possible in these areas.
                                            • 6
                                            • 7
                                            • 3 / 7
