    Run MM on Ubuntu 16 VM
    31 Posts 11 Posters 34.1k Views 10 Watching
      A Former User @justjim1220
      @justjim1220
      try this.
      sudo apt-get install libgconf-2-4
      • justjim1220J
        justjim1220 Module Developer @AxLed
        @axled
        Thanks, that worked!!!
        :winking_face: :winking_face: :smiling_face: :smiling_face: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :smiling_face_with_sunglasses: :smiling_face_with_sunglasses:
        “Life’s Too Short To Dance With Ugly People”
        Jim Hallock - 1995
        • R
          reitrac
          Hello everyone,
          3months later, I hope it’s not too late :)
          @AxLed i’m trying to use “node serveronly” but have this error :
          WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
          I followed @Mykle1 tutorial to create default config.js but this not works.
          Any idea ? (My internet connection works)
          Thanks.
          ? 1 Reply Last reply
            A Former User @reitrac
            @reitrac
            Your config.js might have some misspell or wrong syntax.
            • R
              reitrac
              My config.js is by default :D
              I just changed “en” by “fr”.
              I’ll try to find config.js on Git and come back to you.
              Thanks.
              EDIT :
              I downloaded the latest config.js from : https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
              And not works :'(
              Mykle1M ? justjim1220J 3 Replies Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @reitrac
                @reitrac
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "US Holidays",
                						symbol: "calendar-check-o ",
                						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                			module: "compliments",
                			position: "lower_third"
                			module: "currentweather",
                				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                				appid: "YOUR_OPENWEATHER_API_KEY"
                			module: "weatherforecast",
                			header: "Weather Forecast",
                				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                Reply Quote 1
                  @reitrac
                  I can bet you have missed comma after language:"fr". 95% of syntax error was that thing in my case. :D
                  Reply Quote 1
                  • R
                    reitrac
                    @Mykle1 @Sean Didn’t works with the default config … I don’t know why.
                    • justjim1220J
                      justjim1220 Module Developer @reitrac
                      @reitrac
                      Did you change the name of the config file from ‘config.js.sample’ to ‘config.js’ ?
                      Jim Hallock - 1995
                      • R
                        reitrac
                        @justjim1220 Yeah of course :)
                        I followed @Mykle1 tutorial.
                        EDIT :
                        If can help, I’m using VirtualBox on MAC with UBUNTU 16.04 LTS
                        • R
                          reitrac
                          Hey,
                          i tried tu remove and reinstall MM.
                          Here is the new error :
                          VirtualBox:~/MagicMirror$ node serveronly/
                          module.js:328
                              throw err;
                          Error: Cannot find module 'express'
                              at Function.Module._resolveFilename (module.js:326:15)
                              at Function.Module._load (module.js:277:25)
                              at Module.require (module.js:354:17)
                              at require (internal/module.js:12:17)
                              at Object.<anonymous> (/home/monagraphic/MagicMirror/js/server.js:8:15)
                              at Module._compile (module.js:410:26)
                              at Object.Module._extensions..js (module.js:417:10)
                              at Module.load (module.js:344:32)
                              at Function.Module._load (module.js:301:12)
                          Some one can help me ?
                          EDIT :
                          It works, i launch a second time “npm install”.
