    MMM-Soccer - Standings, Schedules and Top Scorers
    Scheduled Pinned Locked Moved Sport
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 562.8k Views 43 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Egnos
      @Egnos Requires version >= 2.14 of MagicMirror!
      [02:57:33.259] [LOG] Starting MagicMirror: v2.10.1
      Your mirror is not up to date
      E 1 Reply Last reply Reply Quote 1
      • E Offline
        Egnos @strawberry 3.141
        @strawberry-3-141 ok thanks!
        I have updated Magic Mirror to the latest version.
        Now I only see “LOADING IN PROGRESS”, below the error:
        [ERROR] Getting league table: 403 Forbidden
        Where am I wrong now?
        Many Thanks.
          @Egnos seeing your previous post with the config, your league probably requires a free API key.
          • E Offline
            @strawberry-3-141
            The Italian Serie aA championship should be free. Also if I try to enter the site in the section of the Italian Serie A championship but I get this error:
            Italy Serie A
            Are you sure the site works?
            Many thanks.
              @Egnos the module doesn’t make use of the site native-stats.org. You need to specify the api key in the config such as api_key: 'YOUR_API_KEY',. https://www.football-data.org/client/register
              • E Offline
                @strawberry-3-141 with the Api Key works!
                Thanks.
                  Fixed
                  • Nunjuck template was rendering one team less than specified in config
                  https://github.com/fewieden/MMM-soccer
                  [card:fewieden/MMM-soccer]
                  H 1 Reply Last reply Reply Quote 1
                  • H Offline
                    hugopvl @strawberry 3.141
                    @strawberry-3-141
                    Hello,
                    I’ve been here for a few hours trying to get Portugal’s first league up and running, and from what I see it’s free, but it’s always charging and it doesn’t work. if you put germany it works correctly.
                    i try: don’t work
                    module: ‘MMM-soccer’,
                    position: ‘top_left’,
                    api_key: ‘24ea5f89c975401c90bdccb9dd5c16df’,
                    show: ‘PORTUGAL’,
                    league: {“PORTUGAL”: “PPL”},
                    logos: false,
                    colored: false,
                    max_teams: 7
                    this: dont work
                    show: ‘PORTUGAL’,
                    logos: false,
                    colored: false,
                    max_teams: 7
                    this: work fine
                    show: ‘GERMANY’,
                    logos: false,
                    colored: false,
                    max_teams: 7
                    thank so mutch
                    • H Offline
                      hugopvl @hugopvl
                      @hugopvl
                      I found the problem,
                      inside the folder of the module:
                      file MMM-soccer.js
                      defaults: {
                          api_key: false,
                          colored: false,
                          **show: 'PORTUGAL',**
                          focus_on: false,
                          max_teams: false,
                          logos: false,
                          leagues: {
                              **PORTUGAL: 'PPL',**
                              FRANCE: 'FL1',
                              ENGLAND: 'PL',
                              SPAIN: 'PD',
                              ITALY: 'SA'
                      so I think the module is only loading the leagues that are in the list as default, I added Portugal as default and added it to the leagues in the list below and it already works correctly.
                      THX
                        sdetweil @hugopvl
                        @hugopvl but u can do that in config.js
                        anything in defaults can be replaced w similar notation in the module config section
                        lavolp3L H 2 Replies Last reply Reply Quote 0
                        • lavolp3L Offline
                          lavolp3 Module Developer @sdetweil
                          @sdetweil @hugopvl
                          yes the only error in above config seemed to be that @hugopvl has written
                          instead of
                            leagues: {PORTUGAL: “PPL”},
                          How to troubleshoot modules
                          MMM-soccer v2, MMM-AVStock
                          • H Offline
                            hugopvl @sdetweil
                            supposed to be the right one, but if you read my previous comment, you can see that it wasn’t working, it just worked with the change in MMM-soccer.js
                            THX
                            • lavolp3L Offline
                              lavolp3 Module Developer @hugopvl
                              @hugopvl it didn’t work because of the small mistake I mentioned before. Your config entry was not recognized because your object was league: not leagues:
                              @strawberry-3-141 might include in the README that additional leagues can be included via the config entry you made before. Or include all of them from the start.
                                Today the European Championship will kickoff :flexed_biceps: :soccer_ball:
                                I’m currently working on version 3 of this module. It will be possible to not only display the standings of a league but also get the schedules and top scorers displayed in a carousel.
                                On top of that, the module will finally support cups such as the European Championship, Champions League, and World Cup.
                                If you want to test the beta for tonight’s kickoff, then head over to Github https://github.com/fewieden/MMM-soccer/pull/42 for all details.
                                If you find any issues or need help, please report them here https://github.com/fewieden/MMM-soccer/pull/42 so they are all grouped together.
                                  Fixed the standings for the ongoing European Championship. Schedules are now filtered by the current matchday.
                                  Check out https://github.com/fewieden/MMM-soccer/pull/42 to test v3 of the module.
                                    Babene1 Project Sponsor @strawberry 3.141
                                    @strawberry-3-141
                                    thanks for the new version, it’s really great. Great new features.
                                    However, i have Problem to install the leatest version with „schedules fix“. Unfortunately I am not so familiar with git. Is there a new branch available or have to use „feature/extract-api-provider"?
                                      strawberry 3.141 Project Sponsor Module Developer @Babene1
                                      @babene1 it is the same branch. You can check which branch you are currently using with git status.
                                      On branch feature/extract-api-provider
                                      Your branch is up to date with 'origin/feature/extract-api-provider'.
                                      To update to the latest commit you can simply run git pull, as no dependencies have changed.
                                        my branch is up to date
                                        this is my modul-config:
                                                    module: 'MMM-soccer',
                                                    position: 'top_right',
                                                        colored: true,
                                                        logos: true,
                                                        rotationInterval: 20 * 1000, // 20 seconds instead of 15 (default)
                                                        provider: {
                                                            'football-data': {
        apiKey: 'API Keay' // Replace with your API key
                                                        competitions: [
        code: 'EC', // European championship
        standings: {
        provider: 'football-data',
        focusOn: 'GER', // Germany
        maxEntries: 5
        schedules: {
        maxEntries: 7
                                        should not only display the current matchday?
                                          @babene1 schedules wasn’t optimized yet for no focusOn team specified.
                                          Run git pull to get the latest commit.
                                          lavolp3L M 2 Replies Last reply Reply Quote 0
                                          • lavolp3L Offline
                                            lavolp3 Module Developer @strawberry 3.141
                                            @strawberry-3-141 Really great work man!
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 10 / 11
