MMM-GQuotes
@cowboysdude many thanks to you. that is my lovely module. the mirror makes me smart now ;)
@pauabaer You’re welcome!
hi @cowboysdude i realized a new issue.
when you look at this page:
http://www.zitate-online.de/zitatdestages.xmlthere you have on the one hand the link for the specific quote. and under this one, the whole quote. It seems that your module only shows the “link-text” instead of everything.
do you know what i mean?
@pauabaer I updated it the best it’s going to be for now.
I am working on a module that supports both English and German so this one will be deprecated soon.
All these things will be worked out in the new one.
thanks @cowboysdude. works fine now. keep you in touch if i recognize anything.
@cowboysdude said in MMM-GQuotes:
I think it’s perfect the way it is. I can appreciate all the time and effort you’ve put into it. I can’t wait to see all the other marvelous things you’ve got in store for us. If there is anything I can do for you, just let me know.
@cowboysdude I love your module! :D
Do you know at which time the quote is getting updated?
@pauabaer soon. Very soon
I mean the qoute itself. Not the module :D
At the homepage it is 2 am. -
@pauabaer Well it will be working perfectly. I have one change to make and I’ll try to do it tonight…
@pauabaer said in MMM-GQuotes:
I’m just curious. Have you unvoted any of the posts regarding the work that @cowboysdude has been doing for you?
Hi cowboysdude,
regrading the problem of not showing other modules I have done some further investigation running the mirror in dev mode. Attached there are some “screenshots” of errors appearing if I enable GQuotes. The Radio errors I will address to the radio module owner. As this appears also with disabled GQuotes. But the uncaught type error seems to give some hint?
regards,
F.
Delete the entire directory MMM-GQuotes and reinstall.
@Mykle1 said in MMM-GQuotes:
Of course not! Not on purpose. I am glad about @cowboysdudes work he is doing for me/us!! I believe he knows that.
@cowboysdude: same result - same error :(
@Fistandantilus Not sure what’s going on but it’s working everywhere else…
I get no errors or issues installing or running it.
How are you installing it?
~MagicMirror/modules
type: git clone https://github.com/cowboysdude/MMM-GQuotes.git~MagicMirror/modules/MMM-GQuotes
type: npm installmake sure the config is correct. Not much to it really…
I just deleted mine and did the above mentioned actions and it works perfectly.
As did I.
@cowboysdude: this is exactly the procedure I was following. Could it probably be caused by some shared ressources with another module?
The following modules are installed:
iFrame
MMM-FHEM
MMM-nasaastropic
MMM-SystemStats
MMM-iCloud-Client
MMM-RadioDe
MMM-GQuotesF.
