    stronger Raspberry Pi 3 Alternatives
    50 Posts 11 Posters 65.4k Views 10 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @stacywebb
      @stacywebb said in stronger Raspberry Pi 3 Alternatives:
      I haven’t done any benchmarking as of yet. Once I do, I’ll post the results.
      If you could do some comparisons using nmon between a Pi3 and the Rock64 I’d really be interested in the results, as they pertain to this topic.
      https://forum.magicmirror.builders/topic/4684/electron-cpu-usage
      Otherwise, I’m looking forward to your results on the Rock64.
      Reply Quote 1
      • cruunnerrC
        cruunnerr
        @Mykle1
        https://youtu.be/FjbzKfeHB_8?t=8m10s
        As i understood, u were able to use GPIO commands the same way u do on a raspberry. Seems to be a nice option
        Benchmarks at 08:10
        Mykle1M 1 Reply Last reply
        Reply Quote 1
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @cruunnerr
          @cruunnerr
          No WiFi? NFW!
          N 1 Reply Last reply
          Reply Quote 1
          • N
            ninjabreadman @Mykle1
            @Mykle1 The b/g/n adapter is a further $7, and will also give you an antenna for better connectivity. The more robust (and likely excessive) b/g/n/ac dual-antenna is $22.
            Has anyone tried running MM on an Intel Compute Stick? I’m not normally a fan, but it seems it would suit the form factor and be easily placed behind a mirror, and has more fulsome specs to accommodate advanced modules, media streaming, etc.
            Problem with config or JavaScript? Copy/paste it into JSHint.
            Check out the detailed walkthroughs on install, config, modules, etc.
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @ninjabreadman
              @ninjabreadman
              No, but I’ve used, and am using, old laptop boards (and one netbook) with ubuntu. They can be gotten on the cheap and come with everything you need. :-)
              • cruunnerrC
                cruunnerr
                Well, i need to say that especially for me, the ability to use GPIOs is important. Unfortunately the power of the raspi’s & co is not as good as x86 systems.
                Does anyone know if it would be possible to use MagicMirror on a x86 system and uses external GPIOs? I installed an MM instance on a virtual machine running Linux. When i add a module which uses GPIOs i get errors. Is there a possibility (maybe with server-client)
                • emloweE
                  emlowe Module Developer
                  You mean something like this:
                  https://www.adafruit.com/product/2264
                  I just did a google for “USB GPIO breakout board”
                  -Earle
                  • cruunnerrC
                    cruunnerr
                    @emlowe said in stronger Raspberry Pi 3 Alternatives:
                    do you think its just that simple? that would be great.
                    The question is, if the program code or the configuration will be the same as on a RPi. Or are u need to do some complicated hacks to use the board with MM?
                    edit:
                    okay… i searched now, too.
                    Found this:
                    https://www.raspberrypi.org/blog/gpio-expander/
                    what do u guys think about that?
                    • emloweE
                      Well, adafruit has python sample code. You likely need the node FT232H module to use it from JS.
                      https://www.npmjs.com/package/FT232H
                      Does it actually work - I have no idea - that board is also apparently out of stock :-)
                      Sample python code below
                      # Import standard Python time library.
                      import time
                      # Import GPIO and FT232H modules.
                      import Adafruit_GPIO as GPIO
                      import Adafruit_GPIO.FT232H as FT232H
                      # Temporarily disable the built-in FTDI serial driver on Mac & Linux platforms.
                      FT232H.use_FT232H()
                      # Create an FT232H object that grabs the first available FT232H device found.
                      ft232h = FT232H.FT232H()
                      # Configure digital inputs and outputs using the setup function.
                      # Note that pin numbers 0 to 15 map to pins D0 to D7 then C0 to C7 on the board.
                      ft232h.setup(7, GPIO.IN)   # Make pin D7 a digital input.
                      ft232h.setup(8, GPIO.OUT)  # Make pin C0 a digital output.
                      # Loop turning the LED on and off and reading the input state.
                      print 'Press Ctrl-C to quit.'
                      while True:
                      	# Set pin C0 to a high level so the LED turns on.
                      	ft232h.output(8, GPIO.HIGH)
                      	# Sleep for 1 second.
                      	time.sleep(1)
                      	# Set pin C0 to a low level so the LED turns off.
                      	ft232h.output(8, GPIO.LOW)
                      	time.sleep(1)
                      	# Read the input on pin D7 and print out if it's high or low.
                      	level = ft232h.input(7)
                      	if level == GPIO.LOW:
                      		print 'Pin D7 is LOW!'
                      	else:
                      		print 'Pin D7 is HIGH!'
                      • Mykle1M
                        @cruunnerr said in stronger Raspberry Pi 3 Alternatives:
                        Well, it’s certainly possible to run MM on a x86 system. I haven’t a clue about external GPIO usage but it looks promising. For now, I use my mirror for some things and my Alexa for everything else.
                        • 3 / 3
