I only have a white command line after following the tutorial
After having followed the tutorial and restarted the raspberry, I only have a while command line on the top left corner, nothing else.
I didn’t see any error. Does someone has an idea of what could I’ve done wrong? Or where I can look to better understand my issue?
@jgrossrieder said in I only have a white command line after following the tutorial:
Which tutorial, there are many ;)
@cowboysdude said in I only have a white command line after following the tutorial:
This one, since I’m installing on my Raspberry pi: https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
Is this regular Pi or a piZero?
There are a ton of steps in that tutorial. I found that when I started out doing this I would ‘think’ I’d followed all the steps but missed a ‘few’ LOL That was ME, not saying that’s what you’re doing but it does happen.
Now if you are using a regular PI why not just install noobs and follow this tutorial here:
https://github.com/MichMich/MagicMirrorMuch easier :)
The regular Pi 3 ;).
Why? Because it was the officials steps, but I will try with your tutorial -
@jgrossrieder There is an installer script you can use
bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
I executed this one, now I’ve some display! But there is a lot of things that the other did that this one didnt, like rotating the screen, or hiding the cursor, any idea how to do this?
also, I rebooted the Pi, and the mirror didn’t restart :(
And disable the screesaver?
@jgrossrieder Do a forum search for ‘automatically starting mirror’ or something similar :)
Easiest way:
https://forum.magicmirror.builders/topic/1503/how-to-disable-screensaver/8 -
Here it is:
https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
