MMM-NOAA - Another Weather Module
@kbostick88 Hi, look at ur config its called position not postition only a little typing error
@tbbear Thank you, I can’t believe I didn’t see that. Now it shows up! but I have NaN issues
@kbostick88 are u sure that ur keys are ok and also ur pws1. i will check them if u want
@kbostick88 Looks like ur pws1 is not correct, maybe again a typing error … -)
I got it. Thanks!
@kbostick88 your welcome
@tbbear I am having issues with one other module also, any chance you might be able to help me with that one? I had the module working, but all of a sudden part of it seems broke. I get NaN on that one… its MMM-cryptocurrency
Bitcoin works fine, ethereum, litecoin and ripple all show NaN but all 4 were working yesterday. not sure why they are not working now, nothing changed.
@kbostick88 sorry, i dont use any one of this modules. i would love to help u but i dont know the modules u are using. But maybe contact Mykle1 he is the best helper here. If u like the help i did for u maybe gimme a click on the ^ sign close to my answers.
ok thanks, i posted it in the correct module so ill see if i can get it. Thanks for the help!
@tbbear Thanks, if i can help contact me anytime, maybe u can show me ur config, cause in the most cases their is the problem
module: "MMM-cryptocurrency", position: "top_right", config: { currency: ['bitcoin', 'ethereum', 'litecoin', 'ripple'], displayType: 'logo', showGraphs: false } }``` -
This post is deleted! -
@Stellanova Did yours just stop working too? mine was working fine for several days
please do not use this thread for a complete other module and problem
MMM-NOAA3 is in the works…
It will be a little while but rest assured I’m working on it :)
Finally updated the module, and I like the new look. However, I was wondering if there’s a toggle to hide the “Forecast” piece.
You can’t hide it in css?
I believe the last version had some toggles in the config which were quite nice to have, which is why I am asking if it’s there now. I took a quick look at the code, and wasn’t able to find anything like it.
I would prefer not to mess with CSS files, because it would mean that updates might break my config.
@Zooooooom said in MMM-NOAA - Another Weather Module:
No sir. Your config is unaffected by your custom.css entries. In fact, it’s the very reason there is a custom.css file, so that you can make those changes without changing the module files and you don’t lose your changes when the module is updated.
