    MMM-NOAA - Another Weather Module
    690 Posts 77 Posters 2.8m Views 70 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @mac0178
      @mac0178 glad it worked! :)
      • ChrisC Offline
        Chris
        Hello,
        I tried to install this module but I can not make it work.
        instead of the module on the magic mirror screen, it says: “weather info”
        I attach to this post my config file:
        			module: 'MMM-NOAA',
        			position: 'top_right',
        				apiKey: "a3cXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
        				useAir: true,             // set to false if you do not want to use Air Quality Index
        				airKey: "Z4pXXXXXXX",    // IF you want Air Quality Index
        				pws: "pws:I93SEVRA3",         // go here to find your pws: https://www.wunderground.com/wundermap
        				lat: "48.919XXX",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
        				lon: "2.533XXX",       // need this for sunrise/sunset  if left blank none will showshowClock: true,           // Hides or shows clock
        				dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
        				format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
        				ampm: false,                // to show AM and PM on Sunrise/Sunset time
        				showGreet: false,          // deafult is false - to show greeting under clock and above date
        				name: "",                  // Your name
        				showWind: true,
        				showDate: false,
        				showForecast: true,         //show bottom 3 day forecast
        				flash: true,                 //Today in forecast flashes halo
        				showUV: true,               //show UV index
        				showBar: true,             // show Barometer
        				showHum: true,              //show Humidity level
        				position: 'top_right',       //whatever you have in above position must also be here
        				alert: true                //show weather alerts default is true
        By contrast, weather underground works properly so I think it does not come from the API key.
        Does anyone have an idea? Thank you
          cowboysdude Module Developer @Chris
          @Chris start the mirror like this
          npm start dev
          in that window let me know what if any errors you’re getting :)
          • ChrisC Offline
            Chris
            Thank you for your prompt response,
            here is what is indicated at startup:
            > magicmirror@2.2.1 start /home/pi/MagicMirror
            > sh run-start.sh "dev"
            Starting MagicMirror: v2.2.1
            Loading config ...
            Loading module helpers ...
            No helper found for module: calendar_monthly.
            Module helper loaded: MMM-MyCommute
            Module helper loaded: MMM-SoccerLiveScore
            Module helper loaded: MMM-soccer
            No helper found for module: MMM-Globe.
            Module helper loaded: MMM-Remote-Control
            Module helper loaded: mmm-suncalc
            Module helper loaded: MMM-NOAA
            No helper found for module: mmm-wu-moonphase.
            Module helper loaded: MMM-Tools
            No helper found for module: MMM-Snow.
            All module helpers loaded.
            Server started ...
            Connecting socket for: MMM-MyCommute
            ====================== Starting node_helper for module [MMM-MyCommute]
            Connecting socket for: MMM-SoccerLiveScore
            MMM-SoccerLiveScore helper started...
            Connecting socket for: MMM-soccer
            Starting module: MMM-soccer
            Connecting socket for: MMM-Remote-Control
            Starting node helper for: MMM-Remote-Control
            Connecting socket for: mmm-suncalc
            Starting node_helper for mmm-suncalc:
            Connecting socket for: MMM-NOAA
            Starting module: MMM-NOAA
            Connecting socket for: MMM-Tools
            Starting module: newsfeed
            Launching application.
            Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX/basic.ics - Interval: 300000
            Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
            Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
            TypeError: Cannot read property 'observation_location' of undefined
                at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:26:49)
                at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
                at emitTwo (events.js:106:13)
                at Request.emit (events.js:191:7)
                at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1163:10)
                at emitOne (events.js:96:13)
                at Request.emit (events.js:188:7)
                at IncomingMessage. (/home/pi/MagicMirror/node_modules/request/request.js:1085:12)
                at IncomingMessage.g (events.js:286:16)
                at emitNone (events.js:91:20)
            Thanks for your help
              @Chris said in MMM-NOAA - Another Weather Module:
              Cannot read property ‘observation_location’ of undefined
              Not seeing your location…
              ChrisC 1 Reply Last reply Reply Quote 0
              • ChrisC Offline
                Chris @cowboysdude
                @cowboysdude said in MMM-NOAA - Another Weather Module:
                I corrected the pws value and it works. I made a mistake in the way of writing it.
                instead of
                pws: "I93SEVRA3",
                Sorry to have bothered you for so little
                Thank you very much for your help
                cowboysdudeC 1 Reply Last reply Reply Quote 1
                  @Chris Hahhahaahha it happens :) Glad you got it working!!! You didn’t bother me!!
                  • P Offline
                    Peter
                    First: this is a beautiful module, I like it very much!
                    But sometimes it does strange things: today is thursday and normally the module would show today, friday, saturday, etc.
                    But sometimes the module suddenly shows wednesday (yesterday) only.
                    After restarting (or from itself) the module is normal again.
                    Somebody any idea?
                    Peter
                    cruunnerrC 1 Reply Last reply Reply Quote 0
                    • cruunnerrC Offline
                      cruunnerr @Peter
                      @Peter
                      It sounds like your whole MagicMirror instance freezes. But you can only see this at the NOAA module, because once the modules have loaded their informations they will show (without updated informations) their stuff.
                      So the other modules freezes, too but u can’t recognize it because u normally see no refreshing data. But on the NOAA module u expect a change of the shown data.
                      Sorry, my english is bad. Hope u could understand.
                      please check your log files and post the content
                      • P Offline
                        Peter @cruunnerr
                        @cruunnerr your english is good to understand.
                        I think my MM is freezing indeed (see my other thread “something is wrong”).
                        But I do not understand why NOAA gives yesterdays weather while freezing.
                        If it gave only todays wheather I would understand.
                        I suspect one of the other modules making my MM freeze.
                        But which one …
                        Peter
                        • 24
                        • 25
                        • 26
                        • 27
                        • 28
                        • 68
                        • 69
                        • 26 / 69
