    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 32.2k Views 18 Watching
    • C Offline
      cben0ist
      is this an acceptable configuration ?
      address:"0.0.0.0",
      or is it better specifying the actual server ip here ?
      • NiggichN Offline
        Niggich
        I put my config like this:
        	port: 1103,
        	address: '0.0.0.0',
        	electronOptions: {
        	ipWhitelist: [
        		"127.0.0.1",
        		"::ffff:127.0.0.1",
        		"::1",
        		"::ffff:192.168.113.60",
        		"::ffff:192.168.113.22",
        		"::ffff:192.168.113.97",
        		"::ffff:192.168.113.29",
        		"::ffff:192.168.113.103",
        		"::ffff:192.168.113.66"
        The Remote-Control says “This device is not allowed to acces your mirror”. The IP-Adresses are correct.
        • F Offline
          FreddeHamm
          i have the same problem
          i already set “adress” to :“0.0.0.0” and edited the ipwhitelist to
          ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”]
          but still i get no access.
          Btw. its a raspberry pi zero with serveronly
            Jopyth Moderator @Niggich
            @Niggich For my setup (raspberry pi 2) something changed after the update, but when I changed my IP addresses to the IPv4 notation (remove ::ffff: from your addresses) it worked again. Which format do the blocked addresses have in your logs (see below)?
            @FreddeHamm Are you sure those CIDR numbers are correct?
            When in doubt, check the output or logs (pm2 logs MagicMirror or pm2 logs mm if you used the old auto starting guide), there should be a line telling you which IP address was received. Also there are a calculators which transform your IP range to the CIDR notation.
            Helpful sticky: How to troubleshoot
            • N Offline
              Nick
              Same here, tried addres 0.0.0.0 and various things in the Whitelist.
              A ping gives “destination unreachable”… SSH also doesn’t work.
              Can someone please suggest ways to troubleshoot?
                Mykle1 Project Sponsor Module Developer @Nick
                @Nick said in After update to Mirror to 2.1.3 - no working Whitlist:
                Have you tried OUTSIDE your Whitelist, as such:
                var config = {
                	port: 8080,
                        address: "0.0.0.0",
                	ipWhitelist: [], // Set [] to allow all IP addresses.
                • N Offline
                  Nick
                  Thx @Mykle1, indeed I have. See the beginning of my (working) config file below.
                  What is suspicious to me is that not even a Ping works to that IP, even though I’ve checked it by printing it on the screen of the MM and in the router.
                  Also, before my Whitelist was a long list of IPs, now I’ve tried the [] option but to no avail…
                  /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                  var config =
                          address: "0.0.0.0",
                          electronOptions: {
                          ipWhitelist: [
                                          module: "alert",
                                          module: "updatenotification",
                                          position: "top_bar",
                                          module: "MMM-Remote-Control",
                                          position: "middle_center",
                    Pinging the mirror’s IP fails? Pinging other devices on your network is successful?
                    • N Offline
                      Nick
                      Yes, including my personal wiki on another Raspberry Pi, all with 2-5ms
                      Mykle1M J 2 Replies Last reply Reply Quote 0
                        None of this may help, but you can use it as a checklist.
                        • ifconfig on Pi reports the IP address you are trying to ping (wlan0) assuming wifi
                        • Connecting Pi via ethernet, ifconfig and trying to ping then
                        • Pinging another device from the Pi itself
                        • The MM software updates. Clock, calendar, weather, etc?
                        Logically, if the only thing you can’t do is ping or connect to the Pi, then something is wrong on the software side, whether a corruption, an edit or a failed installation of the software or dependencies during the upgrade process. The answer in that case, with the most success, is a manual installation, IMHO. You can continue to troubleshoot, which could take a long time, or you can know in less than an hour. You will not lose anything in doing this.
                        https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
                          Jopyth Moderator @Nick
                          @Nick As @Mykle1 said: something is wrong if you can neither ping nor ssh. You definitely need to check your general wifi/ethernet setup. This is not something that can be solved through the config file.
                          • FlatPepsiF Offline
                            FlatPepsi
                            This post is deleted!
                              ronanversendaal
                              Just came across this post while troubleshooting this issue.
                              I got it working by converting the ip range to CIDR format by using this page as mentioned in older posts. I added these ip’s to the whitelist (without the ::ffff: !) and it worked.
                              It’s also important to set the address value to “0.0.0.0”
