    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 150.6k Views 25 Watching
      Bangee Module Developer
      If you use pin 7 in your config its nr 4
      You have to use the gpio nr.
        samydp
        Thank you it works fine !!
        • P Offline
          phantomlight @Bangee
          @Bangee I tried everything regarding the white screen issues. I’m a noob. was able to get magic mirror installed, I also installed the PIR motion detection and can confirm motion is detected.
          Downgraded Node JS
          Installed the electron
          made sure module was added in config.js
          I am using the Raspberry PI 3 mode b.
          Can somebody confirm this module is working with Raspberry Pi 3.
          Any help would be greatly appreciative…
          Thanks.
            can you restart the magicmirror an check what errormessage you have:
            pm2 logs mm
            P B 2 Replies Last reply Reply Quote 0
            • P Offline
              @Bangee Thank you so much for responding. I removed magic mirror completely reinstalled… then installed the module.
              All is well now… Thank you so much!
                bibi @Bangee
                @Bangee hi ! thx for your nice tuto, i have proceed with it but i got a warning as below:
                pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                npm WARN prefer global npm@3.10.9 should be installed with –g
                do i have to do smt specific or it’s just ok to leave it without any action?
                ps: my config file is also not working with PIR module implemented… maybe that is the reason? thx you very much for any feedabck guys!!
                  @bibi did you try it with the instructions from paviro:
                  https://github.com/paviro/MMM-PIR-Sensor
                  I don’t think that this warn is your problem. I have so many times these warnings :-D
                  You sould send us whats in your pm2 logs mm
                    bibi @Bangee
                    @Bangee yes i follow his and yours… quite the same… regarding this npm warning I do nothing then as understood?
                    I will send you the log later when I’m home
                    Thx bangee! Appreciated!
                      bibi @Bangee
                      @Bangee so as expected the pm2 log mm just show that the file has syntax error… here is my config file, i put the module at the end…
                      thx again :)
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @bibi
                        @bibi powerSaving: true
                          bibi @strawberry 3.141
                          @strawberry-3.141 right was a typo but still the config file is “not created” :((
                            @bibi can you post your whole config file?
                              @strawberry-3.141 here you go and many thx in advance - i struggling with this now (sorry i don’t know why only few parts of the code is with the color background)
                              /* Magic Mirror Config Sample
                               * MIT Licensed.
                              var config = {
                                      port: 8080,
                                      language: 'en',
                                      timeFormat: 24,
                                      units: 'metric',
                                                      module: 'alert',
                                                      module: 'clock',
                                                      position: 'top_left'
                                                      module: 'calendar',
                                                      header: 'US Holidays',
                                                      position: 'top_left',
        symbol: 'calendar-check-o ',
        url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
                                                      module: 'compliments',
                                                      position: 'lower_third'
                                                      module: 'currentweather',
                                                      header: 'xxx',
                                                      position: 'top_right',
                                                              locationID: 'xxx',  //ID from http://www.openweathermap.org
                                                              appid: 'xxx'
                                                      module: 'newsfeed',
                                                      position: 'bottom_bar',
                                                              feeds: [
        title: "New York Times",
                                                              showSourceTitle: true,
                                                              showPublishDate: true
                                                      module: 'MMM-PIR-Sensor',
                                                              sensorPIN: 22,
                                                              powerSaving: true
                              Note from admin: Please use Markdown on code snippets for easier reading!
                              • Y Offline
                                yawns Moderator
                                Everything with at least one tab indent is treated as code and highlighted. ;)
                                  bibi @yawns
                                  @yawns thx! :))
                                    @bibi you forgot to close the config section in the newsfeed module, add } after showPublishDate: true and you should be fine
                                      @strawberry-3.141 yeah! thx a lot. at least i can see this white screen now :p :))) have to figure out how to solve this… Only if it’s realllllly really obvious for you/someone, i post my log file. (sorry to ask so much) otherwise not prob, i will reinstall the PIR module…
                                      [TAILING] Tailing last 10 lines for [mm] process (change the value with --lines option)
                                      /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
                                      0|mm       |     at Error (native)
                                      0|mm       |     at process.module.(anonymous function) [as dlopen]     (ELECTRON_ASAR.js:168:20)
                                      0|mm       |     at Object.Module._extensions..node (module.js:583:18)
                                      0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:168:20)
                                      0|mm       |     at Module.load (module.js:473:32)
                                      0|mm       |     at tryModuleLoad (module.js:432:12)
                                      0|mm       |     at Function.Module._load (module.js:424:3)
                                      0|mm       |     at Module.require (module.js:483:17)
                                      0|mm       |     at require (internal/module.js:20:19)
                                      0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                                       /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
                                       0|mm       | No helper found for module: clock.
                                       0|mm       | Initializing new module helper ...
                                       0|mm       | No helper found for module: compliments.
                                       0|mm       | No helper found for module: currentweather.
                                       0|mm       | No helper found for module: weatherforecast.
                                       0|mm       | Whoops! There was an uncaught exception...
                                       0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                       0|mm       | If you think this really is an issue, please open an issue on GitHub:    https://github.com/MichMich/MagicMirror/issues
                                       0|mm       | Launching application.
                                        bibi
                                        Ok the problem it’s solved! except the screen is turning on and off in a very strange way… have to figure out why.
                                        For those you would get the same issue as me, what i did after fixing my config file was:
                                        1. sudo apt-get update & upgrade & reboot,
                                        2. go in MMM-PIR-Sensor folder in modules folder and run npm install there
                                          3.sudo reboot
                                          cheers
                                          Medo
                                          Also had the “white screen” problem. I installed a complete new Raspian (with PIXEL), a new MagicMirror - including node.js in version 7.3.0
                                          As soon as i tried to get the MMM-Pir-Sensor working, it failed (with an white screen). Heres, how i solved my problem.
                                          At first: Theres no need to downgrade the node (i tried this too, and had no luck)
                                          I figured out, that my problem was an MMM-PIR-Sensor installation error i did not recognized at the beginning. When i tried “npm install” i got something like this (an error):
                                          "gyp WARN EACCES user “root” does not have permission to access the dev dir “/root/.node-gyp/5.12.0”
                                          I figured out, that there are two ways of solving this:
                                          1. CHOWN the directory the install procedure tries to install
                                          2. use “npm install --unsafe-perm”
                                          Im aware that option two is not the “elegant” way, but it solved my problem (and i did not have to change directory permissions).
                                          I removed all files and git the files again (like described some lines above from banglee) and then just use “npm install --unsafe-perm”
                                          The “–unsafe-perm” option was the key to my problem…
                                          Z 1 Reply Last reply Reply Quote 0
                                          • Z Offline
                                            zichao92 @Medo
                                            Hi @Medo ,
                                            I have gotten the white screen problem as well and my raspberry pi configuration is similar to yours ( running on PIXEL with the latest nodejs).
                                            However, upon using option 2 from your solution. I have obtained this error :
                                            npm ERR! Linux 4.4.38-v7+
                                            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "--unsafe-perm"
                                            npm ERR! node v7.3.0
                                            npm ERR! npm  v3.10.10
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e        ../../node_modules/electron-prebuilt`
                                            npm ERR! Exit status 255
                                            npm ERR!
                                            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script '        electron-rebuild -e ../../node_modules/electron-prebuilt'.
                                            npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-P        IR-Sensor package,
                                            npm ERR! not with npm itself.
                                            npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                                            npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
                                            npm ERR! Or if that isn't available, you can get their info via:
                                            npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
                                            npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                                            Does anyone have solution to this?
                                            • 3 / 5
