    Downgrade Magic Mirror?
    14 Posts 6 Posters 10.5k Views 4 Watching
    • chaseb1357C Offline
      chaseb1357
      What’s the best way to go about downgrading the magic mirror software but keeping all modules intact?
        Mykle1 Project Sponsor Module Developer @chaseb1357
        @chaseb1357
        Rename your current MagicMirror folder to something else.
        Install the MM version of your choice.
        Move your modules into the new MagicMirror folder.
        • cowboysdudeC Offline
          cowboysdude Module Developer
          Stick of dynamite… hahahaahhha
          chaseb1357C 1 Reply Last reply Reply Quote 0
            chaseb1357 @cowboysdude
            @cowboysdude Thank you so much, it worked like a charm. After successfully welding an enclosure together to put the dynamite and RPi, I set it off. And BOOM! Magic Mirror is now running like a charm ;)
            cowboysdudeC 1 Reply Last reply Reply Quote 1
            • MichMichM Offline
              MichMich
              Just curious. Why do you want to downgrade?
                chaseb1357 @MichMich
                @MichMich The only reason for me is I really love the ability to use the Remote Control module so I can easily remote access my mirrors. And I noticed in the new update that Http isn’t working, so I just want to go back to where I can remote access my mirrors.
                • cruunnerrC Offline
                  cruunnerr
                  strange… i use the actual version and remote control is working. i even updated the mirror with the remote control module XD worked fine :)
                    chaseb1357 @cruunnerr
                    @cruunnerr that is strange indeed. I’m not sure what’s going on with my setup then. I mainly made this post because I discovered this one researching before posting: https://forum.magicmirror.builders/topic/5025/can-t-access-magic-mirror-via-http
                      cruunnerr
                      well, i allowed to listen to all ip’s at all:
                      var config = {
                              address: "0.0.0.0", // Address to listen on, can be:
                                                    // - "localhost", "127.0.0.1", "::1" to listen on lo$
                                                    // - another specific IPv4/6 to listen on a specific$
                                                    // Default, when address config is left out, is "loc$
                              port: 8080,
                              ipWhitelist: [], // Set [] to allow all IP addresses
        // or add a specifi$
        // ["127.0.0.1", ":$
        // or IPv4 range of$
                      Maybe thats the reason. I had a few problems with just allowing single ip dresses so i went to this option. But works fine, and i have a hardware firewall installed in my network so i hope that this is enough^^
                      for external access i use VPN
                        chaseb1357
                        Well what do you know. It works now! My old code was this and it worked fine on older versions:
                        	"ipWhitelist": [
                        		"127.0.0.1",
                        		"::ffff:127.0.0.1",
                        		"::1",
                        		"192.168.11.1/24",
                        		"::ffff:192.168.11.1/24"
                        But now that I put this it works fine, no need to downgrade now, much thanks:
                        	"address": "0.0.0.0",
                        	"ipWhitelist": [
                          cruunnerr
                          great :)
                          first i tried it with “192.168.178.0/24”, too but couldn’t get it work. i read something about disabling IPv6 would help etc.
                          but however i am glad u got it working
                            cowboysdude Module Developer @chaseb1357
                            @chaseb1357 said in Downgrade Magic Mirror?:
                            HAHAHAHHHAHAHA Actually I just put 2.10 back on mine because well it works… LOL
                            • K Offline
                              Kastore
                              Yes i know this topic is old, but it is spot on what i look for.
                              How do I downgrade to an older version.
                              I cant find any git pullcommand and the copy and paste and keep getting errors…
                              2.3 worked like a charm and 2.4 keeps producing errors for me that I cant fix due to my lack of knowledge
                                Mykle1 Project Sponsor Module Developer @Kastore
                                @kastore
                                https://github.com/MichMich/MagicMirror/releases
